Seagull Spitfire 26- 38 cc
#132
My Feedback: (19)
I spent a lot of time by searching some information about DU J PL124. I didnīt find any good materials or picture of this Spitfire with visible serial number. I decided to change the tail number. I will paint DU V MJ751. This Spitfire was often flown by F/O Miroslav Liskutin. During one of the "Ramrod" action on 21 May 1944 over the Fance he hit a tree during very low flight when he was shootin on the vehicles. The wing was damaged, but F/O Liskutin came back to Appledram air base. I suppose it was Ramrod 906.
Here you can see some of his combat films.
http://history.virtualfighters.cz/Liskutin-3011.html
#136
My Feedback: (19)
The second third of painting is done. Tomorrow I will put the green fields. I tried to put them today, but whole Spit is covered by dust from the grey paint. I can rub it away after 12 hours.
Then I started the painting I prepared the surface for wear out. The result is visible on the stab.
#137
My Feedback: (19)
Because of long rainy weather I was able to paint the green fields today. Iīve painted only the fuselage. Iīm not very satisfied with the result. There is a lot of the green dust on the grey fields. Anybody have idea how to paint the smooth board between the colours? If I use same tape or stencil there would be sharp edge as on German warbirds.
#138
Hi Prekin
If it's any help :-
The factory method of painting the camouflage pattern was use light ply masks with small spacers (around 25mm) to soften the colour demarcation.
If it's any help :-
#139
Hi Perkin
I used foam masking tape, its used in the automotive trade for masking inside door jams..I repainted my hanger 9 spit using this method it worked well.
cheers raaf
cheers raaf
#141
Hi Perkin
Sorry mate i havnt got a link for your country but if you can try someone that sells automotive paints and surplies you should find it there
good luck mate.
cheers raaf
good luck mate.
cheers raaf
