Road trips 2017
Reply
Old 07-29-2017, 05:34 PM
  #101
samparfitt
My Feedback: (43)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
TF P-47 ARF (cont)
Once in awhile you get lucky!
Put her all together to test all surfaces and engine test: all's good with no changes with even the engine trim exactly where I want it. 6500 RPM's.
Learning curve with monocote:
Left her in the sun to bake and wrinkle so I could iron them out. Found those big wrinkles need a lite touch with the iron so one doesn't make permanent folds in the surface.
CG needed a 1/16" lead sheet 3"X12".
Out to the field, tomorrow, to maiden her.
Name:	P-47 top flite 85 ARF 38.JPG
ID:	2226153   Click image for larger version
Name:	P-47 top flite 85 ARF 39.JPG
ID:	2226154   Click image for larger version
Name:	P-47 top flite 85 ARF 40.JPG
ID:	2226155   Click image for larger version
Name:	P-47 top flite 85 ARF 41.JPG
samparfitt is online now
Old 07-29-2017, 06:36 PM
  #102
aghost
My Feedback: (13)
aghost's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sure went together quickly. Good luck with the maiden.
Brian
aghost is offline
Old 08-02-2017, 03:23 AM
  #103
samparfitt
My Feedback: (43)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Maiden,
Got her down in one piece with no damage but things did not go well. After how well the TF corsair flew, I was expecting the P-47 to fly great.
First off, I had way too much 'up' in the elevator and the plane took off in probably 20', which was scary.
The plane was very 'twitchy' and, one time, I got her too slow and she snapped: fortunately, I was high enough and recovered.
On landing, I put the flaps down on final approach and she ballooned on me so I went around and landed without flaps. Came in hot but landed OK: thick grass and, just at the end, when she was going slow, she just settled on her nose, with no damage to plane or prop.
The top hatch came off, couldn't find it but only cost 20 bucks for a new one.
I must be doing something wrong as others have the P-47 and they fly great.
Old 08-02-2017, 05:38 AM
  #104
samparfitt
My Feedback: (43)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Every once in awhile, you do something stupid!
Been flying all year with no problems: until Sunday.
After the maiden on the P-47, decided to fly the corsair.
On take off, it went from the paved runway to the grass and I thought she would be OK, but the grass caught the left wheel and pulled the gear mount out.
A little learning curve with these lite ARF's that weigh about half of what my Ziroli weigh plus smaller wheels. I also find that clubs with paved runways don't maintain the grass as well as clubs with all grass so the grass had a lot of drag.
Anyway, both wood mounts pulled out. I think the FG cloth glassing in the wheel well helped reduce damage to just the mounts.
TF put nylon rods in the mounts to ribs so they did a good job of securing them: I just put too much pressure on them.
The nylon rods were keeping me from pushing the mounts back onto the ribs so I had to cut some holes in the sheeting for clamping purposes. There wasn't room for regular C clamps so these 'jaw' clamps did the job very well.
Wanted to make sure the mounts were secure so I used hysol to secure them.
Name:	F4U corsair top flite 73.JPG
ID:	2226574   Click image for larger version
Name:	F4U corsair top flite 74.JPG
ID:	2226575   Click image for larger version
Name:	F4U corsair top flite 75.JPG
ID:	2226576   Click image for larger version
Name:	F4U corsair top flite 76.JPG
Old 08-02-2017, 05:48 AM
  #105
samparfitt
My Feedback: (43)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
TF P-47 ARF
Made a 'wing' bag for the wing and some for the tail surfaces as I always seem to be hitting those when loading the trailer! Some felt liner inside allows use of the 'hook' side of velcro to be used to keep the tail surface covers from sliding off the plane.
While leaving the hatch in the sun to remove wrinkles, the hatch widened and wasn't fitting properly on the fuse. I cut a slot in the formers and re-glued the formers. It's possible this broke which would cause the hatch to fly off in flight.
Name:	P-47 top flite 85 ARF 42.JPG
ID:	2226578   Click image for larger version
Name:	P-47 top flite 85 ARF 43.JPG
ID:	2226579   Click image for larger version
Name:	P-47 top flite 85 ARF 44.JPG
Old 08-03-2017, 08:47 AM
  #106
samparfitt
My Feedback: (43)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
TF P-47 ARF
Got some help from pilots who have the TF P-47.
Suggested I add more nose weight so I doubled the weight with another 1/16"X3"X12" of lead.
Also, need down elevator of about 1/16" and 1/8" for half and full flaps.
They suggested 10% and 20% mix but I needed 20% and 30% to get maybe a 1/16" and about 3/32" on full flaps.
Sinked the elevator to have the same 2 second servo movement as the flaps.
Used some expansion foam in the belly pan in case I need to belly land her.
Name:	P-47 top flite 85 ARF 46.JPG
ID:	2226788   Click image for larger version
Name:	P-47 top flite 85 ARF 47.JPG
ID:	2226789   Click image for larger version
Name:	P-47 top flite 85 ARF 48.JPG
ID:	2226790   Click image for larger version
Name:	P-47 top flite 85 ARF 49.JPG
Old 08-03-2017, 03:12 PM
  #107
samparfitt
My Feedback: (43)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
TF P-47 ARF basic panel lines and rivets using a sharpie.
Fuse is next.
Name:	P-47 top flite 85 ARF 50.JPG
ID:	2226835   Click image for larger version
Name:	P-47 top flite 85 ARF 51.JPG
ID:	2226836   Click image for larger version
Name:	P-47 top flite 85 ARF 52.JPG
ID:	2226837   Click image for larger version
Name:	P-47 top flite 85 ARF 53.JPG
Old 08-04-2017, 04:52 AM
  #108
samparfitt
My Feedback: (43)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
TF P-47 ARF.
Half the fuse is done with panel lines and rivets.
As with the F4U, nothing fancy but at least it detracts from the fact that the plane has monokote!
Name:	P-47 top flite 85 ARF 54.JPG
ID:	2226884   Click image for larger version
Name:	P-47 top flite 85 ARF 55.JPG
ID:	2226885   Click image for larger version
Name:	P-47 top flite 85 ARF 56.JPG
Old 08-06-2017, 05:44 AM
  #109
samparfitt
My Feedback: (43)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Aug 5-6, Circus at Butler county airport in Butler county, Ohio.
Miles: 10.
My local GCRCC club puts on an annual show for the general public each year (57 years).
Very high participation by club members using their planes for the 11:30 am - 4 PM show with events changing every 8-10 minutes for the public. Bulk of donations given to a local charity ($6500 this year). About 200 planes used by the members.
From Saturday's crowd, I'm guessing around 3000-4000 came to the show on Saturday (too early for Sundays show).
Name:	circus 2017 01.JPG
ID:	2227044   Click image for larger version
Name:	circus 2017 02.JPG
ID:	2227045   Click image for larger version
Name:	circus 2017 03.JPG
ID:	2227046   Click image for larger version
Name:	circus 2017 04.JPG
ID:	2227047   Click image for larger version
Name:	circus 2017 05.JPG
ID:	2227048   Click image for larger version
Name:	circus 2017 06.JPG
ID:	2227049   Click image for larger version
Name:	circus 2017 07.JPG
ID:	2227050   Click image for larger version
Name:	circus 2017 08.JPG
Name:	circus 2017 09.JPG
ID:	2227052   Click image for larger version
Name:	circus 2017 10.JPG
Old 08-06-2017, 05:47 AM
  #110
samparfitt
My Feedback: (43)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Circus (cont)
Name:	circus 2017 11.JPG
ID:	2227054   Click image for larger version
Name:	circus 2017 12.JPG
ID:	2227055   Click image for larger version
Name:	circus 2017 13.JPG
ID:	2227056   Click image for larger version
Name:	circus 2017 14.JPG
ID:	2227057   Click image for larger version
Name:	circus 2017 15.JPG
ID:	2227058   Click image for larger version
Name:	circus 2017 16.JPG
ID:	2227059   Click image for larger version
Name:	circus 2017 17.JPG
ID:	2227060   Click image for larger version
Name:	circus 2017 18.JPG
Name:	circus 2017 19.JPG
ID:	2227062   Click image for larger version
Name:	circus 2017 20.JPG
Old 08-06-2017, 05:48 AM
  #111
samparfitt
My Feedback: (43)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Circus ((cont))
Name:	circus 2017 21.JPG
ID:	2227064   Click image for larger version
Name:	circus 2017 22.JPG
ID:	2227065   Click image for larger version
Name:	circus 2017 23.JPG
Old 08-06-2017, 06:36 AM
  #112
samparfitt
My Feedback: (43)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Poor decision:
Having the gear valve and servo 'sticking out' on the wing creates storage problems in the trailer so it was moved to the fuse along with a electrodynamic's quick connect was used for the flaps and ailerons.
Name:	F4U corsair top flite 78.JPG
Old 08-07-2017, 04:38 AM
  #113
aghost
My Feedback: (13)
aghost's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Both the club participation and local turnout are quite impressive. That takes a lot of work.
Brian
aghost is offline
Old 08-10-2017, 12:13 PM
  #114
samparfitt
My Feedback: (43)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
TF P-47 ARF decals.
After letting her sit in the sun a few times, I think all the wrinkles are 'gone' so the decals were applied.
There's, like, a double layer of plastic, plus the paper on these decals. Soaking for a good hour resulted in no easy separation.
Had to use tweezers on the corner and scrape the 2nd layer of plastic and paper from the top layer decal.
Putting the 'pealed' decal back in the water allowed easy positioning of the decal on the surface. Some paper towels and bondo applicator removed the sub surface water.
Compound curves required a new X-acto knife to make multiple cuts along the edge for a good fit: as along the rudder TE.
The cowl decal also required some multiple cuts around the edges to get a clean finish with no wrinkles. The decal cuts overlaid each other to, virtually, make the cut invisible (and better than a wrinkle!).
The stars-n-stripes along the turbo charger inlets also needed cutting to lay flat over it.
And, yes, I put the VF up front on both sides and the T to the rear, as it is suppose to be (contrary to 'normal' logic and making it the same 'left to right').
Name:	P-47 top flite 85 ARF 57.JPG
ID:	2227570   Click image for larger version
Name:	P-47 top flite 85 ARF 58.JPG
ID:	2227571   Click image for larger version
Name:	P-47 top flite 85 ARF 59.JPG
ID:	2227572   Click image for larger version
Name:	P-47 top flite 85 ARF 60.JPG
ID:	2227573   Click image for larger version
Name:	P-47 top flite 85 ARF 61.JPG
Old 08-13-2017, 05:09 AM
  #115
samparfitt
My Feedback: (43)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
USS Gerald Ford new 21 century aircraft carrier.
Old 08-22-2017, 04:15 AM
  #116
samparfitt
My Feedback: (43)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Aug 17-19, Warbirds and classics at Fond Du Lac, Wisconsin.
miles: 550
An all grass 1300'X300' runway.
For this multi-day events, I got there on Tuesday and left Sunday. Everything is set up early for flying.
Being a part of the 'warbird alliance', the trend seems to be renting large tents for your planes: fly late, leave planes and equipment in tent (with side walls) and easy, quick coverage, should rain come.
144 pilots and, needless to say, a vast array of great, unusual and 'one of a kind' planes.
Name:	FDL 2017 01.JPG
ID:	2228899   Click image for larger version
Name:	FDL 2017 02.JPG
ID:	2228900   Click image for larger version
Name:	FDL 2017 03.JPG
ID:	2228901   Click image for larger version
Name:	FDL 2017 04.JPG
ID:	2228902   Click image for larger version
Name:	FDL 2017 05.JPG
ID:	2228903   Click image for larger version
Name:	FDL 2017 06.JPG
ID:	2228904   Click image for larger version
Name:	FDL 2017 07.JPG
ID:	2228905   Click image for larger version
Name:	FDL 2017 08.JPG
Name:	FDL 2017 09.JPG
ID:	2228907   Click image for larger version
Name:	FDL 2017 10.JPG
Old 08-22-2017, 04:18 AM
  #117
samparfitt
My Feedback: (43)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
FDL (cont)
Name:	FDL 2017 11.JPG
ID:	2228909   Click image for larger version
Name:	FDL 2017 12.JPG
ID:	2228910   Click image for larger version
Name:	FDL 2017 13.JPG
ID:	2228911   Click image for larger version
Name:	FDL 2017 14.JPG
ID:	2228912   Click image for larger version
Name:	FDL 2017 15.JPG
ID:	2228913   Click image for larger version
Name:	FDL 2017 16.JPG
ID:	2228914   Click image for larger version
Name:	FDL 2017 17.JPG
ID:	2228915   Click image for larger version
Name:	FDL 2017 18.JPG
Name:	FDL 2017 19.JPG
ID:	2228917   Click image for larger version
Name:	FDL 2017 20.JPG
Old 08-22-2017, 04:29 AM
  #118
samparfitt
My Feedback: (43)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
FDL Wednesday pictures (cont)
Name:	FDL 2017 21.JPG
ID:	2228919   Click image for larger version
Name:	FDL 2017 22.JPG
ID:	2228920   Click image for larger version
Name:	FDL 2017 23.JPG
ID:	2228921   Click image for larger version
Name:	FDL 2017 24.JPG
ID:	2228922   Click image for larger version
Name:	FDL 2017 25.JPG
ID:	2228923   Click image for larger version
Name:	FDL 2017 26.JPG
ID:	2228924   Click image for larger version
Name:	FDL 2017 27.JPG
ID:	2228925   Click image for larger version
Name:	FDL 2017 28.JPG
Name:	FDL 2017 29.JPG
ID:	2228927   Click image for larger version
Name:	FDL 2017 30.JPG
Old 08-22-2017, 04:31 AM
  #119
samparfitt
My Feedback: (43)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
FDL (cont)
Name:	FDL 2017 31.JPG
ID:	2228929   Click image for larger version
Name:	FDL 2017 32.JPG
ID:	2228930   Click image for larger version
Name:	FDL 2017 33.JPG
ID:	2228931   Click image for larger version
Name:	FDL 2017 34.JPG
ID:	2228932   Click image for larger version
Name:	FDL 2017 35.JPG
ID:	2228933   Click image for larger version
Name:	FDL 2017 36.JPG
ID:	2228934   Click image for larger version
Name:	FDL 2017 37.JPG
ID:	2228935   Click image for larger version
Name:	FDL 2017 38.JPG
Name:	FDL 2017 39.JPG
ID:	2228937   Click image for larger version
Name:	FDL 2017 40.JPG
Old 08-22-2017, 04:39 AM
  #120
aghost
My Feedback: (13)
aghost's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Lot of nice looking planes. Thanks for the pictures.
Brian
aghost is offline
Old 08-22-2017, 04:41 AM
  #121
samparfitt
My Feedback: (43)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
FDL ((cont)
Name:	FDL 2017 41.JPG
ID:	2228939   Click image for larger version
Name:	FDL 2017 42.JPG
ID:	2228940   Click image for larger version
Name:	FDL 2017 43.JPG
ID:	2228941   Click image for larger version
Name:	FDL 2017 44.JPG
ID:	2228942   Click image for larger version
Name:	FDL 2017 45.JPG
ID:	2228943   Click image for larger version
Name:	FDL 2017 46.JPG
ID:	2228944   Click image for larger version
Name:	FDL 2017 47.JPG
ID:	2228945   Click image for larger version
Name:	FDL 2017 48.JPG
Name:	FDL 2017 49.JPG
ID:	2228947   Click image for larger version
Name:	FDL 2017 50.JPG
Old 08-22-2017, 04:43 AM
  #122
samparfitt
My Feedback: (43)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
FDL ((cont))
Name:	FDL 2017 51.JPG
ID:	2228949   Click image for larger version
Name:	FDL 2017 52.JPG
ID:	2228950   Click image for larger version
Name:	FDL 2017 53.JPG
ID:	2228951   Click image for larger version
Name:	FDL 2017 54.JPG
ID:	2228952   Click image for larger version
Name:	FDL 2017 55.JPG
ID:	2228953   Click image for larger version
Name:	FDL 2017 56.JPG
ID:	2228954   Click image for larger version
Name:	FDL 2017 57.JPG
ID:	2228955   Click image for larger version
Name:	FDL 2017 58.JPG
Name:	FDL 2017 59.JPG
ID:	2228957   Click image for larger version
Name:	FDL 2017 60.JPG
Old 08-22-2017, 09:26 AM
  #123
maddog-RCU
My Feedback: (22)
maddog-RCU's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thank for sharing the pics Sam; I was up on Friday as a spectator enjoying the flying.
I'm looking forward to the day when I don't have to do the 8-5 thing 5 days a week and I can take in and fly at the warbird events.
Need to get a trailer set up before then.
Mike
maddog-RCU is offline
Old 08-22-2017, 10:53 AM
  #124
samparfitt
My Feedback: (43)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
FDL (cont)
Got over 200 pictures to post so there should be something for everyone!
Name:	FDL 2017 61.JPG
ID:	2228978   Click image for larger version
Name:	FDL 2017 62.JPG
ID:	2228979   Click image for larger version
Name:	FDL 2017 63.JPG
ID:	2228980   Click image for larger version
Name:	FDL 2017 64.JPG
ID:	2228981   Click image for larger version
Name:	FDL 2017 65.JPG
ID:	2228982   Click image for larger version
Name:	FDL 2017 66.JPG
ID:	2228983   Click image for larger version
Name:	FDL 2017 67.JPG
ID:	2228984   Click image for larger version
Name:	FDL 2017 68.JPG
Name:	FDL 2017 69.JPG
ID:	2228986   Click image for larger version
Name:	FDL 2017 70.JPG
Old 08-22-2017, 10:56 AM
  #125
samparfitt
My Feedback: (43)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
FDL (cont)
Name:	FDL 2017 71.JPG
ID:	2228988   Click image for larger version
Name:	FDL 2017 72.JPG
ID:	2228989   Click image for larger version
Name:	FDL 2017 73.JPG
ID:	2228990   Click image for larger version
Name:	FDL 2017 74.JPG
ID:	2228991   Click image for larger version
Name:	FDL 2017 75.JPG
ID:	2228992   Click image for larger version
Name:	FDL 2017 76.JPG
ID:	2228993   Click image for larger version
Name:	FDL 2017 77.JPG
ID:	2228994   Click image for larger version
Name:	FDL 2017 78.JPG
Name:	FDL 2017 79.JPG
ID:	2228996   Click image for larger version
Name:	FDL 2017 80.JPG
Contact Us Archive Advertising Cookie Policy
