How to Build a B-29
Reply
Old 01-19-2016, 07:23 AM
  #126
kram
kram's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
How the saddle fits in the bones
kram is offline
Old 01-19-2016, 07:32 AM
  #127
kram
kram's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Formers 11 thru 16 need to lose some wood before they're installed (see pencil lines)
Leave just a shallow notch to catch the wing saddle (as shown)
Use former 5, 6 or 7 as a pattern
This is a lot more easily done BEFORE than after assembly, and will leave space for bomb bays and center wing hardware
ID:	2142401   Click image for larger version
ID:	2142402   Click image for larger version
kram is offline
Old 01-19-2016, 07:35 AM
  #128
kram
kram's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Left half of the fuse is planked and solid
It weighs less than 1.5 lbs!
ID:	2142407   Click image for larger version
kram is offline
Old 01-19-2016, 07:37 AM
  #129
kram
kram's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Measure other wing saddle to make sure of 3 degrees + incidence on center wing
kram is offline
Old 01-22-2016, 08:11 PM
  #130
kram
kram's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Level the left fuse and glue it solidly to the table
ID:	2142920   Click image for larger version
kram is offline
Old 01-22-2016, 08:16 PM
  #131
kram
kram's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sharpen a small piano wire and gently punch holes in the left planking to mark the cut-out for the wing saddles
This will even make doing the other side easier
ID:	2142922   Click image for larger version
kram is offline
Old 01-22-2016, 08:17 PM
  #132
kram
kram's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Tunnel Vision!
kram is offline
Old 01-22-2016, 08:25 PM
  #133
kram
kram's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Stringers on
Balsa strips applied to former edges to get them ready for sanding
Sanding: just like the wing, how smooth and flat you get the former edges BEFORE you plank, will make the planking look a lot better and easier to sand
Note the long level for sanding, just like the wing.
All the above, including sanding took about 2.5 hours
I like to get one 2-3 hr step finished every day I'm building: keeps the project moving along and frees your mind to think of the next step
ID:	2142929   Click image for larger version
kram is offline
Old 01-22-2016, 08:30 PM
  #134
kram
kram's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Fully planked fuse, ready for rough-sanding
Editor's Note: I don't know how he got that done in two days! Was it my turn to watch him??
I think he may have spent more than 2-3 hours. Would've take me a week, at least!
ID:	2142933   Click image for larger version
kram is offline
Old 01-22-2016, 08:41 PM
  #135
kram
kram's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The Builder's Second Law of Thermodynamics:
The further a project progresses, the messier is my shop
Now that 90% of the "gluing" is done, I have emptied four 8oz bottles of CA and one 8oz bottle of kicker
ID:	2142935   Click image for larger version
kram is offline
Old 01-23-2016, 08:50 PM
  #136
kram
kram's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Wing saddles cut out and framed
Beef up area for wing bolts:
Vertical gussets with lightening holes made to strengthen fuse wall outside and wing saddle inside
Then 1/4 aircraft ply epoxied to fit on (below) gussets
Receiver holes for the two wing bolts per side with be drilled and tapped after the wing fit is perfected
ID:	2143103   Click image for larger version
ID:	2143104   Click image for larger version
kram is offline
Old 01-23-2016, 08:55 PM
  #137
kram
kram's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nose gear installed and she is ON HER FEET!
Not too far behind her predecessor ? years ago
ID:	2143106   Click image for larger version
kram is offline
Old 01-23-2016, 08:59 PM
  #138
kram
kram's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Fuse with nose gear, but no empennage < 4 lbs
I am optimistic final dry weight of aircraft will be in the high 40's
kram is offline
Old 01-24-2016, 11:44 AM
  #139
bolar
bolar's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I rated this thread 5 stars, I wish there were more. Keep up the good work!!
bolar is offline
Old 01-24-2016, 05:12 PM
  #140
kram
kram's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks, bolar! (and he's not even a relative!)
Frontal view of inboard and outboard nacelles to show how much room we'll have for tanks, throttle servos, etc
Outboards will fit 24 oz tanks, inboards will have 16 oz, plenty for > 10 min flight with a Saito 91
A lot of this extra room in the nacelles is a result of bypassing Don Smith plans for engine mounts and nacelles stringers and doing it the way we detailed earlier in the thread
ID:	2143261   Click image for larger version
kram is offline
Old 01-24-2016, 05:20 PM
  #141
kram
kram's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Tapping fuse for 1/2" LE dowels and 4 wing bolts.
I ream the fuse bolt holes just a little to make starting the wing bolts easy
The little homemade tool shown fits into the LE holes drilled for dowels, then perfectly marks centerpoint for drilling the fuse former to fit
ID:	2143263   Click image for larger version
ID:	2143264   Click image for larger version
ID:	2143265   Click image for larger version
kram is offline
Old 01-24-2016, 05:32 PM
  #142
kram
kram's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Inlaid tiles of 1/8" aircraft ply on bottom of wing where bolt heads will tighten: then saturated tiles with thin CA
Then overlay tiles and this whole strip of underwing with a plate of 1/32" aircraft ply
Then drill 4 holes through the ply reinforcements from holes in the top side of the wing
Last is a picture from the underside of the wing bolted to the fuse
ID:	2143268   Click image for larger version
ID:	2143269   Click image for larger version
ID:	2143270   Click image for larger version
kram is offline
Old 01-24-2016, 05:41 PM
  #143
kram
kram's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Between the top of the wing and the rigid (but perfectly 3 degrees +) fuse saddles, I laid a matte of softer 1/4" balsa
Much easier to sand and mate to perfection than the actual wing surface or fuse saddles, and adds great strength to the thin saddles, AND after sanding, fiberglass and paint, the "matte" will be invisible
kram is offline
Old 01-24-2016, 08:30 PM
  #144
70 ragtop
My Feedback: (23)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looking good!
70 ragtop is offline
Old 01-25-2016, 05:44 AM
  #145
SWORDSN
My Feedback: (13)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Great thread kram.Why the different size tanks? Nose weight?
SWORDSN is offline
Old 01-25-2016, 07:17 PM
  #146
kram
kram's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Begin the Empennage
ID:	2143560   Click image for larger version
ID:	2143561   Click image for larger version
kram is offline
Old 01-25-2016, 07:33 PM
  #147
kram
kram's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
SWORDSN:
Different tanks because of two converging factors: one on the work table and the other in the air
1) There is simply more room in the outboard nacelles because they carry no landing gear
2) 4-engine bombers fly without much conscious correction (except a little added throttle) if an inboard runs out of fuel
(Running out of fuel on an outboard demands more exacting yaw and roll control)
So, especially at events where bombers often fly in groups and runway clutter is common, it's nice to know your outboards will last 50% longer. A Saito will run about 35 minutes on a 24 oz tank in a slow holding pattern
kram is offline
Old 01-25-2016, 07:37 PM
  #148
kram
kram's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dwayne's first Don Smith B-29 has no added weight, except a large NiCad about 6 inches from the nose
kram is offline
Old 01-26-2016, 06:25 AM
  #149
aghost
My Feedback: (13)
aghost's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I will never build a B-29, but I like watching this build. Thanks.
Brian
P.S. In an earlier post, don't you mean the "
nice to know your outboards will last 50% longer"
aghost is offline
Old 01-26-2016, 11:01 AM
  #150
kram
kram's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
aghost:
Typo
Fixed it
mt
kram is offline
