Reload this Page >
Fliteskin Ta-152 H1
Fliteskin Ta-152 H1
Old 01-11-2016, 06:37 PM
  #76
serkan1978
the bottom and the top stabilazer glued together with epoxy and I added balsa leading edge
ID:	2140992   Click image for larger version
Old 01-11-2016, 07:29 PM
  #77
JGrc
My Feedback: (29)
JGrc's Avatar
I'm glad I told you not to use epoxy there. It's heavy and not needed.
J
Old 01-11-2016, 07:43 PM
  #78
serkan1978
I should pay more attention to read your message next time my bad I completely misunderstood anyway it is to late now I didn't use too much I used with brush
Old 01-18-2016, 11:44 PM
  #79
serkan1978
I added balsa leading edge and applyed fibreglass I used eze cote finishing resin
ID:	2142363   Click image for larger version
Old 01-19-2016, 09:40 PM
  #80
JGrc
My Feedback: (29)
JGrc's Avatar
It looks really good, how did you apply the EZE coat, with glass cloth or straight on the wood?
JG
Old 01-20-2016, 07:49 PM
  #81
serkan1978
[QUOTE=JGrc;12164425]It looks really good, how did you apply the EZE coat, with glass cloth or straight on the wood?
The first coat straight on the wood the second coat with glass cloth
Old 01-24-2016, 05:21 PM
  #82
Duplicator41
Duplicator41's Avatar
The first coat straight on the wood the second coat with glass cloth[/QUOTE]
How do you like the EZE Coat compared to Epoxy resin?
Cheers,
Old 01-25-2016, 02:41 PM
  #83
serkan1978
So far i liked it you don't have to mix anything I used same brush during all process,clean with water easy,dry fast but I just used for the leading edge I will try on the wing then I can have a better idea
Old 01-25-2016, 05:34 PM
  #84
Duplicator41
Thanks, I'm looking forward as to how it goes on the wing.
Cheers,
Old 01-25-2016, 09:22 PM
  #85
JGrc
My Feedback: (29)
JGrc's Avatar
When do you start the wing?
JG
Old 01-25-2016, 09:56 PM
  #86
serkan1978
I am still waiting for the low profile high voltage servo they should be here this week then I can finish the flaps
Old 01-28-2016, 09:43 AM
  #87
JGrc
My Feedback: (29)
JGrc's Avatar
A couple of weekends ago, nice weather allowed some Ta152 flights again.
JG
Old 01-28-2016, 09:24 PM
  #88
serkan1978
Looks great I can't wait to finish mine
Old 02-13-2016, 10:39 PM
  #89
serkan1978
Finally I have received the servos for the flaps
ID:	2147148   Click image for larger version
ID:	2147149   Click image for larger version
Old 02-22-2016, 02:48 PM
  #90
serkan1978
The top of the wing covered with fliteskin it was easier than I thought
ID:	2148879   Click image for larger version
Old 02-22-2016, 04:31 PM
  #91
JGrc
My Feedback: (29)
JGrc's Avatar
Serkan,
looks very nice!! you forgot the leading edge though. Post of picture of the bottom of the wing before you sheet the bottom please.
Here is a great page with the Ta152 references: http://www.ta-152.de/farbprofile/
Which paint job did you pick?
JG
Old 02-22-2016, 06:47 PM
  #92
serkan1978
I covered half of the leading edge the bottom one is not sand it yet once I finish sanding should be little gap between them then I will use Fiberglas cloth. I am thinking the red one what do you think?
ID:	2148926   Click image for larger version
Old 02-22-2016, 08:20 PM
  #93
JGrc
My Feedback: (29)
JGrc's Avatar
Serkan,
Before you apply the fliteskin, the whole leading edge should be flush with the ribs and sanded to shape.
Also make sure you go over the latest revision on the wing sheeting area in front of the landing gear.
JG
ID:	2148928   Click image for larger version
Name:	TA 152 wing1.jpg
ID:	2148929   Click image for larger version
Old 02-23-2016, 07:11 AM
  #94
JGrc
My Feedback: (29)
JGrc's Avatar
Serkan,
the red scheme is very easy to reproduce I guess! Here is another very nice scheme seldom done:
JG
Old 03-28-2016, 01:42 PM
  #95
JGrc
My Feedback: (29)
JGrc's Avatar
Serkan,
any progress with the fuselage?
JG
Old 03-31-2016, 08:35 PM
  #96
serkan1978
Not yet
ID:	2155335   Click image for larger version
Old 04-22-2016, 05:46 PM
  #97
serkan1978
What is the best tool to cut the Fiberglas fuse?
Old 04-23-2016, 08:25 AM
  #98
JGrc
My Feedback: (29)
JGrc's Avatar
I cut mostly with a dremel cutting wheel being careful not to go too far. Round all corners with a small stone wheel. If you leave sharp corners they will turn into cracks.
This shows the aft hatch where the elevator bell crank is installed.
JG
Old 04-23-2016, 10:50 AM
  #99
JGrc
My Feedback: (29)
JGrc's Avatar
additionally:
When you open up the front fuse area, leave enough material to mount the cowl brackets.
Also you need to open the cavity for the stabilator to fit through the tail section.
JG
ID:	2158640   Click image for larger version
ID:	2158641   Click image for larger version
ID:	2158642   Click image for larger version
ID:	2158643   Click image for larger version
Old 04-23-2016, 10:52 AM
  #100
JGrc
My Feedback: (29)
JGrc's Avatar
This shows the cowl mounting on the right side of the engine.
JG
