radio needs
PA
radio needs
New to giant scale. Need to know some spec on radio stuff. How many servos will work off of 1 6 volt PCM radio system????
Is ther a need for noise traps on 36"and 48" servo extension when using a PCM radio?????
Thanks for your help.
GA
RE: radio needs
ORIGINAL: planerc49
PCM is the method of encoding used in the link between the Tx and the Rx, not in the link between the Rx and servos, so yes you may need to take measures to 'de-louse' your servo signal leads.
