Reload this Page >
Spitfire Mk XIV 1/5 by fokkeRC
Old 08-23-2014, 10:45 PM
  #151
fokke
fokke's Avatar
Hi Roger
Yes I have 2 degrees down like the real airplane. I recommend and 1-1.5 degrees to the right due to the gyroscopic moment of the propeller.
Old 08-24-2014, 12:41 AM
  #152
perttime
perttime's Avatar
Some pretty good Griffon powered Spitfire and Seafire scale drawings state 2.5 degrees down thrust from fuselage datum - and tailplane at zero. But I also have a Spiteful general arrangement image that says 2 degrees down thrust. Same drawings show +2 degrees of wing incidence at root and -0.5 degrees at tip.
Old 08-24-2014, 12:58 AM
  #153
fokke
fokke's Avatar
Yes, on my plans I have 2 degrees
Old 08-24-2014, 01:48 AM
  #154
perttime
perttime's Avatar
Your drawings look like they'd be from the original source of Spitfires and Seafires - so you are probably correct. I don't think my eyes would detect a 1/2 degree deviation in a finished model ...
Old 08-24-2014, 11:53 PM
  #155
w1nd6urfa
w1nd6urfa's Avatar
I think this washout is important, as I wrote earlier in post #124
Otherwise the elliptical wing has a tendency to tip stall or in the best case stall all at once
On the other hand if one builds this Spit at a low wing loading then the stall speed will be too low to matter
Old 08-26-2014, 04:15 AM
  #156
fokke
fokke's Avatar
I fnish with the canopy plug , next step is molding :
Old 08-28-2014, 12:41 AM
  #157
fokke
fokke's Avatar
Originally Posted by CDB-RAE
hi
perfect. i ve got a question can u modify the firewall position. i need 220mm from the firewall to the spinner with my engine?
Hi again Fafa
I have questions from other guys to , so I will change the first rib . This idea is to put bigger engines , so your engines with 22sm long you can put in the cowl
I will post pictures woth the result !
Old 08-28-2014, 12:49 AM
  #158
CDB-RAE
hello again
that very kind of u
yes 222mm should be perfect u can find the drawing with exact dimension on the roto engine web site i will try to send them if i can not at home right now
thanks
best regards
fafa
Old 08-28-2014, 05:26 AM
  #159
fokke
fokke's Avatar
OK Fafa, I will make the distance 230mm , when I am ready I will write here
I am ready with the cowl , this is it :
Old 08-29-2014, 07:17 AM
  #160
fokke
fokke's Avatar
The second canopy is ready for molding
Old 08-29-2014, 11:02 AM
  #161
Chris Nicastro
Chris Nicastro's Avatar
Those are great drawings, how did you find them?
Old 08-30-2014, 05:15 AM
  #162
fokke
fokke's Avatar
Hi Chris
I am a collector of drawings, some of them I bought, others are my gift from my friends.
Old 08-30-2014, 06:32 AM
  #163
fokke
fokke's Avatar
The molding process
Old 08-30-2014, 08:37 AM
  #164
fokke
fokke's Avatar
Old 09-02-2014, 05:26 AM
  #165
fokke
fokke's Avatar
Hi again guys
This is it, all molds are redy for work with lexan
Old 09-02-2014, 06:57 PM
  #166
Chris Nicastro
Are you vacuum forming into the mold halves or making a new tool?
When I make car body tools or other parts I make the tool from aluminum filled epoxy cast into a mold from the master model. That handles the temps and cycles very well. How are you making your canopy tools?
Old 09-03-2014, 01:57 AM
  #167
fokke
fokke's Avatar
HI
Yes the white details are positive molds for vacuum forming . I made them from polyester resin.
My idea is to make two types canopies, with epoxy frame and without frame
Old 09-03-2014, 05:42 AM
  #168
fokke
fokke's Avatar
Hi Fafa , I made the changes as you and several guys wanted
Old 09-03-2014, 10:03 PM
  #169
CDB-RAE
hello
super thanks very much very nice job
this nice bird must fly with a 4 stroke engine
fafa
Old 09-05-2014, 08:07 AM
  #170
fokke
fokke's Avatar
Hi Guys , some progress with the Germany model
Old 09-06-2014, 05:51 PM
  #171
DLEVETT
My Feedback: (13)
What an absolutely stunning Spitfire!
Great job on the design work Fokke.
I will be in touch with respect to ordering one from you.
Dave
Old 09-08-2014, 11:45 AM
  #172
77chickenhawk
77chickenhawk's Avatar
Awesome
Old 09-09-2014, 05:31 AM
  #173
fokke
fokke's Avatar
Thank you very much guys !
Old 09-10-2014, 05:37 AM
  #174
fokke
fokke's Avatar
Hi guy , here the result of my long work I hope to like it :
Old 09-10-2014, 08:24 AM
  #175
CDB-RAE
hello
fantastic tell me when u can send me this wonderful bird
best regards
fafa
