Ziroli P-61 plan reduction
I want to reduce the plans down to a scale that a pair of .91 4 strokes can fly it with. Any ideas what scale that could be? They are 1/7th scale and use about a 50-60CC engine. I plan to build this scale, have the wood cut, but that is quite some time down the road and want to try a much smaller one first as a sport scale.
That comes out to about 1/10th scale, so the next step is to determine the reduction from the plans and get some copies made at the reduced size and go from there. I have a pdf of a Sterling P-61 that could be blown up as well, but it is pretty marginal for powered flight and would need some modifications to make it work. I can see quite a few places on the Z plans where I can lighten the plane, and use CF in some areas too. Since it would be sport scale, I can go with the long aileron version wing with minimal flaps and fixed gear.
