Engine incidence on top flite spitfire?
NY
I'm posting this for a fellow modeler and he would like to know what is the "up or down" thrust in relation to the wing or tail. If someone can look on their plans to see if it mentioned, that would be appreciated.
AB, CANADA
RE: Engine incidence on top flite spitfire?
The thrustline on the spit is set by the engine box...it is offset (down and right if I remember), so the correct thrustlline is set when the engine mount is bolted to the box.....
