*Simulated* Exploding Bomb
My Feedback: (25)
I'd like to share some ideas I recently got from another thread, thanks for the ideas! I'm working on a simulated exploding bomb design that will produce as much smoke as possible. BBQ ash is the best substance that I know of, but if you have something else that works better let me know. Any other ideas or problems you see with my design please chime in. Will it work?
Dion
Update: Design has problems that I will explain later. Making a much simpler split in half bomb using the same pin method, will explain later and post picture. Have to get busy on Pete's Corsair tanks and bombs!
Dion
VA
RE: *Simulated* Exploding Bomb
Hey there Dion. That looks good. I think your idea to use ashes is superb, they won't tend to "pack" into a solid mass as badly as flour will. My only suggestions would be to perhaps not taper the back end to ease exit of all the contents. (maybe this wont be an issue with ashes?) Also, the more weight you've got, the harder it will hit, so maybe you could cast that nose section that the nail or plunger shaft passes thru out of lead? That maybe a bit "too much" though. Otherwise, looks good!
Salute!! ZZ.
Salute!! ZZ.
My Feedback: (7)
If I understand, it looks like the whole aft tapered section is "capped off" with 1/8" balsa and is dis-lodged on impact, so there is no tapered section inhibiting the "Ash-Flow"
Very cool concept. BTW--Dion helped me a BUNCH in the creation of a very reasonably scale repro of a "Brewster Bomb Rack" on my Iron Bay Corsair a while back (Thanks again dion!), and I've been anxious to try dropping something from it that acts a bit more "scale-like" on impact. The "other thread" became amusing, if not a little scary----
My Feedback: (25)
Wow, thanks guys, ZZ that is a good idea to cast the nose out of resin, YEA! You got me thinking now! I figured having a brass pin in the nose would help with the weight and also make it easy to solder. When you drop the bomb from a high enough altitude it will fall straight in.
f4you, you're right about the bomb, it's smooth on the inside of the "blast chamber"! And your welcome, I'll make these bombs in both 1/8 and 1/6 scale if it all works like I want it to, so you'll have something to drop!
I'll post the results! Keep the ideas coming,
Dion
Dion
ORIGINAL: ZoomZoom-RCU
Salute!! ZZ.
Salute!! ZZ.
My Feedback: (7)
I wonder if a vent of some kind to the front side of the piston might be helpful or necessary so as to avoid any vacuum effect on that side during "detonation"?? Just thinking out loud here, it may not be an issue, but might be worthwhile if the ejection seems anemic.....and nothing is worse than an anemic ejection, I'm told......(probably went too far on that one, sorry).
My Feedback: (25)
lol I thought the same thing, thought the gap on the sides would help, but you are probably right. If it can draw air in faster it might help dispel the ashes more efficiently. I'll try and get a prototype done for the weekend to see what happens. Thanks again for your thoughts!
Dion
Dion
ORIGINAL: f4you
My Feedback: (25)
It's on purpose! I've got a really great design that I'm almost ready to post. I've been busy with other projects but I'll be back on this one in a bit. Stay tuned for the updated plans!
Dion
Dion
ORIGINAL: goatboy
the image for the bomb is x'd out. is that on purpose or is it the political correctness monster lurking about?
FL
Dion, while we're waiting for the politically correct bomb pics, what other items of detail have you thought up? I will be getting a T/F Corsair to build shortly and different threads mention you; (kindly of course.)
Paul
Paul
My Feedback: (25)
ORIGINAL: planechucker
Paul
Paul
Let me know when you start that Corsair, I will certainly be able to help you with some unique details.
Dion
Banned
what if you set up a striker and used a Blasting cap or a shotgun primer????? this would not only expell the contents but add a BOOM for realism???? now im thinking outloud>>>then the whole item could be made of aluminum, with an unscrewable brass head (for weithing and durability) and a striker to set off the cap primer.. it shouldnt take MUCH force to discharge a primer or cap.
Timmahh
Timmahh
