CY models 98" WS C7 Caribou
Gentlemen - l am finishing up this C7 Caribou and the instructions are way off for flight control travels - specifically ailerons and elevator travel, anyone have any experience with this model? -rudder travel l can tweak as needed - thanks Bill
Warbirdz - Can't help you with your question ... but I would like to know where you got your Caribou because I would like to have one. Does it have a flat or glossy finish? Thanks
I got the Caribou from TexasRCPlanes - however it requires much work even as an ARF- cowls and nacelles are small making eng mounting difficult - l am using Zen G20's - unless you choose glow or electric eng's hang out of cowls regardless of which gas engines you choose- tight fit in nacelles for ign units and fuel tank -using 12 oz tanks - formers in fuse not installed very well, used additional epoxy to correct issue -will put some pics up this weekend -
Want to go electric - 2 x AXI 4130/16 motors each having a 6S Lipo (maybe a 5S Lipo).
Sorry for going off topic.
