CMP 160 sized Texan
Reply
Old 07-23-2009, 02:12 PM
  #676
RCPILOT78
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: CMP 160 sized Texan
GONZALO... glad to be of help....if there is one thing I hate is ...spending a fortune on equipment and find out too late its junk !!!!!!!!.....for what we pay for this equipment we should expect the VERY BEST.......JOE
RCPILOT78 is offline
Old 08-07-2009, 05:21 PM
  #677
Ryon L.
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hello All,
Lost my Texan the other day. Flying straight and level the wing seperated from the fuse. Post crash reveiw showed that the wing mounting plate ( the approx. 3/32 3 ply wood plate the wing bolts screw through via blind nuts) and fuse. former and fiberglass broke. This allowed the wing to slide rearward enough that the front wing pin disengaged from its hole and the wing pulled off the plane taking the bottem rear of the fuse with it. The wing bolts along with the broken and torn wing mounting plate and 5" wide 14" long strip of bottem rear fiberglass fuse was still connected to the wing. I flew it a couple of years with a 40 cc gas engine and almost 20 lbs. flying weight. So I was probably exceeding the limits of the airframe. Thought I would share the experience with all. By reinforcing the wing attaching plate my would still be flying. Hope this will help save some planes.
Easy come, easy go.
Ryon L.
Ryon L. is offline
Old 08-09-2009, 09:23 PM
  #678
Meschmidt
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Finishing up my 3rd AT6. Same setup, Poulan 42, Spring Air retracts, 2.4 Spectrum radio. Hope to get better luck out of this plane as it flys so good and is relatively cheap for a big warbird. First one was lost on a bad battery (15 flights). Second one had a damn 35% Extra 330 get in my way (20 flights). Hopefully this one will last 100 or more flights! Paul
Meschmidt is offline
Old 08-10-2009, 07:41 PM
  #679
droman
droman's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Paul, do you glass the wins?
droman is offline
Old 08-10-2009, 08:17 PM
  #680
Meschmidt
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
No, all stock covering except some weathering and panel lines with pencil and spray water based satin urethane on with spray gun. Urethane makes covering a lot tougher and doesn't wrinkle as much in hot sun. Paul
Old 08-12-2009, 07:58 PM
  #681
droman
droman's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hello all,
Does anybody have in photos the process of reinforcing the wins of the CMP AT-6?
Dax
droman is offline
Old 08-20-2009, 09:20 AM
  #682
IdefixRC
IdefixRC's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Guys,
could anyone upload a scan of the CMPRO 160 Texan CG and throws manual page ?
I'm fixing one up but I have no manual for it. :-(
The CG and throws page would do.
Thanks a lot!
IdefixRC is offline
Old 08-20-2009, 03:04 PM
  #683
Meschmidt
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The wings themselves are pretty strong. It's the supplied aluminum tubes I wouldn't use. Replace them with 3/4" hardwood dowels cut the same length. Hey, F86 SABRE, go to Nitroplanes.com, click on warbirds, AT6, see the instruction manual and download it! There you go! Paul p.s. Flew my new AT6 last Sunday. Flies and lands perfectly!
Old 08-20-2009, 09:10 PM
  #684
IdefixRC
IdefixRC's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks a lot for the tip Paul
I downloaded the picture. Unfortunately the throws are not shown in the explosion drawing.
Can you give me an idea of the throws you are using on yours??
IdefixRC is offline
  #685
RCPILOT78
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Meschmidt....I did one better with the wing tubes.....I inserted and epoxied wood dowels into the aluminum tubes....made them very strong 250+ flights and still going strong....great flying plane...
Old 10-01-2009, 05:16 PM
  #686
droman
droman's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hello all
My AT-6 is in progress. I remove the insignias easy but the number in the fuselage were very difficult, I tried a lot of things that didn’t work so finally I painted over the numbers with Alclad Lacquers resulting in some weathering simulation over the fuselage. Next step are more painting job in the rudder and some preparation of the cabin.
This time I post a poor quality photo, next time I post a better one.
I hope to finish next week.
Dax
droman is offline
Old 10-11-2009, 04:41 PM
  #687
droman
droman's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hello
This is my work of the cabin of my AT-6.
Regards
Dax
droman is offline
Old 10-11-2009, 09:15 PM
  #688
mystar46
mystar46's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Lookin' good Dax!
It's pretty amazing what you can do with the photo-realistic images anymore.
That's going to be a nice looking ship.
mystar46 is offline
Old 10-11-2009, 10:06 PM
  #689
droman
droman's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
More progress, finish the front control panel and the cabin is finish. In person the paint of the fuselage doesn't see like that, I think the flash of my camera is the reason to see like that.
ID:	1293051   Click image for larger version
droman is offline
Old 10-18-2009, 11:42 AM
  #690
UDET
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Guy's
I have a CMP T-6 I stripped it glassed it put pannel lines painted it to look like Miss Behavin I have Sierra gear and a BME 44 for it . It came out real nice but I screwed the Canopy up and have been trying to get another one for eight month from Nitro Models and I keep getting the same BS answer please check our web site for new shipments. Do es anyone have and extra Canopy the would sell me?
Thanks Carl
UDET is offline
Old 10-18-2009, 12:10 PM
  #691
Chad Veich
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I think Wing Manufacturing sell the canopy for the old 81" span Midwest Texan which could probably be made to work.
Chad Veich is offline
Old 10-18-2009, 04:38 PM
  #692
RCPILOT78
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
UDET...I too had the same problem with Nitro Models..I ordered a new canopy and never got it from them....I had a heck of a time getting them to reimburse my credit card payment.......I finaly got a new one from AK-Models inc....there out of Iowa City IA.....they also sell the CMP At-6 kit and they are much easier to deal with... hope this helps...Nitro Models does not stock parts they told me thay had to wait for a damaged kit to be returned to get parts....NOT GOOD BUSINESS...
Old 10-18-2009, 08:39 PM
  #693
UDET
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks For your help I contacted AK-Models maybe they will help me.
I will also chek out Wings manufacturing.
Thanks again and Happy landing Carl
UDET is offline
Old 10-19-2009, 11:28 AM
  #694
UDET
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi all I contacted AK-MODELS by email last night and they responded in less then 20 minutes on a Sunday evening they took the time to respond to my email
WOW that is cool. They didn't have the part in stock but he said they will be in at the end of November that works for me.
Thanks again Carl
UDET is offline
Old 10-19-2009, 05:33 PM
  #695
Meschmidt
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Check with Hobbyking.com. They have parts for this plane too. The website is kind of hard to navigate thru, but their prices are real reasonable. I got this plane for $199! Paul
Old 10-25-2009, 09:43 AM
  #696
loukos
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Guys, finally finished my CMP Texan in the coulours of the Greek Airforce.
I modifyed the model to fit the Robart 620 retracts. Powered by an OS 160 twin Gemini with sullivan on-board glow, graupner digital servos and Weatronic 2.4 radio.
The wings are balsa covered and glassed, paint masks are custom cut from flightline graphics in the UK (highly recomended!!).
Test flight to follow soon
Regards
Loukis
ID:	1301500   Click image for larger version
ID:	1301501   Click image for larger version
ID:	1301502   Click image for larger version
ID:	1301503   Click image for larger version
ID:	1301505   Click image for larger version
loukos is offline
Old 10-29-2009, 11:44 AM
  #697
UDET
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Loukis.
Your model looks great. I like that you moved your tail wheel to a more scale location I did the same. Let us know how the OS 160 FS pulled the Texan around I thought about going to a 160 FS in mine sure would sound awesome.
Well good luck Carl
UDET is offline
Old 10-29-2009, 10:05 PM
  #698
droman
droman's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
HELP HELP
Hello, I have to balance my AT-6, it is not very clear the way the plans explain it, it say that the centre point is 117mm to 125mm from the leading edge of the wing, but what part of the wing, from the beginning next to the fuselage or where the fibreglass ended on the wing,next where the wood part begin, I am confuse.
If I balance it from where the wing begin next to the fuselage, I see that needed a lot of weight in the nose, but if I balance approximately where the fibreglass end it seen that it is well balance.
So the question is, the plans say 117mm to 125mm from the leading edge, which is the correct distance perpendicularly outward from the fuselage on the wing?
Dax
droman is offline
Old 10-30-2009, 07:34 AM
  #699
Meschmidt
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mine is balanced 4 1/2" from the wing leading edge, just outside of the gear pod. Flies great there! This plane needs alot of motor or nose weight to balance. Paul
Old 10-30-2009, 01:46 PM
  #700
mallen
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm new to this thread and thanks to everyone that has posted messages to it over the last few years. I've been interested in the CMP Texan for a few years now and since AK-models is running a special, I figured if I was to get one, now is the time. So I first did a search to see what all I could find out about it and the search brought me here. I've spent a few days reading everything everybody has posted and after all that, I just had to order a Texan...which should be here Monday!
Now for my question; It looks like most are running a Zenoah G26 but I was looking at going with one of the gassers that Hobbyking sales.....The XY26, RCG26, FTL26, or the Turnigy 26. Would like to know if anybody is running any of these and what you think and I'm also wondering if any of these 26's are the way to go or maybe I should consider putting a 40-50 size in it. I do like to have some extra power when needed and I will be flying off a grass field that can be a little rough at times. I just don't want to overpower it or cause an airframe failure because of trying to strap on too big of an engine......?????
Thanks for any and all help! Mark
mallen is offline
Reply
Display Modes
