TF P47 giant engine choices?
Hi,everybody,i,m building the p 47 giant from top flite (razorback version),robart mains and tail wheels,gear doors,will be fiberglassed.An now it is the time to buy the engine.And i have seen many options but i not sure witch to choose i like radials but there is no many options.
what do you thing is the best option for this plane,maybe by the power the os gt 33 will be enough?? please ,help me to decide which is the best option
OS gt 33 -5,5HP
OS gt 60 -6 HP
DLE 55RA-5,5HP
SAITOfg 60 3 cilinders 4,5HP
LASER 300 /360 hp unknow
MVVS 50 irs HP unknow
take a look to my build thread at:http://www.miliamperios.com/foro/aer...o-t247405.html
another options are welcome!!!
OS gt 33 -5,5HP
OS gt 60 -6 HP
DLE 55RA-5,5HP
DLE 55RA
Great engine, affordable and reliable. I have a lot of experience so far with DLE engines from their 20,35,55 that I'd say to anyone use this brand.
The RA will fit perfectly as is and run fine in that plane. Use a Xoar 22x10 prop because the engine remains loaded in a dive and the reeds are not floating causing that strange sound. Use an NGK CM6 plug do not use the DLE plug. It's garbage, I tried it once to see how long it lasts and the only dead stick I had was due to that plug.
Plenty of power!
Plenty of power!
Here's a 4-blade on a 50cc engine:
https://www.youtube.com/watch?v=EpClzq7h_NE
I've got the same prop on the same airframe with a G-62 but haven't maiden-ed it yet.
My Feedback: (46)
OS gt 33 -5,5HP
OS gt 60 -6 HP
DLE 55RA-5,5HP
OS gt 33 -5,5HP
OS gt 60 -6 HP
DLE 55RA-5,5HP
f you can afford it the saito FG60 R3 would be the coolest.
My Feedback: (7)
NC
I have a dle85 in mine with a 24x14 prop but I will never go bigger than a 60cc ever again. All you do is chase vibration problems. A friend of mine uses mostly all dle55RA engines and he is always flying and I'm always fixing cracks. I think the 55RA is the perfect engine for these giant top flite planes. I am currently building the top flite zero with the dle61 but I have had to butcher the cowl because its a side exhaust. That rear exhaust on the 55RA makes things a lot easier. He uses the Bennet Mufflers instead of stock. As for the four blades, I tried it a Biela 20x10 once on a 60cc and screwed it to the wall of my trailer for decoration. I like my warbirds to be pretty fast and the 4 blades aren't.
I have a ZDZ 80 in mine and the plane and engine are 11years old. Hundreds of flights. Mine is a kit built so I did beef up a number of areas including the engine box/bulk head area. The ZDZ is one of 3 that I have and they all run flawlessly.
surely I must thank all your valuable opinions,and from Spain thanks you,The DLA 55RA has the cheapest price but i must admit that i like much more the saito fg 60 aeshtetically
but it is more expensive:At this point there a lot of job to do wiht my bird
i can keep the decision for a while ,will se what i will do!
Cant beat the good old Zenoha 62 for warbirds, big lump, does the job, and will just het better the more its run, Love mine, and not as hard to start as you think, simple magneto, no electrics to go wrong, fit, and forget, ahhhh, the simple things But, it aint on your list, so, hey ho!
