first build and help is really needed thanks
Im almost complete on a thor brothers hawker hurrican purchased from Manzano laser Works. My my problem is that i cannot figure out how or where to put the hindges for the ailerons. I cant tell where the attachment point would go and what type of attachment should be used. I thought hinges would work but i can see how they could be installed with this design. This is my first build and im totally lost on the proper hindge and hindge point for this aircraft so any advice would be very well appreciated. thanks
My Feedback: (10)
try searching with GOOGLE and its THORN Bros
a build thread at Svenskt Modellflyg
that hurricane is pretty small 36" wingspan - I would search out how other manufactures are hinging small ailerons, a blenderm tape hinge may be the way to go.
https://www.google.ca/url?sa=t&rct=j...MLuw9dPp3jlfkZ
https://www.google.ca/url?sa=t&rct=j...7qNZicL-jDGm05
My Feedback: (60)
AZ
Is it possible that this is the Derek Micko designed 60 inch span Hurricane? If so, Derek is a regular on the scale electric forum over at RC Groups and you could contact him directly over there. There are also several build threads of that airplane on the site that may be of some use to you. RC Groups has a much more active group when it comes to the smaller scale electric models and I would highly recommend a visit if you have not already.
