Robart P-47 Razorback Repaint and Assemble
My Feedback: (32)
For Christmas I received the Robart P-47 in the Zombie scheme. I've always wanted to do the 5F-A scheme so I will be redoing that scheme on the Zombie.
I will be using a Hacker A100-10 for power on 12 cells 10,000 mAh.
Kirk
Kirk
My Feedback: (32)
One of the first things I noticed was the chin scoop provided was not the correct shape so I order the one Ziroli sells. It has been fitted and glued in place.
I've been collecting parts to so will waiting I decided to start putting a Williams Brothers dummy engine kit together. The engine kit is a little work but will look nice once it's completed and painted.
Kirk
Kirk
My Feedback: (32)
Hi Vincent,
I'm using the 1/6th scale kit. The 1/5th scale kit is a little too large to fit far enough forward in the cowl with the chin scoop in place.
Kirk
Kirk
My Feedback: (32)
Completed putting the Williams Brothers dummy engine together. Painted the crank case grey and the cylinders aluminum.
Photo 1 - The cylinder on the left after it was painted and the cylinder on the right after weathering was applied.
Photo 2 - The engine after being assembled and weathered.
Photo 3 - The push rods and ignition cables have been added.
Photo 4 - The engine is almost ready to install. Just need to make up the mounting former.
Kirk
Kirk
TX
Vincent, I just mounted it to a 1/8 ply piece that I cut to fit in the cowl. The ply also acts as a baffle, making all incoming air go to the heads.
Evan Q.
Hola Kirk! Nice to see youre still wasting electrons.
E.
Evan Q.
E.
My Feedback: (32)
Hey Evan,
I've changed over to kero for the jets but still abusing the electrons on the prop planes with the exception of the 1/4 scale PC-21. I'm turning the prop with a kero burner
https://www.youtube.com/watch?v=UmcuYZi34cs Kirk
