TopRCModel FW-190
Reply
Old 08-11-2018, 06:52 AM
  #226
tevans55
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Empennage repair with carbon fiber mat.
tevans55 is offline
Old 08-11-2018, 06:56 AM
  #227
tevans55
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Added a little over 13,000 vinyl rivets.
tevans55 is offline
Old 08-12-2018, 07:08 AM
  #228
maddog-RCU
My Feedback: (22)
maddog-RCU's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
WOW looks great; mine is still in the shipping box waiting to be worked on. I want to change out the color scheme on mine also; how did you removed the insignias on yours?
maddog-RCU is online now
Old 08-12-2018, 09:43 AM
  #229
n8622t
My Feedback: (8)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Originally Posted by tevans55 View Post
Post maiden photo of my Top RC FW 190. I made Walter Nowotny's plane. Flew great with a DLE 111, Sierra Retracts, and 58 degrees of flaps which is what the full scale used. I installed a IFlyTallies cockpit. After the second flight I discovered hair line cracks in the empenage so I cut open the bottom of the plane last night and put carbon fiber mat all the way around the inside of the empenage. The stock gear doors handled the thick grass at our field as you can see in the photo.
beautiful plane!! Where in the empennage did you discover the cracks? Iíll defin want to reinforce that area
thanks for the info
n8622t is offline
Old 08-12-2018, 10:28 AM
  #230
tevans55
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Very small light cracks on the side of the fuselage between the front of the rudder and the rear fuselage former. you can see the carbon fiber mat I added to the inside of the fuselage. I cut one piece of mat and used 30 minute epoxy to glue it in place.
tevans55 is offline
Old 08-12-2018, 10:31 AM
  #231
tevans55
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I used wet sanding to remove the decals. They are clear coated so be patient. Once you get through the clear coat you will know it because the decal comes off very quickly.
tevans55 is offline
Old 08-15-2018, 09:34 AM
  #232
n8622t
My Feedback: (8)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thanks for the help tevan55.....Iíll do the same before assembly
n8622t is offline
Old 09-19-2018, 06:14 PM
  #233
tevans55
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I Fly Tallies Cockpit kits work fine.
tevans55 is offline
Old 09-30-2018, 02:21 AM
  #234
totto
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Our friend Dan from Denmark is flying his new TopRcModel FW-190 at our Warbirds over Evje event in june, Norway.
https://m.youtube.com/watch?v=0rRHI1...fauxfullscreen
totto is offline
Old 09-30-2018, 02:47 AM
  #235
n8622t
My Feedback: (8)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nice cockpit Tevans, which scale iflytailies did you use?
n8622t is offline
Old 09-30-2018, 05:38 PM
  #236
tevans55
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I used the 1/5 scale cockpit. I put a plywood panel behind the instrument panel cut to fit the fuselage like a former. I removed the entire Top RC cockpit and put in a new floor made out of G10 Fiberglass. I had to trim the formers back that were in the cockpit but the new floor is attached to both sides of the fuselage which adds plenty of additional rigidity. Good Luck..
tevans55 is offline
Old 10-02-2018, 08:39 AM
  #237
n8622t
My Feedback: (8)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nice!!
n8622t is offline
Old 10-13-2018, 06:15 PM
  #238
LtMash1A
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Ground loop Problems
Need some help here. I'm using the TopRC Models tail gear and Sierra main gear. Using the springs to allow the tail gear to retract as seen in the earlier posts, the plane ground loops after landing. Wondering if anyone else has this problem or maybe my springs are not strong enough or maybe a better way? Thanks
LtMash1A is offline
Old 10-14-2018, 12:19 PM
  #239
tevans55
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Several questions:
How many degrees of flap are you using? Landing on grass or pavement? Is the ground loop always in the same direction?
tevans55 is offline
Old 10-14-2018, 04:37 PM
  #240
LtMash1A
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Several questions:
Grass, 40 dg usually to right.
LtMash1A is offline
Old 10-17-2018, 06:24 PM
  #241
tevans55
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The reason I asked those questions was because it sounds like you may be carrying to much speed into your landing. I have been using 48 degrees of flap which I believe is what the full scale used. I scrub off enough speed that the plane almost 3 point lands and thus rolls a very short distance. I will admit that I have a pull-pull from my rudder to my tail wheel steering arm but I use the tail wheel steering for take off. When I land the plane is rolling so slow that I just let it roll out. Again I would try more flap to get the plane to scrub off more speed. It's very stable and can handle a very slow speed landing. Let me know how it goes. Good Luck
tevans55 is offline
Old 10-17-2018, 06:34 PM
  #242
tevans55
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here is a photo right before touching down. You can see how much flap I have and the tail down attitude indicating this will be close to a three point landing.
tevans55 is offline
Old 10-17-2018, 07:14 PM
  #243
LtMash1A
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for your reply, but it does it if I just taxi and cut the throttle. For instance on the taxi test, I would taxi to almost takeoff speed and and then pull the throttle back and it spins i.e. ground loop. Are you using the TopRC Models tail gear and springs like was shown on the earlier post? Thanks, Dave
LtMash1A is offline
Old 10-18-2018, 03:05 PM
  #244
tevans55
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
No. I am using the Sierra tail gear.
tevans55 is offline
Old 10-18-2018, 03:24 PM
  #245
tevans55
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I am using the Sierra tail gear. I have a pull-pull between my rudder and tail wheel control horn with no springs. If you are ground looping with the tail wheel on the ground I would consider getting rid of the springs.
tevans55 is offline
Old 10-19-2018, 07:38 AM
  #246
AV8ATOR
AV8ATOR's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Finally pulled the trigger on this one. Ordered it with Sierra gear and wheels with the Iflytallies cockpit. Should receive it on Wednesday the 24th.
Leaning towards radial power plant not sure which one yet.
AV8ATOR is offline
Old 10-19-2018, 04:40 PM
  #247
TimD.
My Feedback: (207)
TimD.'s Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Go with the Saito FG90 you will not be disappointed.
TimD. is offline
Old 10-21-2018, 02:25 PM
  #248
Chris Nicastro
Chris Nicastro's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The FG90 is more powerful than the 84 for sure. It would be nice to see a FG90 in this size warbird. Iím testing that engine in my friends Mulligan scratch built plane and it pulls really hard and feels like a cam or second blower speed kicks in on the top end, itís a beast. Iíll be flying that plane soon so I can report first hand on its performance in flight. The FG84 is nice but the 90 is just that much better. But can it fly this heavy warbird with authority?
Chris Nicastro is offline
Old 10-21-2018, 04:37 PM
  #249
AV8ATOR
AV8ATOR's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Guys, this is my dilemma. Can always use a little more power. Like Chris said, "Will the FG90 have authority"? Definitely has the easiest maintenance of all radials and cheapest on the market when compared to UMS and Moki. I will take my time an await Chris test with his friends plane. Hopefully someone is further along that is using a radial.
AV8ATOR is offline
Old 10-21-2018, 05:56 PM
  #250
TimD.
My Feedback: (207)
TimD.'s Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have the FG90 in mine and it drags it around just fine. My Delima is with the TopRc gear being so CRAPPY.
TimD. is offline
