Reload this Page >
Spitfire Mk XIV 1/5 by fokkeRC
Old 08-26-2016, 12:57 AM
  #326
Brad330l
Brad330l's Avatar
Originally Posted by fokke
WOW Brad , I am very glad to hear you again !!!
it would be great if you send me some info
Actually do not have on the market any spinners for MK 14 , so I need to make my self
Goodness mate where did you get that from???? That looks like a real, real one!!!!
Yes I will drag out the plans and copy for you.
Old 08-26-2016, 10:30 AM
  #327
fokke
fokke's Avatar
Brad , I have the right shape for the spinner and styart to make the plug for the mold
Old 08-26-2016, 05:57 PM
  #328
Brad330l
Brad330l's Avatar
Fabulous work fokke and I am following with interest as I will need to make a scale spinner for my Mk V Spitfire when I build it,,,,, after I finish your 109. (that I will not be able to continue with just yet)
I think you are now going to fill with foam and shape??
Old 08-26-2016, 09:58 PM
  #329
raaf
raaf's Avatar
hi fokke great work as always
when i order my spitty kit from you will spinners be available..
cheers shayne
Old 08-26-2016, 10:55 PM
  #330
fokke
fokke's Avatar
I wonder how to make the shape now, I can use foam , but have other methods, will see
Shayne, I plan to make the sminner after two weeeks , I will make just the composite part, I can't make the back plate ...
Cheers guys
Old 09-02-2016, 06:05 AM
  #331
fokke
fokke's Avatar
Hello again , some progress on MK 14 Spinner 1/5
Old 09-04-2016, 05:32 AM
  #332
shultz21
shultz21's Avatar
any insight on how she flies?
Old 09-04-2016, 09:37 AM
  #333
gilslo
Same question. Any vidéo?
Old 09-08-2016, 10:33 AM
  #334
FlyerInOKC
FlyerInOKC's Avatar
Rumen, what all is encluded with the Spitfire kit?
Mike
Old 09-08-2016, 10:57 AM
  #335
fokke
fokke's Avatar
Hi Mike
The kit include: Laser cut poplar plywood parts, composite cowl, lexan canopy, paper plans
http://www.fokkerc.com/index.php/woo...k-xiv/49-intro
Old 09-08-2016, 01:47 PM
  #336
shultz21
shultz21's Avatar
and how does it fly again...?
Old 09-17-2016, 10:15 AM
  #337
shultz21
shultz21's Avatar
are any of these kits flying? if so how do they fly?
Hi Mike
Old 09-19-2016, 01:26 AM
  #338
fokke
fokke's Avatar
The first model fly in France, Unfortunately I do not have more details ..
So I have several orders for bigger Spity , so I up the plans to 1/4 scale . One of my costumer want to use Kolm 150 cc, so I made the plans for this engine, off course can use other engines to
Here some pics , the first big kit will fly to Australia, so I hope the guy will post some details around the buiding proces
Old 09-19-2016, 12:11 PM
  #339
vik
vik's Avatar
Hi Rumen,
May I ask what laser CNC cutter do you use? I'm considering to get one for my glider projects.
Thank you
Vik
Old 09-19-2016, 12:20 PM
  #340
fokke
fokke's Avatar
Hi Vik
The laser machine is usual 100W laser hed 150 x 120sm work area
Old 09-19-2016, 12:35 PM
  #341
FlyerInOKC
FlyerInOKC's Avatar
Any chance you might drop that Spitfire down to 1/7th scale?
Old 09-19-2016, 12:42 PM
  #342
fokke
fokke's Avatar
Yes I can rebuld all details for 1.7 scale but like the bigger 1/4 I do not have composite sowl and canopy .
Before several months I made 1/5.5 scale , for this size I have composite cowl , the model is around 2 meters
Old 09-19-2016, 03:00 PM
  #343
shultz21
shultz21's Avatar
staying tuned in for details...
Old 09-21-2016, 05:07 AM
  #344
fokke
fokke's Avatar
i guys , here is the result on 1/4 Spitfire MK XIV E version by fokkerc.com
Old 09-21-2016, 05:13 AM
  #345
FlyerInOKC
FlyerInOKC's Avatar
Nice!
Old 09-21-2016, 09:20 AM
  #346
pheasant75
I second the 1/7th scale, I'm sure a canopy from another manufacturer could be made to fit.
Josh
Old 09-21-2016, 09:23 AM
  #347
FlyerInOKC
FlyerInOKC's Avatar
Josh, it sounds like you have the same transportation and storage limitations I have.
Old 09-21-2016, 09:34 AM
  #348
fokke
fokke's Avatar
The problem in rescaling is not the stringers holes or other wood stuf, the problem is that I have to make the all molds for cowl and canopy......
Old 09-21-2016, 09:54 AM
  #349
FlyerInOKC
FlyerInOKC's Avatar
If you scaled to the same size as an existing kit like Top Flite or the old Royal/Marutaka then you could put out the short kit and plans and the buyer could order the cowling and canopy from another source whether it be Top Flite or Fiberglass Specialties who makes cowling to fit both the Top Flite design and the Royal/Marutaka and the canopy to fit the Royal/Marutaka..
Old 09-21-2016, 10:03 AM
  #350
fokke
fokke's Avatar
Yes, for the Canopy can be done, but for the cowl I can;t make it because the shape of formers of the fuselage is probably different from other companies , So I can make make the cowl by wood ribs and stringers , and make 1/6 and 1/7 scale , then the guys have to buy just canopies
