Ziroli 92" p-47 build thread
Reply
Old 09-04-2019, 07:26 AM
  #226
samparfitt
My Feedback: (43)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
White nav light.
I forgot to allow for the nav light wires when building the rudder but a long 3/16" drill bit worked well. Some outside Sullivan tubing for wire guides and a little CA did the 'trick'.
Since they are smaller, I used some of my railroad connectors. Robart pocket hinges made it easy for the nav install.
Two white lights came off this extension. Will try to run the spare LED into the cockpit for instruments.
samparfitt is offline
Old 09-04-2019, 08:57 AM
  #227
FlyerInOKC
FlyerInOKC's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nice setup on the Nav light!
FlyerInOKC is offline
Old 09-04-2019, 11:44 AM
  #228
samparfitt
My Feedback: (43)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks, flyerinokc
Bummer. Thought I had stars-n-stripes in stock but the shelf was bare.
Just ordered from Major decal. Water transfer. They only take checks/MO so it'll be a few weeks.
Major Decals - Industrial Etching, Inc. / Northeast Screen Graphics - Manufacturers of Fine Etched and Silk Screen Printed Products
Old 09-04-2019, 01:42 PM
  #229
edp
edp's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Paint them, Ziroli 72" version. KlassKote w/ dead flat additive. I used silver ultracote sanded at different angles for covering and the paint sticks very well. I've been following this build as I like the bigger version.
edp is offline
Old 09-04-2019, 01:56 PM
  #230
samparfitt
My Feedback: (43)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I can't paint as well as these water transfer decals (I would get bleeding) are and they are so thin that the rivets show through them. And for 29 bucks a set, I can't go wrong!
Old 09-05-2019, 06:01 AM
  #231
edp
edp's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Fair enough, I have two vinyl cutters that I cut masks with. Your was IS much faster. I'll spend an hour to mask, three minutes to shoot and another half hour to unmask.
Your bird is looking good.
Ed
edp is offline
Old 09-05-2019, 07:53 AM
  #232
samparfitt
My Feedback: (43)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
In my book, you get more 'points' for painting them.
Stuff:
Doors back onl
Adding nomenclature.
Using Promark 'dry rub ons'.
Comes with extra sheet indicating where nomenclature is located on the plane.
I always tape them so I can put the 'rub on' back in its exact position, in case I don't thoroughly get the lettering attached to the plane's surface.
I use my heat gun to activate the 'rub on' and then use a 'stump applicator' and/or popsicle stick to rub the nomenclature to the surface.
Five nomenclatures in this picture.
Old 09-05-2019, 12:05 PM
  #233
samparfitt
My Feedback: (43)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nomenclature (cont)
Did the other side of the fuse. I remember the maker of these said it's best to use them soon after they are made. The sheets I have are several years old and some of the red square stuck to the under liner sheet. I'll just have it as 'weathering'.
Old 09-08-2019, 06:55 AM
  #234
samparfitt
My Feedback: (43)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Cockpit kit from D-balsa (cont)
Got a few things done.
I find using my sanding belt is easiest for removing the back of the plastic on the front console. The edges melt and then I pop them out.
Printed and sealed gauges glued to console with caulk.
Got the throttle quad and left electrical control panel installed. Screwed them to the side panel from the back side.
Throttle quad:
Drilled small holes in the slots and CA'ed some straight pins in the holes.
Drilled an 1/8" diameter hole for the dial.
Electrical panel:
Drilled 1/16" holes where all the toggle recesses are and installed some aluminum wire in the 10 holes after bending them 45 degrees.
Also used extra LED's from the nav lights and installed one in the electrical side panel.
Old 09-09-2019, 03:35 PM
  #235
samparfitt
My Feedback: (43)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Cockpit kit (cont)
Assembled the 'adjustable seat', gun site, armor plate and paint a few parts.
Drilled out the gun site and installed an LED inside it. Also, put a red LED on the dash.
Dry fit.
dry fit seat and armor plating.
Old 09-10-2019, 05:22 AM
  #236
FlyerInOKC
FlyerInOKC's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It so close to the real thing it could trigger the PTSD in a WWII veteran P-47 pilot!
Old 09-10-2019, 10:21 AM
  #237
samparfitt
My Feedback: (43)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Cockpit kit (cont)
done
White LED in gun site and red LED on dash.
right side:
mmm: needs a few 'touch ups'.
Left side.
Mr Doolittle.
Canopy back on the plane.
Old 09-10-2019, 07:43 PM
  #238
heirmeistr
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Where did you get the water slide decals from? And I like your idea of the light plastic over the pull-pull cables.
heirmeistr is offline
Old 09-10-2019, 07:48 PM
  #239
FlyerInOKC
FlyerInOKC's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here is a preflight training video on the P47 to get you ready for the maiden flight.
P-47 Folly
Old 09-11-2019, 04:42 AM
  #240
samparfitt
My Feedback: (43)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Larry,
Major decals: Very thin and won't hide the rivet detail. I like the water transfer (WT) ones. No credit cards, takes a little longer as they wait until your check clears.
At the bottom of the web is the price listings along with a form to fill out and mail to them.
flyerinokc,
cool video.
Old 09-17-2019, 01:40 PM
  #241
samparfitt
My Feedback: (43)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Wing and tail feather protectors.
Some HD insulation sheeting, felt cloth, aluminum tape and 3M spray.
Tomorrow, go to JoAnn's fabric store for some more felt for the left wing.
