GROUP BUILD - Top Flite Giant Scale F4U Corsair
Old 04-01-2012, 05:54 PM
  #8426
rt3232
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: GROUP BUILD - Top Flite Giant Scale F4U Corsair
Jetsflyin
Nice looking bird and good luck with your maiden
Cheers Bob T
rt3232 is offline
Old 04-01-2012, 05:59 PM
  #8427
rt3232
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Live Wire
looks good , do you have any sched for a maiden ? How much scale modes did you do and how did your wieght come out ?
Cheers Bob T
P S Still have not been able to get my birds out this spring weather amd days off are out of sink, but better days are comming
rt3232 is offline
Old 04-02-2012, 06:18 AM
  #8428
B-Squared
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey Corsair builders...I'm getting ready to sheet the upper half of my Top-Flite Corsair and notice that it calls for the supplied 1/8" sheeting. The sheeting feels fairly heavy and is certainly strong...my question to you all is whether or not it would be beneficial weight-wise to use 5/32" (as is used on the wings) or would the weight savings be outwieghed by some loss of strength/rigidity. Or possibly 1/8" up front with 5/32" in the back. Anyone out there confronted this? Thanks.
B-Squared is offline
Old 04-02-2012, 06:29 AM
  #8429
vasek
vasek's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My advice to you would be to sheet with the 1/8 " but get a lighter balsa. I do this often. If you change thickness, you'll get a "misfit" someplace, not worth the trouble... don't ask
vasek is offline
Old 04-02-2012, 07:02 AM
  #8430
stephanmk1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Both wing and fuselage are entirely sheeted with 3/32 balsa.....Plus stab+fin and rudder with 1/16 balsa..
stephanmk1 is offline
Old 04-02-2012, 07:41 AM
  #8431
B-Squared
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the advice guys...I did lighten the tail structure but I do wish I had used a lighter balsa on the stab and rudder...If I get ambitious, I may take the sheeting off the stab and resheet with 1/16". As far as the fuse, I'll try to get some lighter 1/8" or more likely will do the whole thing in 3/32". (I mis-typed in my previous post...I said 5/32" but meant 3/32"...oops.). My build thread is under "Top Flite GS Corsair-Plug in wings".
Old 04-02-2012, 10:23 AM
  #8432
Live Wire
Live Wire's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
rt3232
Not my plane just building it for a guy. The plane is built to plans no changes other than cockpit and gear. Has a 3w 3w70 single glass cowl and will come out weighting a ton. have not had a chance to weight it yet to see how it comes out. I will not be the one that fly's this bird it will be up to the owner.
I have a hard time getting on these long threads so if I don't get timed out I could be back[8|
Larry K
It came 26lbs with out batteries, not as bad as I thought.
Live Wire is offline
Old 04-02-2012, 02:32 PM
  #8433
rt3232
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Live wire
Have fun on any build
Cheers Bob T
rt3232 is offline
Old 04-02-2012, 02:39 PM
  #8434
Live Wire
Live Wire's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
At my age I always try to have fun. Getting all the stuff to work is the hard part, landing gear and doors can give you the fits[:@] getting it to do what you want it to[:@]
Larry K
Old 04-02-2012, 02:45 PM
  #8435
rt3232
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
B-squared
If you are going to glass go for the 3/32 and the lightest on everything aft of the C/G, but on the rudder and V/fin use harder balsa, if you fly from grass, gofer hole can cause a nose over and you have a mess to tepair. don't ask how I know
Cheers Bob T
rt3232 is offline
Old 04-02-2012, 06:32 PM
  #8436
B-Squared
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
rt3232,
That's good advice on the rudder...I did build a plywood spine in the rudder and the fin has the 1/8" balsa. The stab is heavier than I like. I may strip it and put some lighter balsa on it. Thanks for your help...this thread has been a great resource.
Bruce B.
Old 04-03-2012, 08:01 AM
  #8437
Me410
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I used 3/32 on my Fuse because I had a nice supply of good stuff and the supplied 1/8' was hard and heavy. This mod did not seem to affect any fit issues.But, I did run into a problem.
The kit has widely spaced formers and only a few stringers and in the large unsupported areas the sheeting became more flat than round. I had to put a few supports inside the fuse to push out these areas.
Had i known about this beforehand I would have added a few more 1/4" stringers down the fuse to help hold the shape.
Tom
Me410 is offline
Old 04-03-2012, 08:46 AM
  #8438
B-Squared
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Me410...That sounds like a good plan. The supplied 1/8" is hard and heavy. I'm going to pick up some 1/4" stringers and some light 3/32" this week at the hobby shop. Would you have added stringers to both the upper and lower half of the fuse? Thanks for the tip.
Bruce B
Old 04-03-2012, 09:19 AM
  #8439
Me410
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
B-Squared .... I would add them upper and lower, might get away with adding two to each side. Stiffer stronger balsa stringers may be better than soft bendy ones. If you add a few more, I don't think the wieght penalty will be too bad. My worst areas were behind the cockpit area about halfway to the tail.
Tom
Me410 is offline
Old 04-03-2012, 11:24 PM
  #8440
predman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Finally got a hold of topflite and they have shipped out my canopy,yayyy! My bird weighs 29lbs rtf, built per plans w everything in the box. I did cover w monocote instead of glass, added a full cockpit and full bodied pilot.
predman is offline
Old 04-04-2012, 05:26 AM
  #8441
rt3232
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Good for you, now we need pic's of your maiden Good luck.
Cheers Bob T
rt3232 is offline
Old 04-08-2012, 10:43 AM
  #8442
jetsflyin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ok just got my maiden done and everything went perfect.......i have to tell you, i fly turbine jets and this was my first giant scale warbird, and what can i say UNREAL, im looking for my second project
the plane flew like it was on rails and at 33 lb plus 32 oz of fuel the DA 85 proving to be exelent choice(never push the throttle over 3/4 )
PS.. the custom muffler sound was sooooooo cool
ID:	1748186   Click image for larger version
ID:	1748187   Click image for larger version
ID:	1748188   Click image for larger version
jetsflyin is online now
Old 04-08-2012, 10:45 AM
  #8443
jetsflyin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
more pics
ID:	1748190   Click image for larger version
ID:	1748191   Click image for larger version
ID:	1748192   Click image for larger version
Old 04-08-2012, 11:30 AM
  #8444
rt3232
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
jetsflyin
Vary good hope you have lots of fun with it.
Cheers Bob T
rt3232 is offline
Old 04-08-2012, 12:30 PM
  #8445
Duplicator41
Duplicator41's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well done. Try a G.S. P-47, they fly even better than the F4U. Top Flite is very good except for the non scale gear location. The Yellow Aircraft one is better.
Cheers,
Duplicator41 is offline
Old 04-09-2012, 06:38 AM
  #8446
jetsflyin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i think i want the yellow p-38
Old 04-09-2012, 07:33 AM
  #8447
Fly2XS
Fly2XS's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: jetsflyin
Hello JETS,
Two questions:
1.) When did you get a custom Keleo exhaust for the DA85? The last time I asked (a few years ago), they were not going to make anymore custom units.
2.) How much time with a 32 oz. tank give you on a DA85?
Thanks!
Scott
Fly2XS is offline
Old 04-09-2012, 09:47 AM
  #8448
vinnyjet
vinnyjet's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
chris
very nice bring it to floyd bennett one day
vinny
vinnyjet is offline
Old 04-09-2012, 04:31 PM
  #8449
jetsflyin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
scott.........keleo built the muffler for me in return of a favor
9 to 10 good minutes on the DA85 with about 2-3 minutes reserve
vinny.......yes i will fly the corsair at FBF
Old 04-21-2012, 11:42 AM
  #8450
craigcrumpler
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
has anyone used the likes line for retracts on a corsair
craigcrumpler is offline
Display Modes
