Top RC Zero from Gator R/C
Old 03-21-2019, 01:25 PM
  #601
DH71TIGER
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi everyone,
Due to health reasons, I am thinking about buying a hand held electric starter for my FG-90 R3, do any of you guys use a starter ? If so, which one ? I would appreciate some comment from somebody who actually uses one.
Thanks in advance
Andrew
DH71TIGER is offline
Old 03-21-2019, 04:26 PM
  #602
LtMash1A
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Originally Posted by DH71TIGER View Post
Hi everyone,
Thanks in advance
Andrew
Just use your electric drill. Buy a starter cone and insert from Sullivan, put a bolt, (I think a 4-40) in the cone to attach to your drill. i've use it for a couple of years on my RG 84 and RG 90. Works perfectly.
LtMash1A is offline
Old 03-22-2019, 09:51 AM
  #603
DH71TIGER
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks LtMash1A .................... good idea, I'll give that some thought ..............
Andrew
Old 03-22-2019, 11:26 AM
  #604
Neil Guildford
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I’ve been looking at beila props but they are too thick at the hub to fit a backplate on for a spinner due to the length of the prop nut thread. Can anyone please help with alternative brands of quality propellers which work on the Saito 84?
Photo of my Zero awaiting it’s maiden....
Neil Guildford is offline
Old 03-22-2019, 12:32 PM
  #605
LtMash1A
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What Beila prop? I run a 22X12 Beilla Fokke Wulf prop from Aircraft International on my Zero with an 84 as well as the 22X12 WWII Prop. That's a lot of oil on the ground!
LtMash1A is offline
Old 03-22-2019, 03:02 PM
  #606
Craig B.
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nice fit out Neil. ��
Craig B. is offline
Old 03-26-2019, 05:53 AM
  #607
Neil Guildford
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The beila 24 x 10 prop I have is a 34mm thick hub and too big for a spinner, unless I recess the prop nut. The WWII ones are 30mm I believe, does that not cause the same issue?
Old 03-26-2019, 12:47 PM
  #608
LtMash1A
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I don't know if this will help, but I use a Beila 22X12 3 blade Folk wulf prop on my Zero with the 90. The thickness is 25.6mm and poses no problem for fit. Check on that thickness of the WWII prop. . If you call Aircraft International, they can give you the thickness of any prop hub. As a matter of fact the prop that Ray English recommends is the Beilla 3 blade 22X12 size WWII , so I know it will fit. I haver used it as well I would recommend a 22X12 3 blade prop, Combined with the Keleo Exhaust Ring people are going to asking you "What have you got in that thing? It really sounds great". Heavier prop, less nose weight, better sound. If you use a 24X10 2 blade you may need to go with a wooden prop. Falcon makes a painted WWII wooden 24X10 prop.
, nor 24X10.
LtMash1A is offline
Old 04-11-2019, 07:02 AM
  #609
Neil Guildford
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I hope this is going to work...
I've cut into the Beila prop by 14mm to enable the use of my spinner.
Old 04-11-2019, 09:12 AM
  #610
LtMash1A
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What is the width of the prop hub? I use the 3 blade 22X12 for my 90 and don't have to trim anything.
LtMash1A is offline
Old 04-11-2019, 09:30 AM
  #611
Neil Guildford
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I think it’s 34mm from memory. I wonder if I have a shorter prop shaft as a few people have commented the same. With the back plate for the spinner on I can only just get the whole of the first nut on, but only if I omit the washer.
Old 04-11-2019, 09:47 AM
  #612
LtMash1A
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Biella 3 Blade 22X12 is 24.2mm thick at the hub. The 22X12 and Keleo exhaust ring makes for incredibly good sound.
LtMash1A is offline
Old 04-13-2019, 08:05 AM
  #613
Neil Guildford
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Is that the semi scale black prop or one of the white ones that’s 24.5mm?
Old 04-13-2019, 08:47 AM
  #614
LtMash1A
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Aircraft International: Biela Simi-Scale
1) 3 Blake Simi-Scale Corsair Style. 22X12 or
2) 3 Blade Semi-Scae Fokke Wulf Style 22X12
Either one will work.
LtMash1A is offline
Old 04-13-2019, 09:27 AM
  #615
Neil Guildford
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I can only think that Biela has changed the size that they manufacture to.
This engine isn’t new to me and was in my Hangar 9 Corsair for three years previously, first with a 22 x 10 3b semi scale Biela, then 22 x 12 3b and lastly the 24 x 10 2b.
The 2 blade is the thickest at 34mm.
22 x 12 3b is 28mm
22 x 10 3b is 27.2mm.
Old 04-13-2019, 12:25 PM
  #616
flypilot
flypilot's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
New maiden complete in Norway, will be posting video tomorrow..
flypilot is offline
Old 04-14-2019, 08:28 AM
  #617
roydefiant
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Congrats on maiden. What engine and gear did you use? What was all up weight?
roydefiant is offline
Old 04-14-2019, 11:55 AM
  #618
flypilot
flypilot's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here is the video, hope you like it, its a Saito FG90 and sierra retracts
flypilot is offline
Old 04-14-2019, 12:10 PM
  #619
Neil Guildford
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Good video, thanks for posting.
Old 04-24-2019, 08:57 AM
  #620
totto
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thank you !
Saito FG90R3 radial gas engine. The gear is Sierra retract (Air)
Total weight dry 15 kg. (without extra drop tank)
totto is offline
Old 04-25-2019, 09:59 AM
  #621
totto
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
totto is offline
Old 06-27-2019, 04:25 AM
  #622
MikeJM
MikeJM's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Structural failure
I loved my TopRc Zero, however I experienced 2 major structural failures with my Zero. First problem was a leading edge flutter at the root of the wing, right in front of the wheel wells I recovered from this and made a modification to minimize the problem. The second failure was unrecoverable.
BUYER BEWARE. Make sure you reinforce the tube mounts
MikeJM is offline
Old 07-22-2019, 02:51 PM
  #623
HiCurrent
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What do you guys recommend for the gears. Is the TopRC gears good enough. I really hate Robart. Does Sierra makes the gears for this plane ?
HiCurrent is offline
Old 07-22-2019, 04:52 PM
  #624
JKreitz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I wasn't a fan of Robart either so I went with the electric gear from Top RC, looked really good with the polished aluminum and all. My experience with them was not good, if you bump the gear switch and it starts moving while on the ground, you'll cook the gear motors. The struts are also not very beefy, barely got it sideways and the strut folded over. Switched over to Robart air and so far I love them. My 2 cents.
JKreitz is offline
Old 07-22-2019, 05:53 PM
  #625
HiCurrent
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Flypilot used the Sierra gears but I couldn't find it on VQWarbirds or GatorRC. I wonder if he uses the EMS gears for the 88" zero
Copyright © 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
