GSP Zero
Old 04-11-2005, 06:35 PM
  #226
SJN
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: GSP Zero
Please be sure to post once you've flown the Zero
you bet I will [8D]
SJN is offline
Old 04-11-2005, 09:45 PM
  #227
Goggles
Goggles's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I got a hold of GSP today and I'll have a new canopy by Friday. $19.95......time to rebuild some gear ribs.
Goggles is offline
Old 04-11-2005, 10:03 PM
  #228
WYDAH
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Googles,
Meant to ask if you had done anything to beef up the retract mounting area on this plane. If not, do you think that is why the gear broke out?
WYDAH is offline
Old 04-11-2005, 11:50 PM
  #229
Goggles
Goggles's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I only beefed up what I could reach from the open hole. But as I have heard many stories of ARF's gear breaking rails, it happened to me also. And others at the field said I had a good landing and it shouldn't have broke.
So, it's time to beef it up.......I have lots of Carbon here
Goggles is offline
Old 04-12-2005, 08:03 AM
  #230
WYDAH
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi,
Sounds like a good idea. What retracts did you go with? Did they fit without modifications? Do you fly off grass? I have yet to purchase the retracts and am interested in what others are using.
WYDAH is offline
Old 04-12-2005, 10:14 AM
  #231
carlbecker
carlbecker's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I fly off grass and am using Robart retracts. After trying to mount them in the orginial place and having them ripe out I redid the mounting system and added flaps which really slow down the Zero for nice landings.
Carl
carlbecker is offline
Old 04-12-2005, 07:51 PM
  #232
Goggles
Goggles's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm using Spring Air retracts. I have the servo mounted in the stock location and the valve and tank sitting in the center. The tank is nice and small so it fits perfectly and everything is contained to the wing.
I then added the Robart struts which help a bit. One thing I don't like is the retracts are so close to the surface of the wing that trying to mount the gear doors would mean they would almost sit outside the surface of the wing. That's why I left them off.
Goggles is offline
Old 04-13-2005, 04:21 PM
  #233
seanychen
seanychen's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have a 20+ MB video of this CMP Zero. Can someone please host this for me? Thanks.
seanychen is offline
Old 04-25-2005, 12:53 AM
  #234
Goggles
Goggles's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well I have the gear fixed and I put 2 really good flights, this this is really quite fast with the 108. Here's some pics.
ID:	262692   Click image for larger version
ID:	262693   Click image for larger version
ID:	262694   Click image for larger version
Goggles is offline
Old 04-25-2005, 12:57 AM
  #235
Goggles
Goggles's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
more;
ID:	262697   Click image for larger version
ID:	262698   Click image for larger version
ID:	262699   Click image for larger version
Goggles is offline
Old 04-25-2005, 09:44 AM
  #236
WYDAH
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Goggles,
Man that looks sweet in the air! Glad to see you have the gear repaired.
I'm almost ready to start assembling mine. Just need to decide on which retracts to purchase, and a bit of radio gear and I'll be ready to tackle it.
Regards,
WYDAH is offline
Old 04-25-2005, 10:10 AM
  #237
JohnVH
My Feedback: (38)
JohnVH's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It is very cool, and its pretty fast! The weathering really makes the bird too, awesome.
JohnVH is offline
Old 04-25-2005, 05:27 PM
  #238
proulxlaw
proulxlaw's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Saito 100 does also.
proulxlaw is offline
Old 06-19-2005, 04:08 PM
  #239
WYDAH
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi,
I am just about ready to assemble the Zero and was going over the instructions and parts. I think I may be missing one of the smaller 6mm dia. aluminum joiner tubes and was hoping someone who has this kit can tell me how many of the aluminum joiner tubes they have and how it goes together. I have three tubes. One larger 18mm or so in dia., and two smaller 6mmx40mm tubes. I believe the smaller 6mm tubes are needed for the Horizontal stab to fuselage connections, however it also looks like from the instructions step 5 when joining the wing halves together that you need to use the large 18mm tube, and another smaller 6mm tube. This means I'm short one of the 6mm tubes! The kit does include some wood dowels, but those I believe are for the pushrods, not the wing joiner. Anyone with this kit know how many tubes it comes with and where they fit? Instructions are pretty bad, but do show a 6mm tube for step 5 the main wing halves. But do not show which tubes exactly fit the stab attachment step 13 and show 12mm holes to be drilled in the fuse for the stab??. Seems they need to be the smaller 6mm tubes though, which means I don't have enough to go around....
Other than this the kit seems to be of excellent quality, and can't wait to get started on the assembly.
ID:	287080   Click image for larger version
ID:	287081   Click image for larger version
ID:	287082   Click image for larger version
ID:	287083   Click image for larger version
WYDAH is offline
Old 06-19-2005, 04:34 PM
  #240
SJN
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You only need one.
They look like this:
SJN is offline
Old 06-19-2005, 09:31 PM
  #241
WYDAH
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey thanks SJN.
I was totally confused. I thought I was suppose to use one of the smaller aluminum tubes (which are actually 12mm and like 40cm when I actually measure them) for the second joiner on the main wing. Now that you show it as a pin, I was able to locate it in the kit.
Thanks again. I promise, no more stupid questions.... Now which end does this propeller thing go on...
WYDAH is offline
Old 06-19-2005, 09:44 PM
  #242
proulxlaw
proulxlaw's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I am going to get one of these CMP Zero's but I have 2 projects in front of it. I would love to see the video that you shot. Were you able to get someone to host it for you?
How does yours fly and what motor did you install?
Old 06-19-2005, 09:46 PM
  #243
Goggles
Goggles's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
....the only stupid question is the one not asked.
Goggles is offline
Old 06-19-2005, 09:47 PM
  #244
proulxlaw
proulxlaw's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The stupid thing would have been to not ask the question and install it ***** backwards causing a more laborous build and added frustration. Just my 2 cents. Let us know how she flies.
Old 06-19-2005, 10:18 PM
  #245
seanychen
seanychen's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: proulxlaw
Yes, I did get it hosted. Here is the video link:
http://www.rcpics.net/view_single.php?medid=55569
Old 06-19-2005, 10:38 PM
  #246
proulxlaw
proulxlaw's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Seanychen:
Great video. It looks like the plane flies great and it sounds awesome. It looks like the motor that you chose has plenty of power for this plane. What motor did you install?
Old 06-20-2005, 01:23 PM
  #247
seanychen
seanychen's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
YS 120 NC
Graupner 15x8 3-blade prop @ 8500 rpm
It will just prop hang at nearly full throttle. Looks funny doing torque roll w/ a WW2 bird though.
Old 06-20-2005, 06:38 PM
  #248
FJ-Air
My Feedback: (18)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi All,
Just starting my GSP 71" zero, I have an OS 120 FSIII with pump, I have a few questions:
1. What size and style spinner are you using?
2. With the OS 120 FSIII with pump, I was thinking of mounting this engine on soft mounts like the Dubro or other, any experience and will this give me enough nose weight to balance the plan
3. I am looking for a pilot bust, where can I find one?
4. Has anyone installed a retractable tail wheel, I have one laying around that would work, any ideas?
5. For the engine I will be using which 3 blade prop should I use?
6. I was thinking of changing to the Robart hinge points instead of the CA hinges, any comments on the stock CA hinges would be great?
7. I noticed going though some of this post that Arf-er looked like he installed a cock pit kit from my view of the photo's, which one did you use
8. Should I use an after marker muffler with this engine or the stock silencer
Any and all help would be appreciated
FJ-Air is offline
Old 12-05-2005, 10:16 AM
  #249
foots7
foots7's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
THANX SJN for starting such a great thread with much info. I ordered a CMPRO zero then discovered this thread and it seems
this plane is nice and a great flyer
.... its been a while since any one has posted anything on this thread so maybee someone will post some pics of there finished zeros
would like to see some pics that that show the scale of the plane like a person next to it.
my zero is delevered tomorrow dec 6 2005. cant wait
http://www.cmpairplane.com/
foots7 is offline
Old 12-06-2005, 12:31 AM
  #250
BULL-RCU
My Feedback: (15)
BULL-RCU's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the great thread guys!!! I was debating between severel different warbirds but the zero is one of my favs. I have a 120 os pumped which will work great ... but since using a gasser in a WACO biplane this summer I'm really thinking of trying to find a 35 - 40 cc 2.4... Thanks again guys and I'll fill you in when I get mine!!!
BULL-RCU is offline
Copyright © 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
