I need a spinner
I need a spinner
Ok guys...I'm running into much more trouble here that I ever thought I would. Basically, I built a 1/5th scale Spitfire from 3-views. It's a competition aircraft and I planned to make a scale static spinner and prop and use a Pica Spitfire spinner for flying, thus I mounted the engine using the Pica which has a "skirted" backplate that the spinner screws onto. After finishing the plane, I decided the Pica was too long and generally didn't look right on the Mk I Spitfire that I built. My first thought was to contact Tru-Turn to see what they might charge to make a 5 inch spinner with a skirted backplate in the shape I want it...$1750 was the quote so plan B....Gene Barton...I emailed him to get a quote and though he was gracious about it, he said he would have to order a minimum of ten spinners from his supplier......expensive.....now I'm down to Plan C...which I'm still working on. I won't fly the plane until I get a spinner and I can't believe there is nobody making a 5 inch spinner for a Spitfire....with Pica out of business, I couldn't even use them if I wanted to.....does anybody have any suggestions as to where I could turn to remedy this? Chad suggested making my own but I tried that once and the spinner was very difficult to balance....the twist here is the skirted backplate since I need that to match the engine location....if worst came to worst, I could recut the engine standoff pylons to a non-skirted backplate....I'm open to suggestions
My Feedback: (60)
AZ
RE: I need a spinner
LA7, you better clarify which Spitfire Mark you have built and which spinner shape you are looking for lest you get inundated with information on MkIX spinners! I will dig up those articles I mentioned, can't hurt to look them over eh?
ORIGINAL: Chad Veich
How about making one? I read an article a few years back written by Bob Underwood. The article seemed to present a pretty simple method of construction, foam and metal if I recall. From what I remember reading it did not seem like a really difficult project. Good Luck.
