Reload this Page >
Let's See Your Luftwaffe Birds!!!
Old 11-21-2012, 07:28 PM
  #601
radfordc
My Feedback: (14)
radfordc's Avatar
Default RE: Let's See Your Luftwaffe Birds!!!
That'll buff out!
ORIGINAL: uncljoe
Well Did not have enough air speed and tried to horse it into the air . FWIW If you feel you dont have enought airspeed ABORT-ABORT-ABORT ......
Semper Fi
Joe
ORIGINAL: glazier808
ORIGINAL: pandissix
Heartbreaking.
+1
May I ask what happened? She was a beauty.
Casey
Old 11-21-2012, 07:36 PM
  #602
vertical grimmace
vertical grimmace's Avatar
ORIGINAL: JGrc
ORIGINAL: vertical grimmace
Some pics of my David Andersen TA 152 build. Progressing nicely now. Pretty complicated wing. Must be careful to build it straight. Not to mention my kit cutter did a very bad job creating the parts. In the end it will be a very nice plane though. All of the work will be worth it.
1/5th scale, 114'' wing. G62 for power. Sliding canopy, operating cowl flaps with thermostat. Scheme will be one of the prototypes with round wing tips. A departure to make it different at the field.
Ughh....cant get pics to load. Will try later
Very nice work! I may pick your brain about the operating cowl flaps.
Here is my 152 project.
JG
Jose, check out this website. Have not played around with it yet, but I do have it sitting in the box. http://www.oregonscaleaviation.com/
Old 11-21-2012, 07:42 PM
  #603
Ram-bro
My Feedback: (101)
That is my next plan is to solder a set up. The plane flies great just had to mod it since the ARFs have taken away the uniqueness of this plane
Old 11-21-2012, 08:08 PM
  #604
hellcat56
My Feedback: (21)
hellcat56's Avatar
Ram bro
I drew my own plans from a blown up 8 x 10 3-view
it is DO -335V-11 the prototype to the A 10 2 seat trainer
It was one of the FEW that was finished and flown
I DO like the night fighter version I think the antenna are cool
I just never got around to adding them on
My plane has two wing mounted bomb drops I dont think the real plane ever flew with drop tanks or bombs but it was on the plans as an option
and the front canopy is open to the side like an ME 109 operated by servo
DLE 30 in front
OS 1.08 glow in back
flies VERY fast
lands nice and slow with full flaps
Old 11-21-2012, 08:24 PM
  #605
Ram-bro
My Feedback: (101)
Thanks Hellcat. Does yours have that unique sound. Mine is the Al Masters kit.I modified it to the night fighter but not the hump back version. Did nt want to make a canopy plug.I should post some pics. It is ready for paint
Old 11-22-2012, 09:35 AM
  #606
hellcat56
My Feedback: (21)
hellcat56's Avatar
your right about the sound
very unique
gas and glow at same time
YES post some photos
Old 11-22-2012, 11:31 AM
  #607
eindecker 3
eindecker 3's Avatar
Here is a pic of my BUSA Eindecker III it has a .91 Magnum 4 stroke
Nick
ID:	1822581   Click image for larger version
Old 11-22-2012, 11:49 AM
  #608
roncannell
My BUSA Triplanes
ID:	1822583   Click image for larger version
ID:	1822584   Click image for larger version
Old 11-24-2012, 10:46 AM
  #609
Prekin
My Feedback: (19)
Prekin's Avatar
Hi all, after some month I´ve almost done my Bf-109F. Wingspan is 2050mm, and the weight without the equipment is about 6500g, I think, that it is too heavy.
ID:	1823377   Click image for larger version
ID:	1823378   Click image for larger version
ID:	1823379   Click image for larger version
ID:	1823380   Click image for larger version
ID:	1823381   Click image for larger version
ID:	1823382   Click image for larger version
Old 11-24-2012, 11:04 AM
  #610
Ram-bro
My Feedback: (101)
looking good, what kit is that?
Old 11-24-2012, 11:20 AM
  #611
Prekin
My Feedback: (19)
Prekin's Avatar
It is not kit. It´s scratch built, I have Brian Taylor´s plan and I enlarged it.
Old 11-24-2012, 12:41 PM
  #612
kahloq
kahloq's Avatar
ORIGINAL: Prekin
You should be fine. 2050mm is 80.7 inches and 6500g is 14.3 pounds. Add in the servos, retracts, motor, etc.....you're probably going to be around 20 pounds. I have an ESM FW-190 D9 at 82.5"(2095mm) and it weighs roughly 22pounds(9979g). It flies just fine and lands quite well...in fact, I have to use full flaps merely to slow it down to land otherwise it will just keep floating on by. I have a 73 inch(1854mm) me-109F that weighs 16.5 pounds(7484g). It also flies well and lands without much difficulty, although flaps are needed more for landing then just slowing it down.
My Hangar 9 80 inch P-51 weighs over 18 pounds and flies well with a saito 220. Landings are usually uneventfull.
Old 11-24-2012, 01:00 PM
  #613
Prekin
My Feedback: (19)
Prekin's Avatar
Thank you for the optimistic words! I´ve just had this Bf-109, the take-off weight was about 9000g (19,8pounds) and it was little bit difficult for landing, it was very fast. I think, if it was go out off engine, it would be a disaster.
Now I have ESM La-7, and the take-off weight is 7700g (16,9 pounds). The landings are fantastic.
Old 11-24-2012, 09:43 PM
  #614
Brad330l
Brad330l's Avatar
ORIGINAL: t_burley
Grumania 262 I built and painted for George Hunter
Very, very nice sir!
Brad
Old 11-25-2012, 08:28 AM
  #615
t_burley
My Feedback: (59)
ORIGINAL: Brad330l
ORIGINAL: t_burley
Brad
Thanks Brad, I am building and painting another one
of these for Evan now
Old 11-25-2012, 11:13 AM
  #616
hellcat56
My Feedback: (21)
hellcat56's Avatar
Todd
did you do a build thread on your 262
or any other
love to see how you do what you do
Old 11-25-2012, 11:41 AM
  #617
t_burley
My Feedback: (59)
there is a build thread here in the warbirds section
started by George (tshark)
Old 11-25-2012, 12:00 PM
  #618
Ram-bro
My Feedback: (101)
I would love to see a apaint tutorial on doing the German paint scheme
Old 11-25-2012, 12:05 PM
  #619
t_burley
My Feedback: (59)
ORIGINAL: Ram-bro
send me some cash and a plane Tony and I'll do that for you
Old 11-25-2012, 12:11 PM
  #620
Ram-bro
My Feedback: (101)
I have my 262 just sitting here staring at me. Way to many projects before it. It is a Saita 262. Just needs final sanding and paint. Cafreful what you ask for.
Old 11-25-2012, 04:09 PM
  #621
pandissix
My Feedback: (134)
pandissix's Avatar
For serious buyers I'm considering listing my award winning ME262 RTF with flight packs. Painted and finished by the Master builder Todd Burley himself. Interested buyers PM me and we can discuss.
Old 11-26-2012, 04:33 PM
  #622
ForkedTailDevil
My Feedback: (21)
Meister Scale FW 190A "Blue 8"
ID:	1823767   Click image for larger version
Old 11-27-2012, 02:22 AM
  #623
Brad330l
Brad330l's Avatar
ORIGINAL: ForkedTailDevil
Meister Scale FW 190A ''Blue 8''
Looks like that P47 driver overshot and didnt get any hits on your departing '190'.
Once again, very nice.
Brad
Old 11-29-2012, 11:52 AM
  #624
SnakeBT6
Nothing fancy, just a repaint of a flyzone FW190..
Going to weather it next..
ID:	1824920   Click image for larger version
ID:	1824921   Click image for larger version
Old 11-29-2012, 12:38 PM
  #625
Ham639
My Feedback: (13)
Ham639's Avatar
Blown - up Platt 109
86" WS, 18lbs, Fox 2.4 for power. Perfect combination.
Flies like a pattern ship and lands like a butterfly with sore feet.
She's six years old now and has over 300 flights. I even did a winter camo whitewash this spring to dress her up.
Next up, I'll blow up Taylors Bf-109E plans to the same numbers.
Cheers,
Chuck
ID:	1824925   Click image for larger version
ID:	1824926   Click image for larger version
