Balsa USA 1/3 scale Boeing Stearman PT-17/N2S-3
Reply
Old 08-27-2017, 04:36 PM
marksp
marksp's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Balsa USA 1/3 scale Boeing Stearman PT-17/N2S-3
Kicking off a Balsa USA 1/3 scale Stearman tips & tricks thread, selfishly in hopes of learning from some of the experiences from the many folks flying this beautiful airframe.
marksp is offline
Old 08-27-2017, 04:48 PM
marksp
marksp's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My project started with the following build components:
- BUSA kit w/Sierra struts
- Moki S250 ("top hat" ignition, Sparkswitch 5.5v, Emcotec fuel pump)
- PowerBox Royal SRS, Spektrum
- DuBro 50 oz fuel
- Hitec 5645MG aileron, Futaba S9156 rudder/elevator
- Axels Scale Pilot
- Duralite Sentinel A123 batteries;(2) PowerBox, (1) pumps
- AR iCharger on board charger
- Solo 32" scale prop; prop hub
marksp is offline
Old 08-27-2017, 05:01 PM
marksp
marksp's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A few build pics along my journey
marksp is offline
Old 08-27-2017, 05:24 PM
marksp
marksp's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Covering
marksp is offline
Old 08-27-2017, 05:45 PM
marksp
marksp's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dry fitting components
marksp is offline
Old 08-27-2017, 06:20 PM
marksp
marksp's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Paint booth
marksp is offline
Old 08-27-2017, 06:31 PM
marksp
marksp's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
more paint...
marksp is offline
Old 08-27-2017, 06:36 PM
marksp
marksp's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
putting color on the wings...
marksp is offline
Old 08-27-2017, 06:45 PM
marksp
marksp's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Component change
Along the way, decide to make a few changes:
- switched to Savox SV1270TG HV aileron servos
- changed from PowerBox Royal SRS + Spektrum to PowerBox Royal SRS + Futaba 7003SB Rx's
- switched from DuBro 50oz tank to (2) Extreme Flight 50oz tanks for fuel & smoke
- added Powerbox smoke pump
- switched from Duralite Sentinel A123's to PowerBox PowerPak 5.0X2 Pro batteries
- deleted AR iCharger on board charger
marksp is offline
Old 08-27-2017, 06:52 PM
marksp
marksp's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
more pics...
marksp is offline
Old 08-27-2017, 07:06 PM
marksp
marksp's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ok...now for some questions for anyone building/flying a BUSA Stearman. Need to sort out my solution for flying wires. I currently have the BUSA rods/ends as well as the BUSA sourced braided steel cable and Nicopress system. My preference is ease of setup/tear down vs "scale". My current plan is to build and fly the cables, and also build the rods which are required as templates for the custom scale flying wires offered by aeroscaleproducts-prospect_en
Any guidance recommendations to share? Is the cable setup the easiest, most practical solution?
Cheers
marksp is offline
Old 08-27-2017, 07:25 PM
marksp
marksp's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Any tips on where to source a 1/3 scale shock plaque found on fuse above the landing gear?
marksp is offline
Old 08-27-2017, 07:34 PM
marksp
marksp's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Any balancing/CG tips from anyone flying Moki S250 - any ballast required? how much? where placed? trying to pre-sort component placement
Cheers
marksp is offline
Old 08-28-2017, 06:35 AM
do335a
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
Attachment 2229673
That would be very simple to make. Do that sort of thing with great regularity.
If you PM me the dimensions and text as it's placed - a good close up pic would be perfect - I'll do one for you for free and send it your way.
do335a is offline
Old 08-28-2017, 01:40 PM
Greg Wright
Greg Wright's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Attachment 2229673
Mark,
If you could get a good quality close up of the placard i bet you could have them made by a trophy shop in real metal..
Greg Wright is offline
Old 08-28-2017, 07:21 PM
marksp
marksp's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
Originally Posted by Greg Wright View Post
Mark,
Excellent idea...thanks! That's precisely the effect I'm looking for! Like the metal plate on full scale.
I'll swing by a trophy shop to see if they can make.
Cheers
marksp is offline
Old 08-29-2017, 03:55 AM
TomCrump
TomCrump's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Some of the modeling graphics suppliers can print "metal".
If what I have in the pic is what you are looking for, it may be worth investigating.
Unfortunately, the company that provided mine, in no longer in business, or I would provide a link.
TomCrump is offline
Old 09-01-2017, 12:25 PM
okcrcpilot
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mark,
Good to hear from you and you arer making great progress with the PT-17 build. Now on to some answers. I used the recommended tail brace set-up per the plans and have been happy with the results. However, I DID NOT use the solid wire for the flying/landing wires. Rather I purchased the BalsaUSA 1/3 Scale Deluxe Nicropress Starter Set and am satisfied with the results. I have attached a couple of pictures which show the details. I bought the wire thimbles from Vogelsang Aeroscale. The business end of the wires are Sullivan Products 4-40 eye bolts (#549) and Dubro 4-40 Steel Threaded Rod Ends (#302). I purchased ” 4-40 SS socket head cap screws from Bolt Depot.
If I am not interrupted during the field assembly process, it take me 30-40 minutes to put the plane together, ready to fly. For what ever reason, it seem I always have to adjust several, if not all, of the flying/landing wires. Teardown takes half the time. Definitely not a plane I take to the field every time I want to fly, but I do put it up every 4-6 weeks.
Keep us posted on your build and let me know if I can help with anything else.
Gary
ID:	2230078   Click image for larger version
ID:	2230079   Click image for larger version
okcrcpilot is offline
Old 09-01-2017, 11:13 PM
marksp
marksp's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Gary - thanks for sharing the detail and pics. I had not considered your setup using the rods for the tail brace per the plans, but using the cable for the wings. I like that a lot!
With regards to your flying wire cables, do you also have a javelin/spreader? If so, where did you source?
Cheers
marksp is offline
Old 09-02-2017, 05:56 PM
marksp
marksp's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
String mock up to determine cable order length. 34' - wow!!!
marksp is offline
Old 09-12-2017, 08:08 PM
marksp
marksp's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
After searching and searching, I shot a note to Callie t see if she had ideas for sourcing the Stearman shock plates. She responded she had the images and can make out of realistic looking metallic adhesive material. Received today and can say they look fantastic!
Here's a pic of the shock, serial # and engine plates from Callie.
marksp is offline
Old 11-13-2017, 10:30 AM
marksp
marksp's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Celebrating the little things...
Finally have color on my rudder!
Hope to have finished and mounted soon!
marksp is offline
Reply
Display Modes
