Which electric retracts for an ESM Dauntless ?
I've had an ESM Dauntless kit for a few years now, it will have a full cockpit and at one time I was going to use Sierra air retracts but have since had a change of mind.
Would like to go electric and eliminate all the plumbing and air tank since the plane will be electric powered also. Have been looking around at ESM,E-Flite and Lado.
since I fly off a grass fields would like to use functioning oleo struts instead of just wire struts. Sierra doesn't sell their struts separately so at this point I am leaning towards
the Lado 90 degree RS 333 but not sure what to use for struts. I liked the sierras as they had the scale axle angle thinking I may be able to modify Lado struts to the same.
Am open to recommendations or ideas.Thanks
I contacted Lado one time about struts for the RS999 retract. Lado does make custom length struts. I would imagine that they can also drill any axle angle on the strut. I don't know about custom scale appearance. Lado answers emails sent during the week very quickly.
I purchased Lado RS999 retracts but haven't used them yet. I already had some Shindin struts for an 84" span ME-109 that are a good fit by length and axle angle for the American Eagle Typhoon that I am building. It is going to be flown as a sport plane.
Here is a link to the RS333 struts offered.
http://www.lado-tech.net/en/accessor...s333-legs.html
Brian
Brian
My Feedback: (53)
I was very disappointed in Lado.............not enough power to move Heavy Duty ( 1/5 scale) retracts. Almost all retract makers have a electric conversion. I believe the Down and Locked will convert and air set to electric.
Lado offers complete retracts and just actuators of different sizes that can handle different strut lengths and wheel weights. Lado also has dimensions of the actuators to download from their site. In the video on the page below, he gives the strut length and wheel weight being used with the example retract. The torque supported in the demonstration can be calculated by the strut length times the wheel weight. A torque comparison for another airplane can then be calculating using the strut length and wheel weight for it. Lado offers three different actuator sizes.
http://www.lado-tech.net/en/rs666/86-rs666-jumbo.html
Brian
Brian
