KMP New Spitfire Mk XIV
Reply
Old 01-27-2010, 03:35 AM
  #1226
kinverflyer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: KMP New Spitfire Mk XIV
Have you thought about contacting YT International?
kinverflyer is offline
Old 01-27-2010, 11:42 AM
  #1227
WarbirdPilots
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thank you for the advise. I will give them and KMP a call.
Adam
WarbirdPilots is offline
Old 01-27-2010, 12:01 PM
  #1228
oriole
oriole's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Adam,
You could also call Spring Air. I replaced mine with Spring Airs. They dropped right in and are air up, spring down. Work better than the arf supplied retracts.
www.retracts.com
Oriole
oriole is offline
Old 01-27-2010, 12:12 PM
  #1229
nemesis4u
nemesis4u's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
YES... GIVE BILL WATTON at spring air a call...
He is most helpful if you want spring down type gear....
Just tell him your model and he can figure it out from there...
-CHEERS!
TOMAS
VQ WARBIRDS
"KEEP 'EM FLYING"
www.vqwarbirds.com
info@vqwarbirds.com
nemesis4u is offline
Old 01-27-2010, 06:57 PM
  #1230
Shihtzutan
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sorry Twin, I should have given you the courtsey of a reply even if your offer was a tad bit insulting; I'm not going part with them for less than 50% of their value (as listed on TBM's website), rounded up to the nearest dollar, or you can buy them 'new'. I'm going to the RAM show in Feb., if you want them let me know . . . I'll be their Sat., or I'll be in CT just about every weekend once the weather warms.
Shihtzutan is offline
Old 01-27-2010, 08:20 PM
  #1231
WarbirdPilots
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey Shihtzutan,
Where do you see the original retracts on TBM's website? I can't find them. I see the generation 5 retracts on there. They are selling for $119.00, but you get the generation 5 retracts, struts, wheels, tank, valve, and all the accessories. I am just looking for the original generation 1 retracts. The ones that I have pictured above. Are those the ones you have?
Old 01-27-2010, 11:12 PM
  #1232
Beechbum
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm pretty sure I've got a set out in the hangar if you are still interested. I seem to recall they were a bit wobbly, though.
Beechbum is offline
Old 01-27-2010, 11:17 PM
  #1233
Beechbum
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I guess I could have looker before I posted. I have a set with a valve and the fittings and a length of hose. They were mounted up but never flown. Shoot me a PM.
Beechbum is offline
Old 01-28-2010, 12:12 AM
  #1234
nemesis4u
nemesis4u's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
GENTS...
cHeck this out:
http://www.rcuniverse.com/forum/fb.asp?m=9454630
Old 01-28-2010, 09:09 AM
  #1235
tevans55
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Tomas-
That looks very nice! Will you show us an exploded view of the kit when it becomes available? Thanks.
tevans55 is offline
Old 01-28-2010, 11:02 AM
  #1236
nemesis4u
nemesis4u's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
TEVANS55,
yes...thanks...
-TOMAS
VQ WARBIRDS
"KEEP 'EM FLYING"
www.vqwarbirds.com
info@vqwarbirds.com
Old 01-29-2010, 07:00 PM
  #1237
Shihtzutan
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sorry Twin, I should have looked closer. I have originals, new, unused; identical to your pic. I'll part with retract unit, wire, and valve for 50.00; will deliver or meet me halfway.
Old 01-29-2010, 09:12 PM
  #1238
WarbirdPilots
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
No problem Shihtzutan. I actually just bought a set from another member for the original price I gave you. But I am still interested in your set of retracts. I will give you my original offer plus $5 shipping for just the retracts. Send me a PM.
Adam
Old 01-30-2010, 12:07 AM
  #1239
Shihtzutan
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Turbo, I'll use them in something I don't care about that much, I'm not going to part with them for that amount. If I knew you personally or we were a member of the same RC club, it would be different! Anyway, good luck. Personally, I don't see what you like about them but they will be ok for a beater plane.
Old 03-29-2010, 09:04 AM
  #1240
impalas
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Adam; I know this is a late reply to your original post. Nice refit on the KMP Spit retracts. I am just completing my Spit. I would like to know what struts you are using on your retracts. I agree that the original mounts leave a lot to be desired. I leaned them forward but we fly on the turf farm and the grass is rather high. I think that when I do the rebuild I would like to add the struts. In viewing your pictures I noticed a weld just below the link up area for the strut. Am I correct? If so could you get back to me on the strut type you used. Impalas
impalas is offline
Old 03-29-2010, 07:06 PM
  #1241
WarbirdPilots
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Impalas,
I am using Robart 670 Straight RoboStruts 1/2" diameter. The struts are great and really sturdy. Since I am using the original generation 1 retracts I used a 1/4" wire to connect the struts to the retracts. I had to enlarge the hole in the retract to accept the 1/4" rod.
You are correct, it is a welded piece on each strut. What happened is that when I repositioned the gear to the correct spot, it extended them 1/2" or more. So I had a buddy weld a piece onto the strut to extend it.
What I would suggest doing for any KMP/ESM arf is to strengthen the gear blocks with triangular stock and epoxy each and every edge and joint surrounding the blocks. I would also highly suggest using 6-32 blind nuts and bolts to secure the gear to the gear blocks. The wood screws that they suggest using just don't cut-it on any 15+ pound plane.
Good luck and I hope I answered all your questions.
Adam
Old 03-30-2010, 09:33 PM
  #1242
impalas
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Adam; I have already started the mod on the retract blocks. I've taken pictures as I go along.Will forward them when I get things together. I have made up two U-shaped 5 ply plates that sink it into the existing wing framing,with additional support,saimilar to what we do on foam core pattern wings. When I opened it up, I noted that the main spar was comprised of two long sheets of light ply and hollow in the middle which was a suprise to me. . We've had flooding up here in Rhode Island and as my business is pool maintenance, I've been quite busy today pumping out relatives cellars. I started the "Surgery"early this A.M. and was called off. I'll keep you posted on the mod. I have not flown the Spit yet but after all I've read about the nose over problem, I decided to deal with it now and not at the field. Mine is also an early version. The gear works very well. I set it aside for a few years and after getting back on it I had trouble charging the air system. I took the control valve apart and found a really dirty charging stem inside the valve. It looked like the stem was coated with a piece of neoprene. I cleaned it up and the gear works fine. I don't charge to 60 or 65. I charge to 50 the gear works OK and although quick, it does not slam home. I'll keep in touch . And, Thanks for the info on the retracts. Pete
impalas is offline
Old 06-11-2010, 09:30 PM
  #1243
ghostrider168
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I am going to maiden my Spitfire this coming Sunday. I am a little concerned with the CG recommended at 120mm. Has anyone have any experience or flown at the recommended CG? Or how did you set your up?
Gary
ghostrider168 is offline
Old 06-19-2010, 08:24 PM
  #1244
tevans55
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My first ESM Spit manual indicated a 107mm CG and it flew best at 110mm. Just my opinion but I think 120 will leave you trimming the elevator alot on the first flight. My first ESM Spit hit a bird last fall and I have just finished the second one and will fly it at 110mm for the maiden.
tevans55 is offline
Old 01-31-2011, 08:35 PM
  #1245
DVM100
Location: Canberra , Australian Capital Territory, AUSTRALIA
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi guys,
I've converted my Spitfire from a 28cc gasser to electric and I've balanced her at 110mm. I've got a Turnigy 200kV motor on 10S Lipo swinging an 18 x 14 APC and I'm going to trial 19 - 20" to see how she goes. I've got the same set up in a 1.20 size Seagull PC9 swinging a 15.5.x 12 4-blade and she goes VERY well. Can't wait to get the Spit back in the air.
DVM100 is offline
Old 02-01-2011, 11:13 AM
  #1246
tevans55
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Be sure to shoot some video...would love to see and HEAR your spit!
Good Luck.
tevans55 is offline
Old 02-01-2011, 01:58 PM
  #1247
DVM100
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
lol, sounds like a dig at electrics...if I put my Benedini sound system on board would that be better? My club mates are all taking the piss out of me coz I've gone electric after being a staunch "smelly" for so long
DVM100 is offline
Old 02-01-2011, 07:06 PM
  #1248
tevans55
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
No dig...I am interested to hear a plane this size...just curious.
tevans55 is offline
Old 02-02-2011, 12:32 AM
  #1249
DVM100
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I've got a Seagull 1.20 size PC9 flying on the same motor swinging a 15.5 x 12 4-blade and it sounds awesome. I also have a 96" Austars Cessna 152 using the same set up as well swinging an 18 x 14 - it sounds great as well.
DVM100 is offline
Old 02-02-2011, 01:44 PM
  #1250
Merlin Man
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi,
DVM, could I talk to you re your PC9 flying ?
I don't want to highjack this thread and so I will send you a PM.
Cheers,
Merlin Man.
Merlin Man is offline
Reply
Display Modes
