Dave Andersen 1/4 scale Hawker Hurricane
Reply
Old 08-03-2016, 07:36 AM
F4u5
My Feedback: (81)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
F4u5 is offline
Old 08-08-2016, 05:53 PM
roydefiant
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
inboard cannon shroud 3D printed by Trapezoid
ID:	2176244   Click image for larger version
roydefiant is offline
Old 08-15-2016, 03:24 PM
Nordicz
My Feedback: (7)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Man, that sure looks good Roy,
Marty Z
Nordicz is offline
Old 08-20-2016, 05:05 PM
roydefiant
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
So now available are inner and outer cannon shrouds as seen in the first picture. I have not gotten the springs yet but will be available as in the parts list if anyone orders from "Kirk"..You can also see the gun blisters on the wing. These are prototypes. When I chart tape off panels will make sure they are correct. The production versions will probably have a small flange like full size.
The teardrop blister over the cowl valve covers is printed to match the curvature of the cowl. Will again size this up to make sure looks correct before production versions which will also probably have a small flange.
ID:	2177668   Click image for larger version
ID:	2177669   Click image for larger version
Old 08-29-2016, 09:18 AM
F4u5
My Feedback: (81)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I now have a center section and right panel mostly frame/sheeted:
ID:	2178809   Click image for larger version
ID:	2178810   Click image for larger version
ID:	2178811   Click image for larger version
ID:	2178812   Click image for larger version
ID:	2178813   Click image for larger version
ID:	2178814   Click image for larger version
ID:	2178815   Click image for larger version
ID:	2178817   Click image for larger version
ID:	2178818   Click image for larger version
ID:	2178819   Click image for larger version
F4u5 is offline
Old 08-30-2016, 06:51 AM
  #31
CRJDriver
My Feedback: (57)
CRJDriver's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looking great Jeff! I love the "Be Damn Sure" comment reference rib 8! Nice touch!
CRJDriver is offline
Old 09-10-2016, 04:36 PM
  #32
roydefiant
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
As leading edge of tail feathers are sheet metal on full size I am building up leading edge with primer to simulate. Also shot some primer on inboard wings to look for any defects I need to fix
ID:	2180562   Click image for larger version
Old 09-11-2016, 12:44 PM
  #33
roydefiant
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
So now a hard edge where metal ended. After rib stitching, light primer coat then color coat the edge will soften
Old 09-25-2016, 02:29 PM
  #34
roydefiant
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
cannons mounted left wing with laser level to get straight.
ID:	2182822   Click image for larger version
Old 10-01-2016, 11:39 AM
  #35
roydefiant
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
starting to look mean with all the cannons mounted
ID:	2183777   Click image for larger version
Old 10-01-2016, 11:42 AM
  #36
roydefiant
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
More body putty then primer on fuse, looks very smooth now. Also built up leading edge on horizontal stab with primer to simulate the underlying metal sheeting there.
ID:	2183779   Click image for larger version
ID:	2183780   Click image for larger version
Old 10-14-2016, 01:50 PM
  #37
roydefiant
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I made up a light kit from electrodynamics. No heat from their LED's These are pictures of the landing light. Trapezoid 3D printed the holder and octopus screen that holds the lens in. The lens is from I fly tallies. One picture obviously is with landing light on. The other is to show what it looks like in the landing light well in leading edge of wing. Just awesome like the real thing
ID:	2185683   Click image for larger version
ID:	2185684   Click image for larger version
Old 11-22-2016, 06:56 AM
  #38
roydefiant
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Fitting exhausts, a little more fill to do before painting. Also now have the sound system working. 2 four inch speakers mounted in radiator , one facing forward the other backwards. Linked to throttle with start up and shut down noises of rolls royce merlin. Also has hispano cannon noises. Awesome sound system from modelsoundsinc
ID:	2191002   Click image for larger version
Old 11-23-2016, 07:29 PM
  #39
roydefiant
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
rudder trim tab and tail light in place. Now just need to find a domed lens cover tp put over LED
Old 11-27-2016, 04:46 AM
  #40
CRJDriver
My Feedback: (57)
CRJDriver's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looks great Roy!
Old 01-04-2017, 07:04 PM
  #41
roydefiant
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Back on now the holidays are over. First picture shows blisters over the valve covers. 2nd picture shows the conduit taking air in from the oil cooler scoop into the airframe. The 3rd picture shows the hole the conduit will bring air into where the speed controller will be mounted. The 4th picture shows the 6V fan that will help draw cold air in thru the conduit to blow over the speed controller to keep it cool.
ID:	2195546   Click image for larger version
ID:	2195547   Click image for larger version
ID:	2195548   Click image for larger version
Old 08-03-2017, 08:57 AM
  #42
hurrimk2c
My Feedback: (10)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm not sure what happened to this thread - are the plans available for this 1/4 scale Hurricane? Thank you
hurrimk2c is offline
Old 08-03-2017, 11:26 AM
  #43
F4u5
My Feedback: (81)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Both prototypes are nearing completion. Plans will be available upon successful flight of the prototype. Thanks
Jeff
F4u5 is offline
Old 08-03-2017, 02:39 PM
  #44
hurrimk2c
My Feedback: (10)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Hurricane
Excellent - Thank you Jeff - what's the best way to keep track of when the plans will be available? Just monitor this thread or the web site?
Old 08-03-2017, 03:14 PM
  #45
F4u5
My Feedback: (81)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That or check RCSB where I am doing updates. Otherwise monitor mnbigbirds.com
I still hope to get mine in the air this fall. Hopefully plans by winter.
Jeff
F4u5 is offline
Old 08-03-2017, 04:53 PM
  #46
roydefiant
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Old 08-03-2017, 05:48 PM
  #47
roydefiant
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
coming along
ID:	2226854   Click image for larger version
ID:	2226855   Click image for larger version
Old 08-03-2017, 08:24 PM
  #48
F4u5
My Feedback: (81)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
And looking good
F4u5 is offline
Old 09-07-2018, 07:01 AM
  #49
limeybob
limeybob's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default 1/4 Scale Hurricane
All, laser cut kit is now available
http://store.laser-design-services.com/index.php?main_page=product_info&cPath=7&products_id=513
Bob
limeybob is offline
Old 09-14-2018, 07:08 AM
  #50
Moggy
My Feedback: (9)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Hurri for my next build
This all sounds good but I don't have a 3D printer so will all of the components be available? Any kit cutters cutting it yet? I really like this plane so I hope they do a good job making it available.
Moggy is offline
