Pictures posted coming up as attachments instead of pictures!
My Feedback: (43)
Does anyone have a remedy for this problem?
I've got a good 150 pictures to post but will not post them until this problem is fixed.
I've sent the web site 3 private messages with no response.
Personally, I've quite posting on this web site until they fix the problem or I get a solution for posting pictures and not attachments (no pictures showing on the post).
Sam
Sam
Sam
Sam
Roger
My Feedback: (43)
Roger,
I'm using the icon 'insert image' which then allows me to select image on my hard drive (the 3rd last option of icons displayed while in edit mode). I have always used this procedure in the past and it stopped working about 3 weeks ago.
What method are you using (be specific on procedure).
thanks,
Sam
thanks,
Sam
Roger,
thanks,
Sam
thanks,
Sam
If you are posting more than one photo, after the first photo appears in the bottom panel again select "Add Files", Choose another photo from your hard drive or other devise, "Highlight the Photo", select "Open", select "Upload", the photo will appear in the bottom panel. Select "Add Files" for the next photo and repeat sequence until all the photos you what posted have been selected and are showing in the bottom panel then select "Done" then select "Submit Reply", you are done. Make sure you have completed your message that you want folks to read before you select "Submit Reply".
Roger
Well, that's a kick in the rear. I don't know what to suggest, it may be that a setting was changed on you computer without you realising it? Sorry that I cannot help in correcting the problem with your photo posting!
Testing with a different attachment setting.
Roger
Roger
My Feedback: (43)
Roger,
bummer.
thanks for trying.
After sending 3 messages to the web site without a response, I need to find a monitor's handle and ask him.
The 'contact us' must be ignored!
My name used to show in the upper right hand when I was logged on. Now, it says I'm logged in but no name shows.
Sam
bummer.
thanks for trying.
Sam
GA
hey Sam,
I have the same problem. I tried to post two pics on HPA's (Paul's) thread about the ODP event next week. The pics don't show up just on attachment which you then have to click on to get the pic.
pain in the butt. See you at ODP. now it's working. Go figure!!!!!
John
John
Roger,
bummer.
thanks for trying.
Sam
bummer.
thanks for trying.
Sam
I confirmed this by testing, I removed the check from the show images block and posted a photo and it posted the photo as an attached image. I then went back and put the check back in the show images block and posted another photo and it posted as an attached thumbnail as per normal photo.
Roger
My Feedback: (43)
test 4
[ATTACH]2172184[/IMG]
Just got back from Elkhart's flyin and still not working.
Here's the options that were already checked:
Visible Post Elements:
mine has show images versus show image block.
Weird system and no one that works for this web site seems to care to responding.
The system is also not notifying me when there are posts on my thread. They seem to have hosed my entire settings.
Sam
- Show Signatures
- Show Avatars
- Show Images (including attached images and images in [IMG] code)
Sam
My Feedback: (43)
I've sent the following message to monitor barracudahockey; see how long, if any response is made as I also sent another message to a monitor (failed to write down the name) a few days ago with no reply.
I've sent 3 messages to 'contact us' and one to a monitor with no response in the last 3 weeks.
I've not been able to post pictures and my profile shows it should :
The only thread that works is the F4U thread:
http://www.rcuniverse.com/forum/rc-w...sembly-57.html
All other threads only will do attachments, ie:
Blown up Ziroli P-47:
road trips 2016:
http://www.rcuniverse.com/forum/rc-w...-2016-a-3.html
- Show Signatures
- Show Avatars
road trips 2016:
My Feedback: (13)
Another site I visit is having picture posts/link problems. A portion of a post from one of their moderators:
"Explore is actively working with Disqus on the problem of posting pictures from your device. Disqus is currently only accepting pics from a link and not from your computer."
Odd. appears to be somewhat similar problem, but not quite the same.
Brian
Brian
So, here at RCU the web site is hosted on a number of servers. The forums are a huge database that's segmented among several servers. The belief is that one of those servers is causing the issue, thus explaining why content physically hosted on one server may display correctly while threads containing content hosted on another server may be problematic.
Anywho, as I said before, tech is working on it.
