Reload this Page >
New 80" WS SBD-5 Dauntless AFT
Old 01-14-2016, 12:29 PM
tailskid
My Feedback: (34)
tailskid's Avatar
I'm going to try and get there.....
Old 01-14-2016, 05:27 PM
uncljoe
My Feedback: (8)
uncljoe's Avatar
Its a KEEPER ... Flew most flew of flight 1/2 throttle ,10 s system for power /123 for receiver/servos ...
Semper Fi
Joe
ID:	2141395   Click image for larger version
ID:	2141396   Click image for larger version
ID:	2141397   Click image for larger version
ID:	2141398   Click image for larger version
ID:	2141399   Click image for larger version
ID:	2141400   Click image for larger version
ID:	2141401   Click image for larger version
Old 01-15-2016, 04:10 AM
LDM
My Feedback: (15)
Looks awesome Joe congrats !
So power 160 , assume 100amp esc and 2x 5 cells ?
lou
Old 02-18-2016, 10:34 PM
NoFlaps
My Feedback: (131)
Ok- I broke down and got one...gonna be a gasser. I have a few engines in the 30-45cc range that I hope won't shape that suspect wood apart.
i had 2 VQ warbirds back in 2001, and swore them off, but I love this plane. I hope this isn't a mistake.
Old 02-19-2016, 05:52 AM
tailskid
My Feedback: (34)
tailskid's Avatar
Working on mine.....going with DLE 35....so far so good!
Old 02-19-2016, 08:11 AM
  #31
NoFlaps
My Feedback: (131)
What's the inside diameter of the cowlling?
I wonder if you could get an RCGH twin 30CC to fit in there...Might help with a need to add noseweight.
Old 02-20-2016, 12:44 PM
  #32
tailskid
My Feedback: (34)
tailskid's Avatar
It is 8" wide and about 9" top to bottom....
I'm doing a blog on the build http://www.rcgroups.com/forums/member.php?u=17565
ID:	2148484   Click image for larger version
Old 02-22-2016, 01:05 PM
  #33
NoFlaps
My Feedback: (131)
That's smaller than I thought...I don't think a 30CC twin would sit under there.
My retracts arrived today, plane is due by Wednesday.
Anything tricky refarding the airbrake set-up ?
How brittle is the canopy? (Tthe ESM ones crack when you bring scissors into the room) I hope to do a similar set up as Uncle joes.
Old 02-22-2016, 01:10 PM
  #34
tailskid
My Feedback: (34)
tailskid's Avatar
Airbrakes are not hardly mentioned in the 'distructions'....but only remember to use 5 of the same servos, same control arms and of course make sure they all work the way they should - I found their 'marked' locations not to work well, so I moved my servos around so they all could play together.....computer programming was necessary as I have the airbrakes and flaps linked on a separate switch as opposed to the flaps (only) switch.
The canopy hasn't been attacked yet so I don't know how it will react to my knife, but like unclejoe, the front canopy has to be open to be cool
Old 02-23-2016, 09:23 AM
  #35
NoFlaps
My Feedback: (131)
No doubt on the canopy. thanks for the updates...Please keep us informed, add pics and please, somebody; get a video of this baby in flight !!!
Old 02-24-2016, 11:57 AM
  #36
uncljoe
My Feedback: (8)
uncljoe's Avatar
I had no problem with the flaps,used flap switch for flaps(lower) and another switch for the Dive brakes, linkage was no problem, The canopy was easily cut using curved scissors . no brittle at all
Great flying airplane.
Semper Fi
Old 02-24-2016, 12:05 PM
  #37
NoFlaps
My Feedback: (131)
Hey uncljoe...What micro servos are you using ?
Old 02-24-2016, 12:29 PM
  #38
NoFlaps
My Feedback: (131)
Tailskid, What size micro servos are you using on this bird ?
Old 02-24-2016, 02:05 PM
  #39
tailskid
My Feedback: (34)
tailskid's Avatar
I used these from JB Hobbies......
ID:	2149203   Click image for larger version
Old 02-25-2016, 04:57 AM
  #40
uncljoe
My Feedback: (8)
uncljoe's Avatar
I used the one's recommended bu JB hobbies, the one on the left in photo above. Hope It answers you question
Semper Fi
Joe
Old 02-25-2016, 10:06 AM
  #41
tailskid
My Feedback: (34)
tailskid's Avatar
Unclejoe, are you coming to the Electrical event in AJ?
Old 02-25-2016, 02:53 PM
  #42
uncljoe
My Feedback: (8)
uncljoe's Avatar
Yes ! Have two east coast pilots ,going out Friday hope to be there by 10 am
Semper Fi
Old 02-25-2016, 03:12 PM
  #43
tailskid
My Feedback: (34)
tailskid's Avatar
Good, make certain you bring the Dauntless!!!! Mine is 90% done, darn I was hoping I would fly it this weekend....
Old 02-26-2016, 06:39 PM
  #44
uncljoe
My Feedback: (8)
uncljoe's Avatar
Guys WARNING WARNING WARNING WARNING
Had a massive failure with the elevator, even though I pined the hinges ,had both elevators depart the stab. about 200 ft . so control was non existent ended up with a bag of balsa and a big hole in the desert. Will post photos of aircraft with one elevator still attached to servo, and one departed
I checking the hinges that were left it appears that there was no glue on the hinges . Before flight I would PULL OUT ALL HINGES ANS EPOXY & PIn all hinges at least three points
Semper Fi
Joe
ID:	2149580   Click image for larger version
Name:	IMG_0152 3 (1).jpg
Old 02-27-2016, 06:40 AM
  #45
SWORDSN
My Feedback: (13)
Was there flutter?
Old 02-27-2016, 07:02 AM
  #46
rcmiket
rcmiket's Avatar
Could I get the diameter of the dummy radial? I'm hunting for something that will fit my 1/9th scale Skyshark Avenger kit I'm working on.
Mike
Old 02-27-2016, 04:01 PM
  #47
uncljoe
My Feedback: (8)
uncljoe's Avatar
Did NOT HEAR any sound that usually occurs when one has flutter, but could have been . No violent manavours prior to elevators .After examination the remains It appears that there was no glue on any of the stabs hinges ,maybe CA but no apparent glue to wood surfaces . Sure glad I pinned the hinges or might have lost it on prior flights.....
Semper Fi
Joe
Old 02-27-2016, 05:51 PM
  #48
tailskid
My Feedback: (34)
tailskid's Avatar
You were pretty high when that happened but a couple of us saw some flutter....now the questions is::
Did the servo give out first? (is it stripped)
Did the pushrod clevis malfunction? (is it even on the pushrod?_
Did the hinges go first. (tough to tell)
Jerry
Old 02-27-2016, 05:54 PM
  #49
tailskid
My Feedback: (34)
tailskid's Avatar
Crap Mike, I cut mine up a bit to fit but I'm guessing it was around 7 1/4" in diameter.
Old 02-27-2016, 06:25 PM
  #50
uncljoe
My Feedback: (8)
uncljoe's Avatar
Hi Jerry
Servo with the missing elevator(one that departed the stab) has arm & rod , servo works
on the stab that lost the elevator missing two hinges with pins missing and balsa residue .My guess hinges went first but its only a guess
I will get another but will remove hinges and re glue with epoxy ,also update all hardware & use 4-40 push rods
Semper Fi
Joe
It appears that the bass wood blocks delaminated from the plywood mounts even though glued . NEED a screw thru the plywood into the block. Blocks have plywood on them and you can see the plymount mounts have layers removed from them .BTW after removing the covering all the balsa wood joints in the wing / fuselage have CA through out
