Reload this Page >
Preparation for painting monocote on a Warbird
Old 07-22-2014, 03:34 PM
Check6
My Feedback: (427)
Default Preparation for painting monocote on a Warbird
I'll be picking up a nice Corsair, that is covered in monocote. Eventually I will strip it and glass it but for now I would like to paint it. What's a good prep for it and would latex paint adhere to the surface. I'm thinking a good cleaning with lacquer thinner then a thorough scuffing and cleaning again. Prime and paint. Any other suggestions??
Fred
Old 07-22-2014, 05:50 PM
BobH
One of my buddies sprayed paint adhesion on the monokote first. He painted a TF Giant FW190 and it looks really great!!
Old 07-22-2014, 06:05 PM
Warbird Man
My Feedback: (95)
Warbird Man's Avatar
This one was painted with model masters FS Intermediate blue on the sides and std. painters touch white underneath. I lightly scuffed the "painted" areas on the monokote with a light scotchbrite pad and cleaned with alcohol. "No primer" You want to spray the paint on as light as possible. Just enough to cover the color well so it can expand and contract with the monokote.
If you put it on too thick, you'll end up with it cracking and peeling. Make sure the monokote is tight and adhered well.
Old 07-22-2014, 06:46 PM
radfordc
My Feedback: (14)
radfordc's Avatar
I haven't tried it on Monokote, but Krylon Fusion sticks to other plastics very well.
Old 07-23-2014, 04:00 AM
irocbsa
My Feedback: (12)
irocbsa's Avatar
Paint it first with a plastic primer and then with a top coat that is specified for use on plastic. These paints have a lot of additives in them that make it more flexible.
Old 07-23-2014, 04:22 AM
70 ragtop
My Feedback: (24)
Scuff it up with red scotch bright until the shininess is gone. Wipe it down with alcohol, and don't put too much paint on it. Try to keep the paint as thin as possible.
Old 07-23-2014, 10:20 AM
Check6
My Feedback: (427)
Thanks for the tips. Do you think latex would work on this or will it peel off in one sheet?
Old 07-23-2014, 11:04 AM
radfordc
My Feedback: (14)
radfordc's Avatar
Latex won't stick to plastic. But, if you use a good plastic primer the latex will stick to that. I recently painted a plastic "tupperware-like" bowl using Fusion as the primer coat and latex on top of that and it worked well.
Old 07-23-2014, 08:03 PM
w1nd6urfa
w1nd6urfa's Avatar
+1
Primer is the secret for long lasting paint job on film covering, i use auto primer for plastic bumpers (transparent)
For paints I use good quality modelling acrylics such as Testors, Gunze Mr Hobby, Tamiya. They are made for plastic models and in general the warbird paints are spot on, no need to mix and match
Old 07-23-2014, 08:18 PM
w1nd6urfa
w1nd6urfa's Avatar
And this is what happens if you DONT use the correct primer
See the bottom part of the white "S" on the wing where the paint lifted with the mask revealing the black monokote:
