Top flite hellcat CG
Old 06-03-2019, 03:55 PM
roydefiant
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Top flite hellcat CG
I am balancing mine at the 6 inch outboard center section. DA50 with wrap around Pitts muffler. Both Nimh batteries as far forward as possible. Using the foam tires with the kit. I had heard you still needed to add weight despite the pre-mounted weights.
Mine is slightly nose heavy. Needs about 3/4 of an oz on tail to balance. What have others found?
roydefiant is offline
Old 06-04-2019, 07:22 PM
Chad Veich
My Feedback: (60)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Gear up?
Chad Veich is offline
Old 06-05-2019, 05:47 AM
roydefiant
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
So after checking and rechecking mine balanced just slightly nose heavy with gear up without adding any balancing weights. Si I ended up not adding any tail weight and will see how it flies with CG at 6 inch mark
Old 06-05-2019, 06:57 AM
BarracudaHockey
BarracudaHockey's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Very slightly nose heavy with gear up should be fine.
That's a lot of weight swinging forward so even with fuel burn off you won't be in any danger of a tail heavy landing configuration
BarracudaHockey is online now
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
