Fokker RC 1/4 FW 190a
#60
awesome terry, this build log has been really good reference for my build. looking at this build log and the other ones out there i find that many builders have been requesting a building material list. the list would make these kits much more inviting to more novice builders.
#61
Wing stringers: A8 1/4
stringer 6x12mm (1/4 inch x 1/2 inch) 4 pcs 126 cm (49.6inch) long
stringer 6x6mm (1/4 inch x1/4 inch) 2 pcs 656 cm ( 258inches) long
stringer 6x6mm (1/4 inch x1/4 inch) 4pcs 715 cm ( 281.4 inches)long
stringer 6x6mm (1/4 inch x1/4 inch) 4pcs 130 cm (51.1inches) long
stringer 6x6mm (1/4 inch x1/4 inch) 2pcs 110cm (43.3) long
stringer landing gear 16x16mm (5/8 inch) 100cm (39.4 inches) long
stringers Fuselage A8
stringer 6x6mm (1/4 inch x1/4 inch)2pcs 185 cm (72.8") long
stringer 6x6mm (1/4 inch x1/4 inch)4pcs 197 cm (77.5") long
stringer 6x6mm (1/4 inch x1/4 inch) 2pcs 212 cm (83.4") long
stringer 6x6mm (1/4 inch x1/4 inch) 4pcs 96 cm (37.7") long
stringer 6x6mm (1/4 inch x1/4 inch) 2pcs 35 cm (13.7") long
stringer 6x6mm (1/4 inch x1/4 inch)10pcs 35 cm (13.7") long
stringer 6x6mm (1/4 inch x1/4 inch) 2pcs 23 cm (9") long
BALSA A8 1/4
18 sheets 3mm (3/32 inch) balsa for fuselage and 24 sheets 3mm (3/32 inch) for wings 100 x 1000 mm sheets European standart
STRINGERS FUSELAGE 6x6mm (1/4 inch x1/4 inch) A8 1/4 -2820 cm (1110.2")
Stringers wings 6x12 (1/4 inch x1/2 inch inch) - 508 cm (200")
Stringers wing 6x6mm (1/4 inch x1/4 inch) -1176 cm (463")
BALSA A8 1/4
#62
#73
I hope to get the motor run in on the test stand soon. going to go by the book and run 4 gallons through it.
