Top Flite Giant P47 ARF cowl mount blocks
My Feedback: (7)
NC
Ok so after flying my P47 arf for over a year my cowl mount blocks are all destroyed. During one flight they all pretty much shattered. I have been on the phone with hobby services and you cant buy the cowl mount blocks for the arf. I dont have templates to make my own either. If anyone has this plane and could send me one upper block and one lower block so I can make a template I would really appreciate it. I would send them right back. I think its absolutely ridiculous that you cant buy a high wear item like that on this plane. Also if you have this plane and havent built it yet I highly encourage you to make a template of the mount blocks. Thanks
My Feedback: (7)
NC
Yeah well the kit version of cowl mounting is way easier than the arf. The cowls are different sizes and theres nothing even close to the same as far as the kit and arf go. Maybe one day I'll be a real modeller like you and can build cowl mount blocks without even knowing the shape. I dont know why people even post rude comments. Oh I know why because its online and you arent in front of me.
My Feedback: (7)
NC
Whatever, I never asked how to make them. I will make them but if you look at post 1 all I asked was if someone had some mount blocks I could use for a template. Its not that I cant make them or dont know how to make anything. I just didnt feel like going through all the hassle for an arf if I could just measure an exact part and build new ones. Wow people mustve woke up on the wrong side of the bed today. Sorry to burden you and make you post in a thread that you dont have to reply to.
My Feedback: (53)
The one thing I learned about modeling years ago was; there are many ways to fix the problem.............just pick a way and do it!
Jaync, look at the problem and devise your own solution...................that's what all modelers do.
JAYNC,
Sad that you are treated like this, but if you are still following the thread, you might contact Hobby Services and see if they can pull the parts you need from a plane they have been cannibalizing for parts. The assembly manual has a phone number of (217) 398-0007. I might recommend that once you get these mounts you scrape the glue out of the inside corners and then add tri-stock to the inside corners for additional strength.
Best regards.
Illigitimi, non carborundum.
Best regards.
Building a TP GS P-47 ARC right now. I still have to beef up my cowl mount blocks.
Check out the attached PDF for the template. The PDF is to scale. Just print to 1:1 scale and should be good.
The small block in on top and the larger block in the bottom one.
My Feedback: (7)
NC
I appreciate your help. i plan on building all new ones and will use the template. The stock blocks are very weak. Now I know to build them out of quality plywood. Thanks for the reply
My Feedback: (51)
JAYNC,
Best regards.
Best regards.
My Feedback: (7)
NC
I appreciate all that have "helped" and contributed to this thread. I never thought in a million years I would be ridiculed for asking to borrow some mount blocks. At least around here I know that people in this hobby help each other as much as we can. Not sure why others dont see it that way. Again thanks guys and happy flying.
My Feedback: (14)
If you are in a social group face to face, rudeness and aggression are dealt with appropriately. Only on the anonymous internet to people treat others with such disrespect and become "bullies". I think it makes them feel somehow better about themselves?
One problem is that we all want to respond to them like we would if they were with us, which is a total waste of time and effort. No amount of education seems to help.
