Reload this Page >
NEED HELP - Which warbird to choose P51 Mustang or P40 Warhark?
Reply
Old 05-07-2014, 08:54 AM
DaleD
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default NEED HELP - Which warbird to choose P51 Mustang or P40 Warhark?
Been in the hobby since 2007 and since then have had a burning desire to own a warbird. Fell in love with the P51 Mustang first but later developed just about same interest in P40 Warhawk. I would like the community's help in deciding on which model to get as I would not consider myself a diehard warbird modeler.
I would like to know which of the two models would posess better fliying characteristics for someone who really is more into precision flying but at the same time would love to fulfill a desire. I would also appreciate recommendations as to which ARF brand in the 30cc to 50/60cc size come out the box with highest build quality and manners in flight.
DaleD
DaleD is offline
Old 05-07-2014, 11:44 AM
Hot Rod Todd
Hot Rod Todd's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Without consideration to the brand, the P-51 will typically fly a bit better and have better ground handling. P40's (unless it's the later models like the P40N) are a bit short compared to the P-51. The ground handling for the Mustang will also be quite a bit better since the P-40 has quite a bit narrower stance making it more prone to ground loops. The rotating retracts are always more problematic than the standard type as well. As an example, the Top Flite P-51 will be quite a bit easier to handle than the Top Flite P-40 (Giant scale). I can't comment on the build quality of the Top Flite P-40. The P-51 ARF is a bit older than some of the others such as the Spitfire or FW-190, but that also means there is a ton of information out there to help you get it right the first time.
Lots of people like Mustangs, but often build something else to be a bit different. There are lots of Mustangs at every event you go to for a good reason, they look good, fly good, and ground handle as good as about anything except a P47.
Hot Rod Todd is offline
Old 05-07-2014, 11:55 AM
DaleD
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Appreciate your help Todd. Based on what you have shared, the decision between P51 and P40 is pretty straight forward. While I feel pretty sure the P51 will be in my hanger in the future, I am curious as to why you mentioned the P47 as an exception.
DaleD
DaleD is offline
Old 05-07-2014, 12:06 PM
Hot Rod Todd
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The Wide and low stance of the P-47 makes it about the easiest ground handling WW2 Warbird. They also seem to fly well and the wing shape typically provides a good amount of wing area. One of the most popular kits (and ARF's) is the P-47. It's not as pretty as the P-51, but it's pretty much common knowlege that the P-47 makes for a good handling warbird. If I had to rank the popular WW2 fighters for how easy they are to fly/ground handle, here would be my list (some may move them around a bit, but it shouldn't be too far off).
Easiest to hardest, and why: 1. P47: Wide and low stance makes it a good ground handler. 2. P-51: Wide stance, good flying characteristics, easy to balance. 3. Zero: Good stance, good flyer (if you don't add too much weight to balance). 4. Spitfire: A bit narrow stance, but great flying characteristics 5. F4U Corsair: Rotating retracts, Rudder a bit small, but the low stance makes it handle OK on the ground. 6. T-6 Texan: I know, it's a trainer. But the flying characteristics are not good. Handles OK on the ground though. 7. FW-190: Wide stance, good flyer, but if you have the mains the scale height it can be tall and prone to have gear issues. 8. P40: Narrow stance rotating gear, short tail moment, If you built the longer N model, it would not be so bad, but most are the shorter E version. 9. BF-109. Tall narrow gear, small rudder. Flys good, but not easy to handle on the ground.
That's the popular models. Didn't include the twins like the P38 (nasty with one engine) or the Mosquito (nasty on the ground, and nasty with one engine).
Last edited by Hot Rod Todd; 05-07-2014 at 12:19 PM. Reason: forgot rest of message.
Old 05-07-2014, 12:33 PM
DaleD
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Todd, you have provided more then enough information to aid in my decision. I will be giving the P47 a second and third look. Right now that big round cowl isn't making my skin itch; will try and find a few videos to watch and see if interest will grow.
As I am right now looking seriously at the P51, I just need help from experienced flyers and builders as to which ARF kit would be most highly recommended. I have read about the Aeroworks, TopFlight, ESM and I know Hanger 9 just released a new 60cc size kit. Any other ARF kits not mentioned worthy of consideration?
DaleD
DaleD is offline
Old 05-07-2014, 12:46 PM
Hot Rod Todd
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That sounds like the main choices. The top flite is innexpesive and has been around a long time. The new Hanger 9 is pricey, we'll have to see how good it is once they get them flying. Good luck.
Old 05-07-2014, 01:28 PM
aghost
My Feedback: (13)
aghost's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
+1 on Hot Rod Todd's comments. In addition the P-47 with the big round cowl generally takes less cowl cutting for the engine installation. As compared to the relatively narrow cowl on the P-51 (and P-40). Probably not something to hang your decision on at this point though.
Brian
aghost is offline
Old 05-07-2014, 01:29 PM
LA7flier
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Agree with the summary regarding the P 47 as the easiest in flight and on the ground....also easier to hide a gasser in....P 51 is nice but can bite if slowed down too much...also, the in-line lends itself to e-power....my experience with the ARFs I have purchased is they are all under built with cheaper materials. I prefer to build kits and scratch build my own but I understand that the vast majority of sales is going to ARF's...Top Flight is a recognized name and one I would consider
LA7flier is offline
Old 05-07-2014, 01:56 PM
Peter_OZ
Banned
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Have flown both.
P40
- poor ground handing, requires experienced pilot in use of co-ordinated rudder, elevator and throttle.
- tendency to snap from high speed stalls
- will tip stall
- CG issues, due to 90 degree rotating retracts
- lands quite well but do not get slow or it will tip stall, must be wheeled on
- large opening and exit area for engine cooling. Easy to fit a good sized engine within the cowl
P51
- very forgiving, even with CG incorrect - found that out the hard way!
- wide track undercarriage makes for easy ground handling and easier take off.
- narrow nose, makes engine choice and fitting tough
- cooling of engine is difficult, similar to a Spitfire in this regard
- lands nicely and can be slowed but still likes to be wheeled on.
just a few thoughts.
Cavet Venditor!!
Peter_OZ is offline
Old 05-08-2014, 02:07 AM
Lifer
Lifer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Add my recommendations for the P-47 as your first effort. Best flying/ground handling qualities of the three.
Lifer is online now
Old 05-08-2014, 03:53 AM
willig10
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Go get yourself a Top Flight Giant scale or 60 size P-47. You will not be disappointed.
Glenn
willig10 is offline
Old 05-08-2014, 05:44 AM
charlie1960
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Cool
The OP stated a desire for a P-51 or a P-40.
And seems most everyone is trying to persuade him into a P-47.
All the facts being equal, a P-47 would handle somewhat better on the ground, does fly well,
but his interest is in one of the other two planes.
My 2 cents, is build the plane that will make you happy. That being said. Look at The World Models GS P-51s.
No one has mentioned them. I owned a 60 sized Mustang and it was solidly built and flew very well. This being your first foray into
warbirddom, there will be charaterists of warbirds you may or may not be aware of. How ever you go with this, i would hope you
seek the wisdom and advise of a local warbirder. Personaly i love warbirds.
There are Warbirds, and then there are Targets.
There are Mustangs, and then there are Targets......
charlie1960 is offline
Old 05-08-2014, 07:24 AM
raptureboy
raptureboy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My first was the jug and she was a sweatheart. I agree with all the above comments and I have both the 51 and the 40 and for me the biggest drawback on the 40 is the rotating gear. If you go for that then get the Sierra Giant gear, well worth the money.
raptureboy is offline
Old 05-08-2014, 08:25 AM
Scar
Scar's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Guys, guys,
You know he wants one of each! Dale, just do it!
Oh, and my favorite so far is my Meister Corsair. I don't fly it for speed, but it will do all the loops, rolls, four point rolls, etc. that I want, with a big grin on my face.
Dave Olson
Scar is offline
Old 05-08-2014, 09:30 AM
Lifer
Lifer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
True. Buy all three. Start with the Jug, then the "Stang, and finish with the Warhawk. Life is wayyy too short to deny yourself at this point!
Above all, have fun.
Lifer is online now
Old 05-08-2014, 10:43 AM
charlie1960
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Right on Dave. I like flying in a "less powerful manner" myself. And i agree with Rapture, good retracts are a must on a big warbird. (any plane for that matter)
Nothing will make a lousy day flying, faster than junk retracts.
Just wait......you'll never get finished.....theres the retracting tailwheel mod.
the sliding canopy mod
the fuctioning radiator door mod (mustang)
the navigation lights mod
the landing lights mod
the scale main landing gear and wheels mod
the scale cockpit with pilot mod
the scale fuctioning exhaust mod
the functioning cowl flap mod (p-47 and f4u)
the drop tank mod
the fighter group specific paint and scheme mod
IT GOES ON AND ON...
Old 05-08-2014, 10:56 AM
charlie1960
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
currently building an ESM 72 inch D model mustang
Old 05-08-2014, 11:27 AM
DaleD
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
WOW!!!!!
I can feel the passion for warbirds from all your feedback. Thanks for taking the time to share your experience and insights. As of now, I am set on the P51 Mustang and now must decide on which kit to buy. Somehow I have a funny feeling that shortly after the P51 a P40 will become an object of serious desire and contemplation. I have a serious weakness for model planes and tend to hang on to every model purchased. Seriously growing out of storage space right now. Last time I counted there are 10 models, two of which are yet to be assembled.
I will most likely delay the purchase until after I read feedback on the new H9 60cc P51. The Topflight seems to be the pick of the litter; it is very its popularity for many reasons and good build quality and flight characteristics seems to be among them. If the Hanger9 fails to impress this is definitely what I will be getting.
Please keep the information coming.
DaleD
DaleD is offline
Old 05-08-2014, 02:11 PM
prop wash
prop wash's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dale my fav is the TFGS Mustang,very well built and performs great.My next one is the H9 P47 razorback.My new addition is the TFGS F4U.Very nice and well built.I have not flown it yet so I'll let you know.Both my mustangs and thjug have Moki 210's and a Moki180[jug].The Moki's in the51's don't have the cowls all chopped up with carbs and all sticking out.The F4U has my first gasser in it[DLA 58cc].
As you can tell I too love war birds.Go with Top Flite.
Name:	two P51's and a Jug.jpg
ID:	1993589   Click image for larger version
ID:	1993590   Click image for larger version
prop wash is offline
Old 05-08-2014, 03:08 PM
wnewbury
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Top Flite P39 flew pretty well and the ground handling was no problem. I liked flying the Top Flite P47 a lot. (Both .60 size)
wnewbury is offline
Old 05-08-2014, 08:08 PM
jeffk464
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
190D-9's multiply everything he said about the mustang times 2 plus when you go to the field you wont be 1 of 10 mustangs.
jeffk464 is offline
Old 05-09-2014, 05:39 AM
karolh
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Some advise from your pardie, just say enie, menie, minie, moe, but make sure that moe falls on the P51
karolh is offline
Old 05-09-2014, 05:43 AM
cloudancer03
My Feedback: (22)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I built and flew a p 51 and it flew well but the the p47 is much easier.and the p40 I have had that much interest in. A mustang is like a cub .everyone wants it at some point.as the guy said life is to dang short.go buy the p51 and p47.and have a ball.go with top flite or horizon.you wont be disappointed!
cloudancer03 is offline
Old 05-09-2014, 06:01 AM
charlie1960
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I've always loved a P-51. Used to watch them fly over when i was a little tike.
Back when Ellington AFB was still Ellington AFB.
Back in the day...when you could sit at the end of the runway at Hobby Airport, on the hood of a 1964 Ford Falcon
station wagon, sucking on a pepsi cola (in a BOTTLE by golly) with peanuts in it,and not get ran off by the cops.
Old 05-09-2014, 07:20 AM
steph69
steph69's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
no you want the topflite fw-190 GS, awesome flying plane.
steph69 is offline
