H9-F6F Hellcat 60 ARF
#1755
RE: H9-F6F Hellcat 60 ARF
Good luck finding one... Most places show "back order" because H9 has discontinued the 60 size Hellcat.
As soon as I saw H9 discontinued the Hellcat, I dashed over to my LHS and took the last one they had in stock... :-)
M3
M3
#1757
Hey Frank
The 82 will fly it marginally - ie you will be 3/4 to full throttle - and only if its well broken in to spin a 14x6 @ 9,000 RPM or more. You will need nose weight or install batteries in the cowl area.
A Saito 100 is ideal, a 125 or DLE 20 is too much but can be tamed down with a 15x7 3-blade prop.
Nick
Nick
#1759
The struts are flimsy and the mech retracts have a weak part that will break: the collar with the ball link that rotates the strut.
But you can try them and see what happens. I used Robart 615s and later Lados, both worked well.
#1760
My Feedback: (15)
IL
Just received my H9 F6f, what a buitiful looking bird. I got the last one from Graveshobby before they were out of stock. I thnk I will go with the Saito 100, this bird deserves it!
Frank
Frank
#1762
Can't replace the H9 Hellcat as they are OUT OF STOCK and discontinued. I still want a Hellcat and thinking of going bigger, maybe a EMS Hellcat 72" wingspan. At least they come with flaps. Anyone want a set of Century Jet Retracts with wheel well doors, (the whole system) slightly used but cheap, for a H9 Hellcat?
#1763
My Feedback: (15)
IL
What`s cheap? I`m intrested, please let me know what you want for them. Send me a email at [email protected]
Frank
Frank
#1764
ORIGINAL: skrez
Frank
Frank
A great motor for the Hellcat...just be sure to keep after run oil in the case after de-fueling
A new plane can still be bought....one piece at a time...just very expensive...I just bought a spare cowl, canopy, and retracts
#1768
My next step is to put the h9 p51 struts with some modifications on my hellcat, I decided to do a patent to place them but to make them more robust! Initially I cut the leg to the desired length and having bought screws 6x10 opened the taps with appropriate pass.Now it remains to cut the screw in length and must go to a lathe to be eaten 4mm to pass the mechanism! I think its a simple patent and yet to see it in action!
#1770
A question for anyone who knows and can help, what is the easiest way to paint panel lines and weathering on the model??? One solution I think is to Scale Warbird Template of top flite and marker panel line pen of top flite http://www.top-flite.com/accys/topr2187.html and http://www.monokote.com/ accys/topq2510.html but then I have to put something on top to protect the panel lines? Another way is with an airbrush but I have never worked and i have a little fear! I expect opinions, thanks!
#1774
ORIGINAL: Chad Veich
I have the gear doors if that is what you're after rcavi8ter.
ORIGINAL: rcavi8ter
Does anyone know where to get scale strut covers. I have seen a couple guys in this thread with some. Anyone want to mold me a pair? My Hellcat should be RTF next week.
#1775
My Feedback: (60)
AZ
ORIGINAL: har28
Where can I find such gear doors???
ORIGINAL: rcavi8ter
[email protected]
