Electric Retracts for TF .60 Size P47
Hi everyone,
I plan on installing e-flite 60 - 120 85-Degree Main Electric Retracts on my Top Flite .60 size P47. Can anyone tell me what is the best way to route the wiring coming from the retract units? The only way I see to do it is to remove the clips from the wires, tape the wires to a push rod, pull it through the linkage tubing (which will require a lot of bending, finagling, trial and error ), then reattach the clips. Does anyone have any other recommendations? Any advise is appreciated. Thanks.
If you haven't glued your wings together then it's pretty simple. My Eflite retracts have very short connector wires on the plugs requiring extension leads. Drill a hole through each root rib in line with the wheel well, drill into the wheel well just enough to see where the hole is. Enlarge the hole with a Dremel just enough to pass the plug through it. Drill a hole in the top of the wing for the retract extension to come out. Make sure your extension is long enough to reach your receiver "Y" harness. I CA'd my servo extension into the wheel well in three or four spots and it's done. I recommend you angle your strut a little more forward by adding a washer or two under the rear retract bracket. Makes for better take offs and landings.
Cheers,
Cheers,
Cheers,
Cheers,
I hope this helps anyone who faces this problem.
