.26 Four-Stroke or .25 Two-Stroke
My Feedback: (12)
Hi All. I have a Hobby Hanger OV-10 Bronco (52") and am interested in opinions/suggestions. Do I go with two OS 26 four-stroke engines or 2- .25 (or so) engines. The kit minimum engine size is stated as a .20. I am not looking for 3-D performance, more scale appearance in flight. I lean more toward the four-strokes, but give me your opinion and reasons for your choice.The Bronco will be done up in a US Marine finish, as I am a former Marine.
On one hand, 2 .25 engines would be the cheap way out. They would provide more power (?) and pull more RPMs. On the other, the .26's may sound better and swing a bigger prop I plan on using 3-blade props for a more scale look. I know when using a 3-blade prop you have to go down in size and pitch. But I'[m wondering if a 4-stroke's ability to swing a larger prop may cancel out having to use a smaller prop.
The plane is not built yet, but I may post a build. We'll see. Thanks in advance for any thoughts.
If you go with the 4-strokes, I would add on board glow for reliability. I have a Saito .30. They also make a Saito .40 that was in the same sized case, The .30 is the same size as the OS .26. Also, way back in the day, when I flew combat, there were guys running the OS .26 with the RC car .26 cam. This gave them a bunch more power. It was just a drop in part.
Of course, the .25 FX is one of the best small 2-stroke engines ever made. It would be the most reliable and the best runner of them all I believe. It it were me, I would go with the .25 FX or maybe the Magnum .25 SLX, which is a clone, and is the engine of choice of the combat fliers now. They are cheaper and just as good. Check Hobby people for pricing.
My Feedback: (12)
pkoury and vertical grimace, thanks. As far as pipes are concerned, don't they provide the most power only at a particular setting? I was thinking of an OS .25 but will look into the Magnum. Another reason I was thinking 4-strokes is that it is easier to hide the exhaust.
As far as the mousse cans and Jett mufflers go though, They will get your .25 up to 19,000 rpm, with the right 9-4 prop. Most used Master airscrew black props. The engine must be allowed to turn up rpm to get on the can. So a reduction in prop load is needed.
My recommendation: Run a stock OS .25 FX with the black Macs mufflers. THey are one piece, and have a low profile so will be unobtrusive to the looks of your scale model. The engine will want 9-5 APC props and they should spin around 16,000 rpm. This is a great set up. Very reliable. In fact I am scratch building a sport twin model right now with just these engines. A Dick Sarpolus 50 Caliber. Looks like a Kaos with 2 engines. It is a practice plane to help me get my feet wet with twins as I have never built/flown one. My goal is a larger German heavy twin fighter.
