Reload this Page >
CY MODELS La-7//Evolution 160 radial
Old 11-14-2017, 09:57 AM
  #401
n8622t
My Feedback: (8)
Ignition removed and waiting....probably a week and we’ll try it again😃
ID:	2245065   Click image for larger version
Old 11-14-2017, 10:35 AM
  #402
BobH
I've had a bad ignition on my 160 and so has a friend of mine.
Bummer that they are so crappy..! Also if you wanted a spare I think horizon wanted near $800.. EKKkkkk
Old 11-14-2017, 01:05 PM
  #403
n8622t
My Feedback: (8)
hang on to your money BobH.....I called Adrian at CH Ignitions and he is in the process of making one for this engine. It would be a good idea to call him if you are interested to give him incentive that there are folks out there in need of an ignition for this engine. I will need two since I have two engines and I know two others that will also need it. It’s almost like a rescue job for me
Old 11-15-2017, 01:55 PM
  #404
n8622t
My Feedback: (8)
Excellent match for the La-7 👍👍👍
ID:	2245191   Click image for larger version
Old 11-21-2017, 09:36 AM
  #405
n8622t
My Feedback: (8)
Got my tracking number yesterday and the new ignition will be here tomorrow. While i was waiting for it, i found the mfg. website and have been emailing them about my ossues. They are very receptive so I will try thos new ignition then go from there.....hope it works
Old 11-21-2017, 02:04 PM
  #406
BobH
Who is the Mfg?
Old 11-22-2017, 06:24 PM
  #407
n8622t
My Feedback: (8)
Who is the Mfg?
check it out BobH....they upgraded the pushrods to stainless steel
  #408
n8622t
My Feedback: (8)
Home
heres the site
Old 11-22-2017, 06:27 PM
  #409
n8622t
My Feedback: (8)
Let me know if that link works
Old 11-22-2017, 08:06 PM
  #410
BobH
Thank you. yes the link works
Old 11-24-2017, 12:23 PM
  #411
n8622t
My Feedback: (8)
Old 11-24-2017, 12:24 PM
  #412
n8622t
My Feedback: (8)
2 hours 25 minutes and still running perfect
Old 11-24-2017, 02:16 PM
  #413
n8622t
My Feedback: (8)
Three hours 16 minutes run time on ground should do it
Old 11-24-2017, 06:01 PM
  #414
BobH
Looks great! I have about 2.5 running hours on mine. Some at full throttle and slightly below. I'm pretty sure mines broken in as well.
Oh did you get Stainless Steel push rods from UMS? and if so.. did you have to buy them or did they replace the older style?
Old 11-25-2017, 03:17 PM
  #415
n8622t
My Feedback: (8)
im pretty sure the SS pushrods will have to be a purchase but i plan on buying two sets. My first 160 has about 20 gallons of fuel ran through it and has never missed a lick....hope this one works as well as the first👍
ID:	2246179   Click image for larger version
Old 11-26-2017, 04:49 PM
  #416
n8622t
My Feedback: (8)
Both spinners ready for paint
ID:	2246251   Click image for larger version
Old 11-27-2017, 04:45 AM
  #417
SWORDSN
My Feedback: (13)
Is this and other CY models only available direct from China?
Old 11-27-2017, 03:07 PM
  #418
n8622t
My Feedback: (8)
Here is where i got mine
ARF airplane- Electric ARF airplanes- RC AIRPLANES- wholesale warehouse
Old 11-27-2017, 03:10 PM
  #419
n8622t
My Feedback: (8)
I also have the Cessna 310 which will also be a bash when i get to it. Id like to get the 96” Mustang too😜
Old 12-08-2017, 12:17 PM
  #420
n8622t
My Feedback: (8)
The maiden occurred last weekend and went very well. The video didn’t happen due to technical difficulties (operator). The Evo160 lifted the Model at 1/2 throttle and ran very smooth. I needed no trim whatsoever which was a wonderful surprise!!
the gear came up but the doors interfered so I put them back down during the flight. After 10 min of flight I dropped the flaps 1/2 on base then full on final....no pitch changes occurred and I left about three clicks of throttle and she settled in on a smooth glide path with a small amount of power. Winds were 7-10 on the runway heading. The La-7 came right down to the asphalt and flared without a single ballon and a gentle touchdown. This model is as easy to fly as a P-47 and it’s a definite keeper.
The bad news is that the Evo160 was making a clicking noise as she taxied back so there wasn’t any other flight made. I’m bery disappointed with the engine and it’s on its way back to Horizon
the temps for the flight day was low 70’s and the engine ran well but I decided to open up three more spots on the cowl to let more heat out. If Horizon offers my money back on the engine I’ll take it and order a moki 180....to be continued 👍👍
Old 12-08-2017, 04:28 PM
  #421
BobH
Good luck with a refund. My best guess is it's not going to happen
On the other hand what do you think the clicking noise is from?
That would be good to know..
Congrats on a successful maiden!
Old 12-08-2017, 05:21 PM
  #422
n8622t
My Feedback: (8)
Thanks BobH...there’s a problem in the cam block...they’ll have to replace the cam block to fix it so I’m just waiting to see what they do. It’s still on warranty so it’s a free one this time. This is an awesome flying model so it’s gonna have a good engine on front one way or another👍
Old 12-09-2017, 12:12 AM
  #423
warbird04
Hello Jimmy,
Congratulation for your maiden. You see that the La-7 is a perfect warbird! And yes, a moki 180 is a good idee, and will be a great performer...
Old 12-09-2017, 05:27 AM
  #424
n8622t
My Feedback: (8)
Thanks warbird....I received confirmation yesterday so Horizon has the engine. If they repair it I will be happy. The Evo160 is a real powerhouse, it will turn the same prop 900 rpm more than the moki 150 and runs about 50 degrees cooler, so I really do hope that Horizon can repari it. I have the same engine on my Stearman with 100 flights and Ive had nothing but good service from it. Oh well I guess we will see
Old 12-09-2017, 05:31 AM
  #425
n8622t
My Feedback: (8)
Originally Posted by warbird04
Hello Jimmy,
BTY warbird , thank you for sharing the CG info and flying surface movement ranges, they were perfect and nothing needed to be changed👍😃
