TopRCModel FW-190
Reply
Old 03-03-2018, 10:10 PM
  #126
vertical grimmace
vertical grimmace's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Originally Posted by Katniss View Post
Why would it cause overheating when it's designed to directly provide airflow to the motor? As long as the engine area is baffled correctly and air exits, it should be a benefit. Understandably there would be a performance hit of a few hundred rpm though.
Because the extra load on the engine facilitates lean running, hence over heating if not properly accounted for. This is not the full scale FW 190. The fan on the full scale was on a gear reduction, not spinning the same rpm as the prop.
Again, good for static display in competition, otherwise.... ho hum! Nobody is gonna care about your scale cooling fan spinning while it is flying. But they will when you are fighting deadsticks from lean runs. In the immortal words of Dave Platt : "It has to fly". I find it best to set up my model airplanes to do just that. These are not the full scale, just a representation.
vertical grimmace is offline
Old 03-03-2018, 10:57 PM
  #127
Katniss
Katniss's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I would imagine someone would tune their engine with that fan unit in place so would be compensated for. But you're also right in the fact the fan will add load and if there's pressure change for the carb air, the extra load will exacerbate a lean situation.
Katniss is offline
Old 03-04-2018, 07:12 PM
  #128
wingspar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Install of the throttle and choke servo.
wingspar is offline
Old 03-06-2018, 05:20 AM
  #129
maddog-RCU
My Feedback: (22)
maddog-RCU's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Originally Posted by wingspar View Post
Spent some time working on the main gear install. First, I had to trim off the extra material at the retract mount. Rail spacing was fine but it sat to low in the wing causing interference between the retract and upper wing.
Trial fitted two pieces of 1/8" plywood on top of the rails to help this issue. Layed the retract back down and found that the wheel and strut would be to low in the wheel well. I installed two 1/8 plywood shims ...1/4".... on both upper
part of the mounting rails. With this the wheel and strut sat perfectly in the wheel well and the strut was parallel to the wing surface. Then loaded up the rail mount with West System thickened epoxy before laying down the
plywood piece on top
Wingspar, can you post a picture with the Sierra mains installed in the wings?
maddog-RCU is offline
Old 03-06-2018, 03:19 PM
  #130
wingspar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hope this helps.....
ID:	2257901   Click image for larger version
ID:	2257902   Click image for larger version
ID:	2257903   Click image for larger version
ID:	2257904   Click image for larger version
ID:	2257905   Click image for larger version
ID:	2257906   Click image for larger version
wingspar is offline
Old 03-06-2018, 09:34 PM
  #131
Reverend
Reverend's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Finished installing the DLE 111. Looks like I won't be able to use the fan unit at the motor and drive gear for the autostart is right behind the spinner.
Was strafed by Spitfires and took a 20mm cannon shell in the wingtip
Hi Wingspar,
I am not sure about that. Can you give me this measurement? It might still work.
Name:	2018-03-07 06_30_13-TopRCModel FW-190 - Page 5 - RCU Forums.png
Reverend is offline
Old 03-06-2018, 09:38 PM
  #132
Reverend
Reverend's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I've been in contact with most of the german guys who bought the Topflite sized Fan from me an none have claimed overheating issues. The Fans have a profiled blade which helps scoop air into the cowl so on my TF 190 the temp. on the FG84 actually went down by about 5C. It does however cost you about 100-130 RPM. You do need to check, that the air has someplace to get out of the cowl though! Otherwise the warm air will stay in there and you will have overheating problems again.
The first Fan is almost ready. needed to do some tweaking on the printer to get this fan perfect but it looks good now.
Rev
Reverend is offline
Old 03-06-2018, 10:54 PM
  #133
wingspar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It's about 1/8" from the prop face to the gearing and about 2 1/2" from the prop shaft center line to the uppermost housing.
Dave N
wingspar is offline
Old 03-07-2018, 05:34 PM
  #134
aatjame
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Got my Robart replacement retracts from Mike at Gator RC today. Spent this afternoon getting them installed and so far seem to be working great. They are a lot more robust than the TopRC gear. The design is not at all like the TopFlite FW190 gear. I had to add a 1/8” plywood spacer to each side of the mount to stop the wheel from hitting the top of the wheel well. I told Mike I would use the TopRC tail wheel as it fit so good. Engine is mounted(Saito FG90), fuel tank and fuel system, panel for air, fuel, and switches are installed, radio and servos in and working. I think this this is almost ready to go. The last thing is a fan unit that Philipp (Reverend) is working on for us. The design should fit the stock spinner and just have a few mm clearance on the cowl. Can hardly wait to see it.
John
aatjame is offline
Old 03-08-2018, 04:34 AM
  #135
maddog-RCU
My Feedback: (22)
maddog-RCU's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Originally Posted by aatjame View Post
Got my Robart replacement retracts from Mike at Gator RC today. Spent this afternoon getting them installed and so far seem to be working great. They are a lot more robust than the TopRC gear. The design is not at all like the TopFlite FW190 gear. I had to add a 1/8 plywood spacer to each side of the mount to stop the wheel from hitting the top of the wheel well. I told Mike I would use the TopRC tail wheel as it fit so good. Engine is mounted(Saito FG90), fuel tank and fuel system, panel for air, fuel, and switches are installed, radio and servos in and working. I think this this is almost ready to go. The last thing is a fan unit that Philipp (Reverend) is working on for us. The design should fit the stock spinner and just have a few mm clearance on the cowl. Can hardly wait to see it.
John
Can you post a picture of the gear?
Old 03-10-2018, 08:00 PM
  #136
vertical grimmace
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Rev
Do you balance thse? If so how?
Old 03-12-2018, 05:47 AM
  #137
Kh@n
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Any thoughts about the tail. It seems a little twisty?? Is it necessary to reinforce this area?
Kh@n is offline
Old 03-12-2018, 05:50 AM
  #138
Kh@n
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
John
Sound very nice. No solution from BIGPLANES.NL . Ignoring my mails, even though they accepted (together with TOPRC) that there is a problem with the TopRc landing gear. Poor service
Kh@n is offline
Old 03-16-2018, 07:18 AM
  #139
wingspar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I don't think so. Seems fine to me. I did reinforce the Toprcmodel Zero between the cockpit and the tail with CF and epoxy.
Put the tail retract cover on..
ID:	2259439   Click image for larger version
wingspar is offline
Old 03-18-2018, 06:13 AM
  #140
maddog-RCU
My Feedback: (22)
maddog-RCU's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I would like to get one also Reverend.
Old 03-20-2018, 04:49 PM
  #141
wingspar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The new 6" Sierra wheels arrived for the 190. Excellent!!
wingspar is offline
Old 03-21-2018, 03:56 AM
  #142
maddog-RCU
My Feedback: (22)
maddog-RCU's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
WOW now those are a work of art also; how much did that set you back and does Sierra have more?
Old 03-21-2018, 04:05 AM
  #143
wingspar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
They were included in the price of the retracts. For price, give Darrell a call at Sierra.
Dave N
wingspar is offline
Old 03-22-2018, 05:40 AM
  #144
DrScoles
My Feedback: (18)
DrScoles's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dave, Roberto and I should have our kits next week. Looking forward to seeing yours fly with the big block! I'm still leaning towards a Moki....
DrScoles is offline
Old 03-22-2018, 09:00 AM
  #145
maddog-RCU
My Feedback: (22)
maddog-RCU's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Guys,
just to let you know, I have designed a specific fan for the toprcmodel FW-190 that fits the cowl and the backplate of the original Toprcmodel Spinner. Its 3D printed in BDP, a very sturdy and temperature resisting material (110C)
I would like to get one of your fan units; how can I get one?
Old 03-23-2018, 12:56 AM
  #146
ptdan
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Nearly there👍🏻😊 next cg and wheathering👍🏻
ptdan is offline
Old 03-23-2018, 09:13 AM
  #147
maddog-RCU
My Feedback: (22)
maddog-RCU's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looking good there PTDAN; has anyone flown thier's yet?
Old 03-24-2018, 01:30 AM
  #148
jamessymons
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi, can you post a pic of the Saito FG90R3 install ?
Many Thanks
jamessymons is offline
Old 03-24-2018, 02:29 AM
  #149
ptdan
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi jamessymons
If it is me youre asking, i have the dle 111 engine installed
ptdan is offline
Old 03-24-2018, 02:35 AM
  #150
jamessymons
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi PTDan. Somebody mentioned in one of the earlier replies that they were going to put the Saito in. This is an option i am quite keen on. Your FW looks stunning by the way.
Kind Regards
James
