NEW TopFlite GS P-47 Razorback 2015
#52
My Feedback: (49)
Originally Posted by Lifer
Something else to consider; Set up your favorite sport plane so it has the same wing loading as your warbird project plane. Add the necessary weight to the c/g then practice landing with your sport plane to gain experience with a similarly loaded plane.
Most sport planes and trainers land with nearly zero ground speed but warbirds land much faster. Practicing with a plane set up as above will help you with the transition.
It helps!
Hope your Lightly Loaded Very Lightly built 3D Electric is able to take the typical Wing Loading of a war bird With out some beefing up. Just saying.
It helps!
#53
My Feedback: (7)
CA
Hey plane attics! just thought id share, i got my razorback delivered by ups santa today, I will be putting the saito 450 radial in mine, not sure it will fit all under the cowl, but hey what better than to have tons of power, a radial, and a couple of valve covers coming through the cowl? keep the buids posted love to see other ideas out there!
#58
Are you gonna be swinging a 4 blade prop? I've heard { and seen } that the DA85 is a real shaker. I've got a guy in my club that has one in a Tar Heel Hal & it isn't much faster than a DLE61. Just wondering !
Rob
#59
Hi Rob,
I hope to run a 4-blade if I can find the right prop. My 85 is serial #17 but it's had the piston mod and retarded timing done. I've also fiddled with the carb springs and the engine runs real well for a large single. The engine hasn't been used for several seasons now but it didn't vibrate too bad in the two previous airframes I had it in. So fingers crossed.
Thx,
Steve
Thx,
Steve
#60
My Feedback: (7)
I'm curious how it'll do also. I'm installing one in my Tar Heel Hal and have a Beila four blade for it. I've seen a video of one flying and seemed pretty good. Really wanted to do a Saito but don't think it would be enough power and didn't want to deal with a different fuel mix and maintenance
#61
My Feedback: (7)
CA
I have the giant top flite p40 with the da 85 it's most def. a shaker but if you like fast warbirds that's the hot ticket, I use menz 24/14 prop and does about 130mph going to use the Saito 450 on my razorback!
#62
My Feedback: (45)
No particular reason. I've got the EME 55 in the TF FW-190, TF P-51, TF- p-47 bubble canopy and the ESM PC-21. It powers them all extremely well, and I always end up getting them on some sort of sale. The only plane it didn't work well in was the H9 Corsair. I swapped it for the EME 70 and am much happier.
#75
