Reload this Page >
Robart - 630RS 90 degree Pneumatic Main Retracts - HELP Question:
Reply
Old 06-13-2018, 02:38 PM
Electriceddie
Electriceddie's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Robart - 630RS 90 degree Pneumatic Main Retracts - HELP Question:
Hi Guys,
I have the 630RS 90 degree Pneumatic Main Retracts .
I have the ESM Model Bald Eagle (approx.- 15 -18 pounds) 72" span. Is there a rule of thumb for the size of the air tank that can or should be used? Robart makes 3 different size air tanks. Extra small, Small and Large. Does anyone know of the size tank to be used with a plane of the approx. listed size and retracts above and how many cycles that the tank will deliver. A cycle would be dropping the gear and then raising the gear = One Full Cycle.
Thanks Ed
Electriceddie is offline
Old 06-13-2018, 11:56 PM
CK1
My Feedback: (60)
CK1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My suggestion is to go with other largest tank you can fit in the airframe or gang several (2 to 4 ) small ones together . A single small tank will rarely get you enough air to operate more than one cycle on the medium and large retracts
CK1 is offline
Old 06-14-2018, 02:01 PM
Electriceddie
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi CK1
I have a Large Tank now but its to Big & Cumbersome too get into the plane. I have the Extra Small tank, but its too small of air capacity for these size retracts. I was thinking of just getting the Small tank which is the middle size of the 3 tanks they make. I never heard of using multiple tanks. Would you set them up in Series or in Parallel and I guess using T fittings.
Ed
Old 06-14-2018, 02:22 PM
CK1
My Feedback: (60)
CK1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes , you would use t's to connect all the tanks together in series since there is only one direction of flow from the tanks once pressurized . Locate the tanks wherever convenient and run a line between them .
CK1 is offline
Old 06-16-2018, 09:52 AM
scale only 4 me
My Feedback: (158)
scale only 4 me's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Two medium tanks is what the midwest AT-6 used in it's design,, it worked very well and easier to fit than the large tank would have been,,,
scale only 4 me is offline
Old 06-18-2018, 04:21 PM
Electriceddie
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Not Trying to Beat A Dead Horse:
Question:
Could you use , lets say two different size tanks without any issues? Ex. A small tank and an Extra Small tank and get the same pressure to the retracts needed?
Ed
Old 06-18-2018, 04:38 PM
CK1
My Feedback: (60)
CK1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
There is no problem with using different size tanks to get the air volume you need .
CK1 is offline
Old 06-18-2018, 05:01 PM
Electriceddie
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Finally A Good Fit:
Cooollll….. Thanks CK1... Thwill make the install a Whole Lot Easier.... I was using the Robart Large Air Yank and it was becoming a real ***** trying to get it into the Fuse ANYWHERE!!!!!!!!!
Thanks Again...
Eddie
