CMP 160 sized Texan
Reply
Old 12-13-2008, 11:47 PM
  #601
RCPILOT78
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: CMP 160 sized Texan
jojo....check post #283 I have posted pics..of the flaps and the 3 piece wing...you can see the bolt holes drilled through the top of the wing , through the wing tubes and into a T-nut mounted under the bottom skin...I removed some wing skin at the top and bottom of the wings and inserted and epoxied hard wood blocks above and below the aluminum wing tube for strength. like I said over 200 flights no problem....
RCPILOT78 is offline
Old 12-14-2008, 07:25 AM
  #602
telejojo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looks good did you epoxy or bolt the tube in the center section? I think I will go with one piece wing I have a trailer so space is not a problem.Did you have to drill out the holes for the alum. dowels so they would fit?
telejojo is offline
Old 12-14-2008, 10:19 AM
  #603
mystar46
mystar46's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
I have a question about CG. Is it inverted or upright. Also did you all cg from wing tip or spot clostest to fuslage.
I did mine inverted (I think that's easier on a low wing aircraft) and close to the fuselage. If I remember right they give you a measurement from the leading edage of the wing and another from the leading edge of the wheel wells.
This plane has a short nose so you want to keep the tail as light as possible.
mystar46 is offline
Old 12-14-2008, 02:31 PM
  #604
RCPILOT78
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I epoxied the tube in the center section... the tubes on my kit fit perfectly..don't know why everyone is having so much trouble with those tubes..you would think the manufacturer would check them.
Old 12-16-2008, 12:08 AM
  #605
patzane
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
received my retracts today from sierra giants. The Retract appears well put together. Was able to cycle them about 50 time and they are working excellent. I will be installing them in the AT-6 2morrow
patzane is offline
Old 12-16-2008, 11:42 PM
  #606
speedpro 1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
what kind of throws do you guys have on ali, rud, elev i only see CG on instructions
speedpro 1 is offline
Old 12-20-2008, 05:51 AM
  #607
patzane
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I should have my AT-6 in the air in a few week, Just have to finish some minor details. I can not been this excitied about a madien flight since I started flying 2 months ago
patzane is offline
Old 12-20-2008, 04:33 PM
  #608
Zippi
Zippi's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I've been looking at this plane and I see there are three versions available. Silver, silver black & green, and silver red & yellow. They all have a glass fuse but the silver black & green one says that the wings & tail group is "Monocote-like covered" while the other two say " Wing panel, elevator & tail plane are painted over high-quality balsa wood". Is there a difference in these planes or is it just a type O. Is the outer section of the wings detachable are is this a one piece wing design? Looks like Sierra makes a set of retracts for this plane for $260.00 that drop in. Are these retracts the preferred ones to have and do you get the air tank, lines, valves, etc. when you buy the retracts? Any on the market any better?
Zippi is offline
Old 12-20-2008, 08:31 PM
  #609
LDM
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes some are CMP and some are the copies , you need to ask when ordering or look at the find details , personally I would only buy the CMP version
LDM is offline
Old 12-20-2008, 09:56 PM
  #610
patzane
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Zippi the Sierra retract is a drop in fit for this plane. Are for the retracts itself, there appear well built. For 260.00 you just the retract alone. If you want the air tank, lines and valve that is an extra 80 bucks. I ordered the robarts retract starter kit from Tower Hobbies for 30.00 bucks
Quote:
ORIGINAL: Zippi
patzane is offline
Old 12-21-2008, 07:54 AM
  #611
Zippi
Zippi's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
patzane,
Thanks man. Are there any good Robarts that drop in???
Zippi is offline
Old 12-21-2008, 09:09 AM
  #612
grs34
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
For the ones using the 26 sized engines. How overpowered is the plane? What are your thoughts on using a G38?
grs34 is offline
Old 12-21-2008, 06:57 PM
  #613
telejojo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I just put the Sierra retracts in and they will not work.They will go up but not down,it seems they are locking in the up position and the only way to move them is to pri them out of the lock groove.I put some grease on the rails but once you retract them they are locked.........I don't know. I'll call them tom.
telejojo is offline
Old 12-21-2008, 09:06 PM
  #614
mystar46
mystar46's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
telejojo,
Did you install the gear door covers? I had to trim mine a little before my Sierra gear would go down all the way.
The 26 seems the perfect balance of size and power. It fits very nicely inside the cowl and has plenty of power. I don't think I would say that it is overpowered. The G38 would probably do OK in this plane. The weight is about right that you probably would not need to add any nose weight. My only concern would be if you want it to fit inside the cowl as much as possible it could be a challenge. Look through some of the earlier posts on this thread and you'll see that several guys used some pretty big motors in this plane successfully. The other thing about the G26 is that there is still enough room in the cowl for good cooling airflow.
mystar46 is offline
Old 12-21-2008, 09:23 PM
  #615
mystar46
mystar46's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sorry for the delay Speedpro, see the image attached. I used these throws that came with the amendment. My normal flying is a flight mode with these settings and just a little more elevator throw. I did not use aileron differential and stuck with the higher setting. With such a short fuselage compared with the wingspan, it does not require a lot of rudder and you might want to stay at or under what they show here. When flying, any rudder corrections are very pronounced.
mystar46 is offline
Old 12-21-2008, 11:17 PM
  #616
RCPILOT78
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
grs34...the g26..IS MORE THAN ENOUGH POWER..... the g38 is not only too much power but you are going to add way too much weight mine weighs 17 lbs and even that is too heavy for this plane.....but it does handle the 17 lbs ok but landing speeds have to be kept up all the way to touch down...
Old 12-22-2008, 12:32 AM
  #617
speedpro 1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thanks, mine did not come with this amendment sheet . good point about the rudder ill watch that setting . im going to try the module under the cowl with cooling air flow to reduce or eliminate the need for added weight
Old 12-22-2008, 12:54 AM
  #618
speedpro 1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
one more pic
Old 12-22-2008, 01:19 AM
  #619
patzane
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I did not get this amendment sheet with my AT-6. Dave, is that the correct cg on the amendment sheet[145 mm to 170 mm]. The instruction I received with my AT-6 is 117mm to 125mm
patzane is offline
Old 12-22-2008, 06:02 AM
  #620
telejojo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I did'nt use the covers and I fixed the gear by dremeling some of the shoulder off the rails so they would not lock up so hard.I will probably have a test flight this week.It looks good for the money and balanced good with the OS 160.
telejojo is offline
Old 12-22-2008, 11:30 AM
  #621
speedpro 1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i think the 117 to125 is taken from front of wing and the 145 to 170 is taken from front of wheel opening next to fuse
Old 12-22-2008, 04:17 PM
  #622
grs34
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
THANKS RCPILOT78 FOR THE RESPONSE. I WAS HOPING THAT WOULD BE FAST ENOUGH. HAVE YOU HEARD OF ANY POWER INFO ON USING AN OS 160?
grs34 is offline
Old 12-22-2008, 11:00 PM
  #623
RCPILOT78
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
grs34...no info yet on useing the OS 160.
Old 12-23-2008, 12:10 AM
  #624
grs34
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
RCPILOT78- I'm putting in a smoke system as well. Is the 26 still going to have plenty of power?
grs34 is offline
Old 12-23-2008, 12:24 AM
  #625
patzane
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thanks SpeedPro that sounds more correct. Mine is ready to go, just waiting on my gas tank a buddy has. My power setup is a TGY 52CC swing a 20x10 prop. Most of the motor fits in the cowl but I did have to do a little cutting for the spark plug wire, muffler pipes, and carb. The TGY 52 was 4 oz heaver than the G26. My balance was right on point with the Sierra retracts and both batteries place right behind the firewall. Total weight is 15 lbs and 5 oz, so I am very happy with that outcome. I ran the motor a few time and it lifted the AT-6 wings up at 1/2 throttle. Hope to get my tank before Friday so I can get this bird in the air this weekend for the maiden fight.
patzane is offline
Reply
Display Modes
