skyraider
PA
skyraider
I am building a Zirolli Skyraider. I have the fuse framed up and have a problem. I am beginning to build the horizontal stab. Is it built in halves or one piece. If it is onepiece, do you cut fuselage former 11 to get it in place.
Thanks for your help.
Bill
Bill
WI
RE: skyraider
planerc49,
the stab is cradeled in former SS1 ,SS2 .
the stab is built and covered in one piece[stab that is] leaving the elevator to be seperated and covered with fabric if that is what is called for. You should glass the stab and finish up to the primering stage. The stab is then installed and rested on the formers for above, making sure that the stab is square to the verticle stab in both verticle and horizontal and you have not pushed the stab forward on the formers thus changing the stab incidence from what is called for.
tom
tom
PA
RE: skyraider
I guess I am a little confused. If you build the stab in one piece and finish it the way you suggest, the fuselage former F-11 is about in the middle of the stab. Do I have to cut the fuselage former away to get the stab in? Or should I build the stab in 2 halves and work aroung the fuselage former?
Thanks for the response.
Bill
Bill
