Mounting that dreaded lead to balance your Warbird.
My Feedback: (427)
It came time to balance my recently completed ESM 89 in. Spitfire. After setting up the balance stand I realized I would need 2 1/2 lbs. of lead to balance the plane. Glueing this amount of lead to the cowl would not work. I came up with this mounting system utilizing the standoffs on the DLE 55 engine. The lead cradle is made from mild 1/8 in. steel 3/4 of an inch wide. This bends very easy and is very strong. I made two straps for each side and joined them with 4 in. 1/4 in. bolts. I then used metal hose clamps to anchor everything down. Pictures explain my setup. Cowl now just bolts on with no strain and the lead is right out in front where you get the most benefit.
Fred
Fred
Fred, I’m not a mechanical engineer and maybe there is one watching this forum. I’m an electrical engineer with a little ME background. Your ballast has added a significant amount of weight to an already loaded structure, the standoffs. They are not as rigid a structure as they appear. They contribute to a cantilever effect which has been extended. It is susceptible to twisting and bending as the engine vibrates. I may be all wrong and hopefully full of BS. I would like to find out. Dan.
My Feedback: (427)
Hi Dan and Spaceworm,
Both points are valid. When I stand back and look at this setup , looks like a lot of strain on the engine mounts. I think I will set it up as Spaceworm suggests. I'll try to get this done tomorrow and post more pics. Thanks for the input , guys.
Fred
Fred
I agree that the lead mounted that way may overstress the engine mounting. I would remake the side brackets so that they are sandwiched between the standoffs and the firewall, rather than forward of the engine. That should take the cantilevered effect of the weight off of the standoffs. Good luck.
My Feedback: (427)
Hi Dan,
I'm a big advocate of the G 62. Unfortunately I would have ended up with no cowl. I always use the G 62 with cup mount spring starter and pitts wraparound muffler in my Warbirds when I can for that very reason plus the reliability and no extra ignition battery. I guess I should build only radial engine fighters with big round cowls. LOL
Mounting lead to the engine will load the engine mounts more on for example landing and high G, but in normal flight it will probably dampen the vibrations from the engine.
Fred
Fred
My Feedback: (427)
Here is my new mounting set up. I made two 1/4 in. aircraft ply extensions at the base I epoxied two 3/8 in. oak blocks. I then pegged the blocks with 1/4 hardwood dowels. I epoxied and doweled the extension arms to the firewall. Everything else is the same as far as mounting clamps and 1/4 in. mounting bolts.
Fred
Fred
Roger
My Feedback: (427)
OK, Roger. Thanks for the heads up. I emailed Tomas , at VQ models to see if there was an addendum to the CG in the manual.. Where did you get the 137 mm CG?
Fred
Fred
The 157mm CG measurement explains why you only require 2 & 1/2lbs to meet CG of 157mm. Do not attempt to fly at 157mm, the manual is quoting the most aft CG point! The Spitfire will be difficult to control due to being very pitch sensitive using the elevators at 157mm.
Roger
Roger
The wing chord is measured from the widest part of wing usually where it attaches to the fuselage. Measure the width of the wing from the leading edge to the trailing edge of the wing, the total measurement is the chord of the wing.
The ESM Spitfire wing has a chord measurement of 508mm (20 inches).
To calculate the actual forward and aft CG points for the ESM 85" WS Spitfire.
508mm x 25% = 127mm, this will be the minimum forward CG point.
508mm x 30% = 153mm, this will be the maximum rear CG point.
As long as the CG is within 127mm to 153mm, the aircraft will fly but the performance and stability of the aircraft will depend on where you set the CG between the forward and aft CG locations.
Based on these measurements, I have set the CG on my ESM Spitfire at 137mm for the first flight. After the first flight I can adjust the CG more forward or more aft to suit my style of flying and how my Spitfire performs/reacts during flight maneuvers, landings etc..
I chose the CG as 137mm because it is approximately mid way between 127mm and 153mm and should be an ideal location for the CG on the maiden flight. I selected mid way CG's with my other two H9 Spitfires and the maiden flights were stress free and enjoyable. One can never go wrong when using the MAC 25% & 30% CG rule when identifying the correct CG range on an aircraft!
Roger
Just for your info, my RC flying club held a giant aircraft fun fly two months ago when two visiting flyers from different clubs arrived with ESM 50cc Spitfires. I talked with both flyers before they flew and asked them how they liked their Spitfires. One said he really enjoyed flying his because it handled so well in flight and was easy to land etc. The other flyer said he was always nervous when flying his, said it was hard to control and it was a handful during landing.
I watched both Spitfires with great interest while they flew, one flew very nicely, smooth just like a Spitfire should, the other flew crappy, very pitch sensitive and the landing was almost a disaster. I asked the flyer who flew the Spitfire that handled nicely what CG location he had selected, he said 140mm. I asked the other flyer the same question and he answered his CG was in accordance with what was listed in the assembly manual, 153mm. I recommended that he should move the CG forward which would eliminate the pitch sensitive elevator effect. He was not very receptive to my recommendation and said he was just about fed up with the poor flying qualities of the Spit and said he would either sell it or crash it to get rid of it. Amazing that some flyers do not acknowledge that the CG could be set in the incorrect location, even when elevator pitch sensitivity is so pronounced.
Roger
