Esm stuka- new cg location callout per manual
There's been a lot of discussion about the proper ESM Stuka cg location. Kahloq a RCU warbird specialist whom I have a great deal of respect for recommended to be around 120-122mm at one point and this is where I was going to set mine at. A couple of weeks ago my new ESM stuka arrived and I'm just about done with my wing assembly, so I decided to see what the manual said about the recommended cg. So apparently ESM changed the location again to 115mm according the manual. So Kahloq if your reading this or anyone else what are your thoughts please???? Thank you!
This works very well and you can cross reference your numbers to verify. This info will liberate you from CG questions on any other aircraft you have in the future as well. Good luck with your Stuka. I am building a large one myself as well. Very cool plane!
http://adamone.rchomepage.com/cg_calc.htm
