needing scale parts for yellow aircraft p47
Reply
Old 07-30-2017, 08:59 AM
PROSTOCK68
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default needing scale parts for yellow aircraft p47
guys I'm needing the following scale parts for my yellow aircraft p47 razorback build DUMMY RADIAL---CHIN DIVIDER---SCALE COCKPIT FOR FULL PILOT---WING PYLONS---BOMBS---BELLY DROP TANK---any help appreciated thanks
PROSTOCK68 is online now
Old 07-31-2017, 04:41 AM
IFLYBVM2
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default parts
Quote:
Let me check tonight when I get home-I may be able to help.
-Mike O.
I
IFLYBVM2 is offline
Old 07-31-2017, 05:06 AM
PROSTOCK68
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hueg thanks mike.
Old 08-01-2017, 02:25 AM
ButchPendergrass
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default p47
I have a set of pylons and drop tanks 225.00 336-978-1133
ButchPendergrass is offline
Old 08-06-2017, 03:47 PM
big fred
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Chin divider is from Meister scale, just need to sand to fit inside of cowling. Radial is made from cylinder I cast ( can send you some if you'd like), crankcase is a can of diesel starting fluid, mags are from plastic parts from prop adapters and sheet plastic. Bolts are mini from RTL Fasteners. Pylons are carved from balsa, glassed and then covered in aluminum foil.
Name:	p-47 engine and pylons 001.JPG
ID:	2227135   Click image for larger version
Name:	p-47 engine and pylons 002.JPG
ID:	2227136   Click image for larger version
Name:	p-47 engine and pylons 010.JPG
ID:	2227137   Click image for larger version
Name:	p-47 engine and pylons 009.JPG
big fred is offline
Old 08-06-2017, 03:49 PM
PROSTOCK68
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
NICE!!!!!!!!!! Which engine did you use?
Old 08-06-2017, 04:04 PM
big fred
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thank you. Cylinders are cast by myself, everything else was also made here.
big fred is offline
Old 08-06-2017, 04:17 PM
big fred
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A couple pics of the plane.
ID:	2227139   Click image for larger version
ID:	2227140   Click image for larger version
big fred is offline
Old 08-13-2017, 07:01 AM
big fred
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Making the cylinders today. If you PM your address I will get them sent out to you.
big fred is offline
Reply
Display Modes
