Reload this Page >
NEW TopFlite GS P-47 Razorback 2015
Old 03-01-2015, 06:08 AM
HoundDog
My Feedback: (49)
HoundDog's Avatar
Go Here if U wan't to know every thing about the History of the 15,660 Republic P-47 Thunder Bolts built. Very Interesting all the different Versions to the 3 different plants where they were built in.
http://en.wikipedia.org/wiki/Republic_P-47_Thunderbolt
[TABLE="class: infobox, width: 315"]
[TR]
[TD="colspan: 2, align: center"]P-47N flying over the Pacific during World War II.[/TD]
[/TR]
[TR]
[TH]Role[/TH]
[TD]Fighter-bomber[/TD]
[/TR]
[TR]
[TH]Manufacturer[/TH]
[TD]Republic Aviation[/TD]
[/TR]
[TR]
[TH]Designer[/TH]
[TD]Alexander Kartveli[/TD]
[/TR]
[TR]
[TH]First flight[/TH]
[TD]6 May 1941[/TD]
[/TR]
[TR]
[TH]Introduction[/TH]
[TD]1942[/TD]
[/TR]
[TR]
[TH]Retired[/TH]
[TD]1966, Peruvian Air Force[/TD]
[/TR]
[TR]
[TH]Primary users[/TH]
[TD]United States Army Air Forces
Royal Air Force
French Air Force[/TD]
[/TR]
[TR]
[TH]Produced[/TH]
[TD]1941-1945[/TD]
[/TR]
[TR]
[TH]Number built[/TH]
[TD]15,660[SUP][1][/SUP][/TD]
[/TR]
[TR]
[TH]Unit cost[/TH]
[TD]US$85,000 in 1945[SUP][2][/SUP][SUP][not in citation given][/SUP][/TD]
[/TR]
[TR]
[TH]Variants[/TH]
[TD]Republic XP-72[/TD]
[/TR]
[/TABLE]
Old 03-01-2015, 07:08 AM
SWORDSN
My Feedback: (13)
Originally Posted by chris923
I emailed Hobbico This is the answer I received.
Christopher,
Thanks for your interest in our Top Flite model. The Razorback is scheduled for release in June. Pre-orders are usually available within 2-3 weeks before release so check with your local dealer to get one of the first arrivals.
Thanks from your Hobbico Airplane Team!
If they are releasing it in June it will probably be demoed at Joe Nall
flypilot
flypilot's Avatar
Thanks Chris, the date I got here i europe is september, but June sounds much better Saito FG-60r3 on order as well, will be a nice combo..Anyone tried 20x10x4blade props on this bird?
Old 03-01-2015, 07:12 AM
SWORDSN
My Feedback: (13)
That would be the perfect engine! I hope it will fit
Old 03-01-2015, 07:20 AM
flypilot
flypilot's Avatar
According to my checks and a friend who has this engine and the p-47 cowl says it will fit.
The cowl has the following measurments at the thrustline according to another post on RCSB:
It is 8.75 inches (222mm) on the horizontal and 12 inches (305mm) on the vertical.
Name:	Screenshot 2015-03-01 16.33.14 (2).jpg
File Type: pdf
Old 03-01-2015, 08:10 AM
  #31
Lifer
Lifer's Avatar
20x10x4 has been used on the Top Flite G.S. P-47. On a DLE 55, it turned 5500 rpm on the ground. It didn't really seem to unload in the air much. With a G-62, it tached at 6000 on the ground but hasn't been flown yet due to the weather. I suspect an EME 60 would turn it fine. Several guys at my field use that engine with a 24x9 and it pulls like crazy.
Old 03-01-2015, 08:17 AM
  #32
flypilot
flypilot's Avatar
Thanks Lifer, Im thinking maybe the 20x10x4 is a bit to much for the fg-60 and maybe a 19 inch is more correct..will have to see. The engine has been reported to pull an APC 22x10 at around 6800 static though and these radials are prone to be more "torque happy". I guess we will see.
Old 03-01-2015, 08:34 AM
  #33
Lifer
Lifer's Avatar
Check YouTube for a guy named Affas flying a P-47 with a 4-stroke engine and a 19x8x4 prop. It flew pretty good.
Old 03-01-2015, 09:47 AM
  #34
flypilot
flypilot's Avatar
Yes I know, he is my friend but had forgotten about that video as it is a couple of years old...and I think it is an 18x10x4 actually, but you are right it looks to be sufficient power.
Old 03-01-2015, 10:47 AM
  #35
SWORDSN
My Feedback: (13)
Lifer,a 24x9 does not leave much much ground clearance. Is that prop used on a TF P47? I have to be ready on the elev. with a 22X10 .A flying buddy is using a 24 on his TF P47 with a DA85 has had expensive brushes with the ground on take off.
flypilot....It looks like you have done your homework and it will be the perfect engine!
Old 03-01-2015, 10:59 AM
  #36
Lifer
Lifer's Avatar
I wasn't too precise on that. Apologies. The prop was on a 3D type plane.
Old 03-01-2015, 10:42 PM
  #37
JAYNC
My Feedback: (7)
I fly a 24x14 on my P47 and I have no problems with ground clearance.
Old 06-03-2015, 01:58 AM
  #38
handyman 220
My Feedback: (54)
Maybe??? Looks nice
Old 10-27-2015, 06:56 AM
  #39
dubd
dubd's Avatar
Does anyone know if the Saito FG-60R3 will fit without cutting the cowl?
Old 10-27-2015, 07:01 AM
  #40
HoundDog
My Feedback: (49)
HoundDog's Avatar
Hope this helps
http://www.horizonhobby.com/pdf/SAIE...nual-MULTI.pdf
Old 10-28-2015, 05:37 AM
  #41
SWORDSN
My Feedback: (13)
On the FG60R3 thread there is a TF ARF p47 bubble canopy pictured without cutting the cowl.It uses the same cowl as the razorback.
Old 11-02-2015, 03:42 PM
  #42
TomH
TomH's Avatar
I have the new version of this engine and it has been broken in, I have wanted a plane to put this in. I have no warbird experience, l fly sport planes and heli's. I have read that this plane has some trainer like qualities. Is this a good first time plane.
thanks
t
Old 11-02-2015, 04:02 PM
  #43
chris923
My Feedback: (53)
TomH,
My advice to you is hook up with an experienced Warbird flyer. That will save you a lot of time, money and heart ache.
Old 11-02-2015, 05:18 PM
  #44
HoundDog
My Feedback: (49)
HoundDog's Avatar
thanks
t
It is a very easy plane to fly and take off and land ... U have to bring the power up slowly on take off and keep the speed up on landing and carry a little power. Landings are all about nailing the speed envelope, At least that's the way mine flies. Good Luck and let an experienced war bird pilot maiden her.
Old 11-03-2015, 03:39 AM
  #45
TomH
TomH's Avatar
thanks guys, good advice I will find a warbird pilot.
Old 11-03-2015, 04:16 AM
  #46
Lifer
Lifer's Avatar
Something else to consider; Set up your favorite sport plane so it has the same wing loading as your warbird project plane. Add the necessary weight to the c/g then practice landing with your sport plane to gain experience with a similarly loaded plane.
Most sport planes and trainers land with nearly zero ground speed but warbirds land much faster. Practicing with a plane set up as above will help you with the transition.
It helps!
Old 11-03-2015, 06:34 AM
  #47
SWORDSN
My Feedback: (13)
All said above is good advise....and the TF P47s are the easiest giants to fly.
Old 11-03-2015, 10:12 AM
  #48
tailskid
My Feedback: (34)
tailskid's Avatar
Has anyone started on this bird? I'm about 1/2 way through it and so far, so good!
Old 11-03-2015, 10:27 AM
  #49
Lifer
Lifer's Avatar
There really shouldn't be any surprises. The design has been around a long time. I reviewed the manual and it looked like they revised the air tank mount and of course with the top hatch you can hide all the switches, etc. I can't justify buying a third T.F. G.S. P-47, but I expect it to be very popular.
Old 11-03-2015, 12:21 PM
  #50
TomH
TomH's Avatar
It helps!
great advice lifer, I will try to calculate that out and use one of my 3D planes as the test setup.
