Reload this Page >
Need help with 4 stroke throttle linkage for a 65" Spitfire
Old 07-08-2014, 03:55 AM
Bonified Wingnut
Bonified Wingnut's Avatar
Default Need help with 4 stroke throttle linkage for a 65" Spitfire
I have this Spitfire of which I have no idea who the kit manufacturer was but it isn't relevant. I have to figure out a way to connect the throttle linkage. The fuel tank seems to be in the way if I move it to where I would like it. I prefer not to use a smaller tank. The engine is a 90 and the tank is a 10 oz.
Any Ideas?
Thanks in advance.
ID:	2012551   Click image for larger version
ID:	2012552   Click image for larger version
ID:	2012553   Click image for larger version
ID:	2012554   Click image for larger version
ID:	2012555   Click image for larger version
ID:	2012556   Click image for larger version
Old 07-08-2014, 08:49 PM
ho2zoo
Looks like a Pica Spitfire. I have one- great flying plane! Mine has a .91 four stroke, but the throttle arm is on the other side of the carb. That's a tough one there. Can you bend the throttle into a 'U' shape to come around and connect to the throttle arm? Or maybe you could build some kind of 'rocker arm' to connect between the pushrod and the arm? Like a see-saw with a pivot in the middle?
Old 07-08-2014, 10:05 PM
warbird lover
Tower Hobbies has a Dubro 4-stroke linkage kit stock number LXD 939
that I have used for a Saito 150. Tried to post a picture of my setup but couldn,t
upload.
Old 07-08-2014, 10:25 PM
warbird lover
Default Picture of 4-stroke linkage
Name:	saito throttle linkage hookup.jpg
Old 07-09-2014, 03:31 AM
Bonified Wingnut
ho2zoo did you have to cut much to get it to fit the engine mounts? Do you have any pictures? Warbird lover thanks I might give that a try.
Old 07-09-2014, 03:46 AM
Bonified Wingnut
ho2zoo I think you solved my problem. You got me thinking about the carb and if I could reverse it. Sure enough it can be. Now the throttle cable is where I can reach it. I will just move the servos. I am not sure if I did it or it came like that. I would love to know more about your Pica Spitfire. I was leaning towards mine being one. How much does yours weigh and where is your CG?
Old 07-09-2014, 08:48 PM
ho2zoo
Glad I could help. That Du-Bro linkage that warbird-lover showed is a neat solution too. Give me a day or two to get my Spitfire out and take some pics. Mine has an older OS Surpass II four-stroke ( the plane is about 18 years old! ). I think the engine dropped in pretty easy without too much trimming. I balanced it according to the plans and I think I still have them, so I'll have to dig them out to see where the CG is. I modified mine to have flaps and I was so glad I did. Made landings so much easier! I just cut away the sheeting on the bottom of the wing and hinged 2 thin plywood flaps to work on a single servo in the center. Used a semi-flexible cable pushrod in a plastic sleeve.
I'll be back with the pics.
Old 07-11-2014, 03:56 PM
ho2zoo
Here are some pics. I have to take the spinner, prop, and exhaust off to get into the cowl.
ID:	2013469   Click image for larger version
Old 07-11-2014, 04:02 PM
ho2zoo
Default More Spifire pics
The red wire going to the plug is a home-made glow driver. I had one dead-stick landing and that was enough! There is a cam cut into the throttle servo wheel that pushes on a switch to turn on the power to the glow plug.
ID:	2013471   Click image for larger version
Old 07-11-2014, 04:05 PM
Bonified Wingnut
Thanks ho2zoo. What are you using for the bolts? Do you have blind nuts in there?
Old 07-11-2014, 04:07 PM
ho2zoo
According to my plans, the CG for the Pica Spitfire is 4 1/4 to 4 1/2 inches from the leading edge.
ID:	2013473   Click image for larger version
Old 07-11-2014, 04:14 PM
ho2zoo
Default How about the flaps?
The stock 65" Spitfire didn't come with flaps, but after talking to a couple guys I decided to modify it to have them.
The flap servo is in the center of the wing (the one on the right, the other is for the retracts). I mounted the aileron servos out in the wing to drive each aileron directly.
ID:	2013475   Click image for larger version
ID:	2013476   Click image for larger version
ID:	2013477   Click image for larger version
Old 07-11-2014, 04:20 PM
Bonified Wingnut
The mounts in mine were spaced for a 40 size engine. I had to cut away quit a bit of wood creating another problem for me. Whoever built it did a really nice job.
ID:	2013479   Click image for larger version
ID:	2013480   Click image for larger version
ID:	2013481   Click image for larger version
ID:	2013482   Click image for larger version
Old 07-11-2014, 04:21 PM
ho2zoo
The nylon wing bolts screw into a hardwood block that is epoxied into the fuselage. The holes are tapped- no blind nut is necessary (although I suppose it wouldn't hurt).
Old 07-11-2014, 04:26 PM
Bonified Wingnut
It seems that it will have a light wing loading. Do you feel the flaps helped landings? I removed air retracts and I am replacing them with electrics.
Old 07-11-2014, 04:27 PM
Bonified Wingnut
I meant the engine bolts.
Old 07-11-2014, 04:28 PM
ho2zoo
That's a good looking plane! I can't imagine trying to fly it with a .40! It was designed for a .60 (at least).
I have not weighed mine, but it is pretty light- maybe around 9 or 10 lbs.
Old 07-11-2014, 04:33 PM
ho2zoo
Oh, of course. Mine has wood screws about 3/4 inch I think. I screwed them in, then backed them out, put CA down the hole and quickly screwed them back in. I would check them every dozen flights or so to tighten them up, but it worked pretty well.
Old 07-11-2014, 04:37 PM
ho2zoo
The flaps helped a lot. The first few flights I was afraid to use them (first plane with flaps) and I would have to land it pretty hot. But I tried them and found the landings a lot easier and more stable. But I understand that you may not want to cut into a wing that is already built.
Old 07-11-2014, 04:51 PM
Bonified Wingnut
Wood screws? Awesome I can move forward. I already ca'd the holes. I am at 7 lbs 14 oz. with everything except RX and battery. Ishould be about 8 1/2 plus fuel.
Old 08-17-2014, 03:39 PM
Bonified Wingnut
ho2zoo
you don't have the control throws for that do you? Thanks for all the help.
Old 08-18-2014, 06:51 AM
ho2zoo
Yup.
From the plans; Ailerons 1/2" up 3/8" down. Elevator 3/8" up and down. Rudder 2 3/8" left and right. The elevator and rudder weren't written on the plans- I measured them with a ruler. I always noticed when taxiing out that there was not much elevator throw. Plane simply would not taxi in the grass. Flew great though!
