Reload this Page >
Meister 1/5th P-47 with Fiberglas fuselage, a rebirth of a build!
Reply
Old 03-19-2017, 03:21 PM
TonyBuilder
TonyBuilder's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Progress
I got a start on the wing. Starting is the hardest part. It usually takes me a couple days to get going but once going things move right along.
I am building with the spare in instead of making the pocket and then gluing it in when both wing laves are done. I like that I get positive gluing of all parts to the main spar. got the splice done first thing.
then I glued the main spart to it along with rib 1
Then one rib at a time along with the TE for the flap and the front spar.
On the first build the gear block at rib 5 is to high and I set it so the gear plate was at the top of the rib block so I cut it down this time.
I wont glue it in yet, I want to see how the gear sits first.
The wing tongue does not sit right in rib 1. The tongue is 1/4 and the slots in rib 2 are 1/4 but the slot in rib 1 is almost 3/8 so alignment is impossible without doing both sides at the same time. so I will do that when I start the other side.
not sure why it is not cut right but NP, I can get it later.
This is a good start and things will pick up now that I have broken ground.
TB
TonyBuilder is offline
Old 03-26-2017, 02:25 PM
TonyBuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Got some wing progress, left wing is all framed up.
I like to do pressure blocking so the front spar gets webbing all the way to the tip both sides. This really helps to keep the wingtip flat during framing and sheeting.
I also do that on the LE.this also helps to keep the wing flat during the sheeting as the tips not floating out there. 1/8 for the blocking that also straitens out the TE ribs as they do not line up and you would have a wavy sub LE.
The blocking gets faced with 3/23 balsa.
I added some balsa blocking at the ribs that the CF skins will end on so I have plenty of room and surface to glue the skin to.
The center ribs are glued in and the tongue. There is a 1/16 gap in the slot for the tongue at the top so I glued in a piece of ply in to fill the gap and help fuse the two pieces together.
I will sheet the top next then start on the other side.
TB
Old 03-28-2017, 05:39 PM
TonyBuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I am working on the prototype Fowler flap hinges.
I am making them beefier then what I have seen as they can be notorious for slop.
With the wider mount I think that will help stiffen it up instead of just one mount bracket.
1/16" laminated G10 for the main arm.
So fare it is pretty stiff with no slop on the hinge.
figuring the point of connection and how to mount the hinge to the TE of the flap pocket.
This portion is the move out action.
Once I am good with this I will work on the second part the control arm that moves the flap down.
the look from the bottom when the flap is up.
Still a bit to do as I am only in the design phase.
TB
Old 03-30-2017, 06:03 PM
TonyBuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Putting the prototype together and working on the linkages.
Duel linkages and dual control horns as I do not want the control horn that is on the flap right on top of the hing so two horns works just fine.
1/4 x 3/8 sealed flange bearings for the rod.
The linkages are easy to adjust and I am still working on the best position for the rod control horns.
The 1/4 rod will either be carbon fiber or aluminum. The servo arm on the rod will be a single at the end of the rod and in the belly of the wing.
This is just a rough mock up but it shows me the linkages and control horns, how they are positioned and located. Next I will see how it will fit in the wing.
This will be the same on all three hinges, not just one hinge. That should help tighten it all up.
here is a short video
youtu.be/U9iKXPiXrlg
TB
Old 04-01-2017, 11:12 PM
corsair 59
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
how do you like your meister p-47 I am thanking about getting one full wood kit to build after I build my TF p-47 kit?
corsair 59 is offline
Old 04-02-2017, 07:02 AM
  #31
TonyBuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I love it, it allows so much more as to detailing and it flies really well even heavy.
It is more of a builders kit as it does not have the instructions a TF will have and you have to adjust a few things but it builds as simple as you like or as complicated as you like.
TB
Old 04-03-2017, 10:40 AM
  #32
corsair 59
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
keep up the good work on your p-47. keep posting the gerat pics it has given me lots of good ideas for my build.
Old 04-09-2017, 04:03 PM
  #33
TonyBuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ok, so I glued in some additional blocking at the LE for the FG skin. Also for the gear ribs.
Sheeting is done, as much as I want until I work on the flap and aileron.
I put an additional row of balsa so I could hold back the wing skin from the TE of the flap and aileron. I will finish those out with the flap and aileron, G-10 for the TE.
So I'm doing the flap and aileron a little different then you normally would. Instead of framing it up and sheeting it, then gluing the solid balsa block and then shaping and sanding...sanding...sanding I am trying the Pink Panther foam from HD. I can get a 4'x4'x 1" piece for $10. The pink is solid, light, and sand so much easier then solid balsa block. It finishes out very smooth too.
I cut the main shape on the table saw then glued a couple pieces together to finish it out. I glued it all to the 1/8" balsa bottom sheet to give it the profile and some rigidity.
I little fine tuning and some filler to fill in any low spots.
This is very light and took a fraction of the time then if I were to frame it up traditionally.
The bottom is 1/8" balsa.
This was a test (prototype) and the results are very good so I will do the aileron like this next.
I will do the TE now that the flap is shaped.
TB
Old 04-10-2017, 02:41 PM
  #34
TonyBuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Got the aileron shaped today. This really goes quick, the foam sands very easy but has a very smooth finish. this is just a rough shape as I need to finish the TE so I don't over sand the surfaces.
I need to cut the robs so I can fit the aileron in its place.
The line you see was my profile gauge. I will fill it with filler before I glass. That line is also were the stock kit aileron ends, you can see how much bigger the scale aileron is.
some fine tuning and they are ready to go
TB
Old 04-13-2017, 03:59 AM
  #35
TonyBuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Getting a look at the fiberglass fuselage. Quality looks good with only a few minor defects. This will be a very good canvas to work from.
Belly pan looks good.
Fuselage is big!
Panel lines look good.
Seam joints will need a little work, nothing the evercote wont fix.
Detailing is nice and will save some time.
Inside.
Tail section.
Nice!
Lighting is not to good, I will be improving that soon.
I'm very pleased with this fiberglass fuselage and this will move things along, time to get busy
TB
Old 04-14-2017, 10:44 PM
  #36
corsair 59
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
fuse looks great looking forward to see how it come out. I will post some pics of my TF arf p-47 when I finger out how to post them it will have saito 60 radial for power. what do thank of this engine for power?
Old 04-14-2017, 11:22 PM
  #37
corsair 59
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
here are a couple pics of my p-47.
ID:	2209743   Click image for larger version
ID:	2209744   Click image for larger version
Old 04-15-2017, 05:07 AM
  #38
TonyBuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Is it glow or gass, it will fly the plane scale but I flew mine with a DLE85, all depends on the weight of the plane, at 24lb you will be ok!
TB
Old 04-15-2017, 05:23 AM
  #39
corsair 59
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
it is gas I plan on running 22x10 or 23x8 prop gas is the only way to go.
Old 04-15-2017, 06:19 AM
  #40
TonyBuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
So similar performances as a DLE55 but not as strong as its 4S. That will be nice, a few have flown with thus engine with success.
TB
Old 04-15-2017, 09:28 PM
  #41
blkbird
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
IMHO the best counterweight for a tail heavy airplane is a Heavier more powerful engine!!!!
blkbird is offline
Old 04-16-2017, 01:04 PM
  #42
corsair 59
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I like the sound of the saito and with my batteries up front I hope I don't need any weight.
Old 04-22-2017, 05:08 AM
  #43
TonyBuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I wonder what this is for [ATTACH]2210808[/IMG]
[ATTACH]2210809[/IMG]
Wing framing continues!
TB
Old 04-22-2017, 12:23 PM
  #44
TonyBuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
So I had Chad cut me a new test set of fowler flap prototype at 150% of the original size. The last prototype was 130% and I felt it was to small so now I am tinkering with it.
The main arm is bigger and longer. It needed to be longer. The secondary arms, one in the center that goes from the main arm and attaches to the wing is a little longer so the hinge point is at the top of the wing.
[ATTACH]2210991[/IMG]
The second arm is the same length so no modification there.
[ATTACH]2210992[/IMG]
I did add a extension to the main arm at the end so I could attach the linkage without having to mount to the pivot and connection point of the inner link.
I am doing a different mount that will allow me to mount the hinge to the top of the wing inside the wing instead of at the face of the LE of the wing. This gives me an easier install and puts the pivot point closer to the top of the wing.
[ATTACH]2210993[/IMG]
I think this will work very well, now I can have Chad go into full production [ATTACH]2210994[/IMG]
[ATTACH]2210995[/IMG]
Video version.
TB
ID:	2210991   Click image for larger version
ID:	2210992   Click image for larger version
ID:	2210993   Click image for larger version
Old 04-29-2017, 12:25 PM
  #45
TonyBuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Been doing grunt work getting the right wing half to where the left wing half is, top is all sheeted.
Framing is completed.
[ATTACH]2212331[/IMG]
[ATTACH]2212332[/IMG]
As you can see i use a lot of blue tape. Helps to keep me from over sanding the soft balsa ribs.
[ATTACH]2212333[/IMG]
[ATTACH]2212334[/IMG]
[ATTACH]2212335[/IMG]
Makes for easy sanding.
[ATTACH]2212336[/IMG]
High spots are easily presented.
[ATTACH]2212337[/IMG]
Ready for the top skin.
[ATTACH]2212339[/IMG]
I don't like the center tongue, despite all my finagling it is still off center as to being level with the wing level. [ATTACH]2212341[/IMG]
I'm considering using two 3/8" aluminum dowels. I will look at that when I flip the wing over.
[ATTACH]2212343[/IMG]
[ATTACH]2212345[/IMG]
rear bolt plate is in on the right side, that will complete the top of the wing.
[ATTACH]2212347[/IMG]
[ATTACH]2212349[/IMG]
Once I do the aileron and flap I will be all caught up to the left wing, then a break from the wing as I will do the tail feathers next.
TB
ID:	2212331   Click image for larger version
ID:	2212332   Click image for larger version
ID:	2212333   Click image for larger version
ID:	2212334   Click image for larger version
ID:	2212335   Click image for larger version
ID:	2212336   Click image for larger version
ID:	2212337   Click image for larger version
ID:	2212343   Click image for larger version
ID:	2212345   Click image for larger version
ID:	2212347   Click image for larger version
  #46
TonyBuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Been doing grunt work getting the right wing half to where the left wing half is.
[ATTACH]2212338[/IMG]
[ATTACH]2212340[/IMG]
[ATTACH]2212342[/IMG]
[ATTACH]2212344[/IMG]
[ATTACH]2212346[/IMG]
[ATTACH]2212348[/IMG]
[ATTACH]2212350[/IMG]
[ATTACH]2212351[/IMG]
I don't like the center tongue, despite all my finagling it is still off center as to being level with the wing level. [ATTACH]2212352[/IMG]
[ATTACH]2212353[/IMG]
[ATTACH]2212354[/IMG]
[ATTACH]2212355[/IMG]
[ATTACH]2212356[/IMG]
TB
ID:	2212338   Click image for larger version
ID:	2212340   Click image for larger version
ID:	2212342   Click image for larger version
ID:	2212344   Click image for larger version
ID:	2212346   Click image for larger version
ID:	2212348   Click image for larger version
ID:	2212350   Click image for larger version
ID:	2212353   Click image for larger version
ID:	2212354   Click image for larger version
ID:	2212355   Click image for larger version
Old 05-04-2017, 03:18 PM
  #47
TonyBuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Working on the elevator now.
[ATTACH]2213180[/IMG]
[ATTACH]2213181[/IMG]
Still have some shaping and sanding to do once I get them both done.
I wont sand the tip anymore until I get the tip of the stab shaped.
[ATTACH]2213182[/IMG]
[ATTACH]2213183[/IMG]
I will getting other side done now that I see this is working well.
[ATTACH]2213184[/IMG]
TB
ID:	2213180   Click image for larger version
ID:	2213181   Click image for larger version
ID:	2213182   Click image for larger version
ID:	2213183   Click image for larger version
Old 05-05-2017, 03:53 AM
  #48
TonyBuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ok, confession time...the foam parts are just plugs as I will be doing them in composite layups, carbon fiber stab, elevator, rudder, ailerons and flaps.
I have considered making molds but I do not want to spend the $500+ setting up with vacuum pump and so on. I don't want to do the standard gel coat and arex foam core, that method is to soft for my liking.
I will do a surface layup over the plugs, top and bottom. Then add hinges and join them together. I do not want surface detailing as I am doing aluminum tape finish so I just need a smooth finish, I can achieve that!
I know this is not a conventional way of making compost parts but I think I can get what I want with this method. We will see.
I am not concerned about weight and I'm not doing this as a weight thing. I build heavy and I'm ok with that, I figure with all the detailing I will be at the 60lb range, not bad considering my TFGS P-47 was close to 40lb and flew (flies) great. Yes there is a price to pay for "heavy metal" but I can deal with that.
The composit parts are just another way to build and a new and exciting phase for me.
I will do one of the elevators as a test. Nothing to loos but a bit of foam.
TB
Old 05-06-2017, 05:17 PM
  #49
TonyBuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
On the docket for tomorrow, finish the stab and make it ready for layups, do the same on the elevators and rudder.
TB
Old 05-07-2017, 06:23 AM
  #50
CRJDriver
My Feedback: (57)
CRJDriver's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looking good Tony!
CRJDriver is offline
Contact Us Archive Advertising Cookie Policy
