Reload this Page >
Topflite Giant P-47 Club
Old 08-22-2015, 12:22 PM
  #526
Chad Veich
My Feedback: (60)
Originally Posted by ccostant
My flying buddy just did a makeover on his TF Tarheel Hal and went with the Josephine My Flying Machine scheme. Such a small world.
In the background is my Hangar 9 P-47 made over into one of the Gabreiski schemes.
It appears from the picture that you only allow P-47's at your club field!
Old 08-22-2015, 08:42 PM
  #527
Prekin
My Feedback: (19)
Prekin's Avatar
Hi guys, I´m thinking about this Top Flite kit. Anybody know, where to buy razorback canopy and what is the average weight of this warbird?
Old 08-23-2015, 05:05 AM
  #528
TLH101
My Feedback: (90)
TLH101's Avatar
http://www.ebay.com/itm/391186724875...%3AMEBIDX%3AIT
Omni Models. They have everything you need and are a good trusted seller. Actually a lower price division of Tower Hobbies.
Old 08-25-2015, 05:46 AM
  #529
haefeli
haefeli's Avatar
Guys. I accidenty unsubscribed. I can't find the thread other than thru an old email I found. What do I do besides punt?
Old 08-25-2015, 07:11 AM
  #530
HoundDog
My Feedback: (49)
HoundDog's Avatar
I would that just by posting this message that U are re-subscribed.
Old 08-25-2015, 10:50 AM
  #531
TLH101
My Feedback: (90)
TLH101's Avatar
OK, I have started my electric conversion. Not sure what motor I will be using, or if I will be using 10s or 12s battery, so I am making room for either. These pics show how I made the front battery hatch. Should be plenty of room for all the needed "stuff" up front, and hopefully I won't need any ballast to balance. I will be extending the motor box a couple inches, so the batteries will be able to be even further forward if needed. Plan to have a tray to mount the batteries that will will slip in and out of the fuse, so I don't have to deal strapping the batteries down in the hole.
Hopefully these pics are self explanatory.
ID:	2116687   Click image for larger version
ID:	2116688   Click image for larger version
ID:	2116689   Click image for larger version
ID:	2116690   Click image for larger version
ID:	2116691   Click image for larger version
ID:	2116692   Click image for larger version
ID:	2116693   Click image for larger version
ID:	2116695   Click image for larger version
ID:	2116696   Click image for larger version
ID:	2116697   Click image for larger version
ID:	2116698   Click image for larger version
ID:	2116699   Click image for larger version
ID:	2116700   Click image for larger version
Old 08-25-2015, 11:46 AM
  #532
haefeli
haefeli's Avatar
as far as heat is concerned use Bob Violett ceramic based paint. as far as the engine running hot due to exhaust is due to too much back pressure and adjusting the mixture with a properly sized exhaust is not an issue. this is a DLE 55 RA that has compression raised and ported and the pipes are laid at different angles due to engine offset but come out properly located. I have not yet made my vents that will be attached with number 0 screws.
ID:	2116702   Click image for larger version
ID:	2116703   Click image for larger version
Old 08-26-2015, 11:40 AM
  #533
haefeli
haefeli's Avatar
For those interested I meant to say the pipes will be coated with the ceramic paint where it enters the fuselage and this will keep the heat internally in the pipe. I have many air vents and the rear edge of the aluminum plate has a 2 mm air gap to the former so it bleeds heat from that area also. if you go on Bob Violetts website you will see them use a propane torch on cardboard and it will not ignite. pretty cool stuff for 21 bucks delivered.no smell and water clean up. the jet guys use it on their fuselages with exhaust temps of 1000C.
Old 08-29-2015, 01:58 PM
  #534
TLH101
My Feedback: (90)
TLH101's Avatar
I just made a deal for a power system for my P-47 electric conversion. Will be using an E-Flite Power 360, with a Castle Creations 160A esc, and 12s battery. Will use 24x12, or 26x12 prop. Should be about the equivalent of a 60cc gasser.
Old 09-05-2015, 03:34 PM
  #535
WI53072
Guys, I just got my tower catalog and it seems to indicate that the new Top Flite Razorback is now I stock? Is that right?
Old 09-06-2015, 07:36 AM
  #536
TLH101
My Feedback: (90)
TLH101's Avatar
Tower website still says mid Sept.
Old 09-06-2015, 07:43 AM
  #537
TLH101
My Feedback: (90)
TLH101's Avatar
Received my motor, esc, and batteries this past week. Got a little more building done too. Hope to get a good bit more construction done this weekend.
That's 5 1/2 lbs of batteries under the hatch. Will have a lot of room to move forward or back as needed to balance.
ID:	2118288   Click image for larger version
ID:	2118289   Click image for larger version
ID:	2118290   Click image for larger version
ID:	2118292   Click image for larger version
ID:	2118293   Click image for larger version
ID:	2118294   Click image for larger version
ID:	2118295   Click image for larger version
ID:	2118297   Click image for larger version
ID:	2118298   Click image for larger version
ID:	2118299   Click image for larger version
ID:	2118300   Click image for larger version
Old 09-18-2015, 11:07 AM
  #538
redwingsfan71
Anyone know of a place I can go to see a build using scale retract installation/position?
Just curious...
Old 09-20-2015, 07:21 AM
  #539
captainron
captainron's Avatar
TLH101
I got my new Top Flite Razorback yerterday. My LHS ordered for me back in June. They are now in stock. I can tell you and all that are getting one.......THIS IS A BEAUTIFUL MODEL. Well packaged. I'm gonna save it for my winter project.
Captain Ron
Old 09-20-2015, 10:16 AM
  #540
Lifer
Lifer's Avatar
Pictures?
Old 09-20-2015, 10:40 AM
  #541
captainron
captainron's Avatar
LIfer,
I haven't unboxed her yet..........But here's a teaser............
Name:	new Razorback.jpeg
Old 09-20-2015, 11:19 AM
  #542
redwingsfan71
How difficult would it be to squeeze a DLE 85 in the cowl? I know guys do it, just wondering how it all fits.
Old 09-20-2015, 12:19 PM
  #543
Lifer
Lifer's Avatar
85cc engines tend to shake the airframe apart, at least according to several previous posters in P-47 threads. I think one of the 61cc engines would be a good choice. 10 percent bigger than a 55cc engine.
I wonder how I could justify a 3rd giant scale P-47 in my basement.........
Old 09-20-2015, 02:32 PM
  #544
captainron
captainron's Avatar
Lifer, No Worries mate, this will be my 4th GS P47. I'm gonna use the EME 60 with the electric start in mine. I like the EME over the DLE simply because the EME uses the Walbro carb and the DLE's use the Chinese carb that's not quite the quality and doesn't seem to perform as well.
Old 09-20-2015, 04:51 PM
  #545
bzyguy01
bzyguy01's Avatar
Captainron...Hurry up and get that bird down here to Phx! My Saito 60R3 is begging to be stuffed in the cowl.
Lifer...There's always room for another JUG!
Chad... Is there another bird to have besides a jug?? This makes what?....My eighth Jug in my fleet!
Old 09-20-2015, 05:30 PM
  #546
captainron
captainron's Avatar
Yes sir bzyguy we are working on it. The wife and I started reloading the coach for the winter trek to Phoenix just today. I can't wait to get down there and start my winter life with my boys. We hit the road on the 30th of Sept and we'll be on the desert floor on the 1st of Oct. 4 airplanes, all my gear and a black Acadia suv in a 24ft trailer................Ye Hah...!!!!
Captain Ron
Old 09-20-2015, 05:44 PM
  #547
Todd D
My Feedback: (51)
Todd D's Avatar
I'm wrestling with a similar dilemma, that being multiple giant scale P47's,I'm sure I'll figure something out.
Todd
Old 09-21-2015, 12:43 PM
  #548
SWORDSN
My Feedback: (13)
Originally Posted by captainron
LIfer,
Build thread ?
Old 09-21-2015, 12:51 PM
  #549
captainron
captainron's Avatar
SWORDSN,
Might possibly do a build thread. It would be my first one. Problem is, I don't work steady on a model. I might work like a dog for a week and then not touch it again for a month. I usually have two projects going at a time. We'll see, thjat might be fun. I'm gonna use her for a winter project.
Captain Ron
Old 09-21-2015, 01:10 PM
  #550
SWORDSN
My Feedback: (13)
SWORDSN,
Captain Ron
Cap,post when you can. I work slowly also.
