A motor to keep an eye on
My Feedback: (7)
I was at the AMA show and got to see the Revolution motor in the flesh.
Rear intake, rear exhaust, motor mount keeps you from making cut outs in the firewall for the carb.
This is a scale modelers dream. I can hardly wait until the bigger motor comes out.
Ray
Ray
RE: A motor to keep an eye on
The only problem that I can see is the front of the engine is too long. Most new kits with glass cowls are designed with shorter engines. We looked at these to put into the Top Flight Giant ARF Mustang, and the engine is too long. It's over eight inches long and the model calls for the front of the cowl to be 71/2 to 73/4 inches from the fire wall. We ended up using the ZDZ 40 with the rear intake and exhaust set up. Motor screams, but puts out a lot of vibration. I guess you can not have an high compression engine and smooth running in a small package.
My Feedback: (9)
CA
I wonder if the engine could be used in the 1/5 scale Mustang kit not the ARF? Maybe you could make the clearance needed when building the plane? I am looking at building a new Top Flight 1/5 Mustang and I have been looking at that engine. Anybody with the 1/5 scale kit that could check their plans and see if you could make the room to install the engine? I would by one for my Mustang if it will fit the Kit plane?
Thanks Viper
Thanks Viper
My Feedback: (9)
CA
Revolution 50cc gas engine with electronic ignition. The name of the company that makes its escapes me ATM. So I am sorry I cant give you that but I am looking at it for my P51 1/5 kit because I can make mods to the firewall if need be. I just dont have the plane hence the plans so I cant tell. Can anyone with the built kit please tell me if the engine will fit in the plane ?
Thanks Much Viper
Thanks Much Viper
My Feedback: (44)
(CNC) Standoffs do the name thing regarding mounting the "rear inducted engine's carburetor" away from the firewall--- And they also offer a precision 2-piece machined mount which offers a larger mounting "foot print' when the engine is mounted to the firewall additionally; you can combine the CNC standoffs (available from 1/2"- 1-3/4" lengths enabling you to (adjust the length. You have to by the mounting bolts separately though.
My Feedback: (44)
ORIGINAL: gary9648
My Feedback: (25)
ORIGINAL: viper21
Thanks Viper
Thanks Viper
Must be Mustang fever huh!!! I think it is contagious. Here is a pic of the T/F 1/5 kit version showing the distance between the spinner baking plate & the firewall. The distance is 8 1/8" and that is allowing for a 3/32 gap between the backing plate and front cowl lip.
My Feedback: (9)
CA
Hi Countryboy, well yes I thought while I was building the 1/5 scale TF kit and I plan to build it as scale as possible. I was considering picking up a H9 Plane to fly while I build my big Mustang but I think I will pass on buying one as the real funny part is that I am putting together a new in box original EZ Dago Red with new in box original Supra retracts. So I think I will fly it while I build my big P51.
Thanks Viper
Thanks Viper
My Feedback: (7)
What to do, what to do............
In every case of every plane that I have ever owned, where my engine of choice or financial means did not fit..............I modified the firewall. Plans are "old", and built around the engines of the day, damned if I would let a little thing like that ever keep me from putting in the power plant that will offer me the most reliable and powerful porformance.
Brison has never failed me personally, and I do not think this one will either. If I had a smaller plane I would be picking it up. But everything I own will call for the larger 80cc version. I will be happy to report on how it works, when it comes out.
Ray
Ray
